Extracting images from the RAW Burst file
ptys
p.1 #1Extracting images from the RAW Burst file
Hi All,
I am considering upgrading my R6 to R6 II to get the pre-capture feature mostly. The one issue I can see is actually extracting the individual images from the RAW Burst file. Is there an efficient way to do it? I have looked around and it seems it can only be done one by one either in the camera or Canon's DPP.
R6 III does look better in terms of everything actually, but I would need to buy a CF memory card and get a new Capture One license (I don't want to get a subscription) as mine doesn't support this camera.
Is there any other way to extract the images?
Thanks!
Jul 07, 2026 at 05:46 PM
EB-1
Details
p.1 #2Extracting images from the RAW Burst file
R6 III also uses the old SD cards if you are Ok with the sluggish write speeds compared to CFe Type B.
Jul 07, 2026 at 06:44 PM
ptys
Details
p.1 #3Extracting images from the RAW Burst file
I mean if you want redundancy you need a CF express card.
I have found something here just now. Previously nothing like this was coming up in my searches
https://github.com/AGFeldman/canon_burst_image_extract
I'll try to find a sample burst file to play with it
Jul 07, 2026 at 07:06 PM
rscheffler
Details
p.1 #4Extracting images from the RAW Burst file
Let us know if it works because the general understanding has been that none of the major software options supported Canon's proprietary RAW burst file from the R6II.
Be aware that the R6II's pre-capture implementation locks you out of shooting another sequence until the first one has written to the card. If you plan to use this feature in situations where you may need to do quick successive bursts, you will want to use SDXC V90 cards, which unfortunately are (or were the last time I checked) more expensive than CFe Type B cards of the same capacity. Unfortunately (again), memory card prices are just crazy now...
Pre-capture implementation in the R1, R5II and probably the R6III (I have not tried one to confirm) do not lock you out of starting another sequence as long as there is buffer capacity.
Jul 07, 2026 at 07:56 PM
Kameratrollet
Details
p.1 #5Extracting images from the RAW Burst file
DNGLab works.
Jul 08, 2026 at 06:43 AM
stanj
Details
p.1 #6Extracting images from the RAW Burst file
Kameratrollet wrote:
DNGLab works.
But is incredibly slow.
Jul 08, 2026 at 08:25 AM
Kameratrollet
Details
p.1 #7Extracting images from the RAW Burst file
19,7 seconds to extract 85 dng files.
stanj wrote:
Kameratrollet wroteDNGLab works.
Jul 08, 2026 at 12:23 PM
stanj
Details
p.1 #8Extracting images from the RAW Burst file
Damn! They improved it since I last used it Then again I gave up on the R7 years ago so I didn't try that hard.
Jul 08, 2026 at 06:57 PM
Kameratrollet
Details
p.1 #9Extracting images from the RAW Burst file
Three years ago I tried it. https://github.com/dnglab/dnglab/issues/345
stanj wrote:
Kameratrollet wrote19,7 seconds to extract 85 dng files.
Jul 08, 2026 at 11:13 PM
EB-1
Details
p.1 #10Extracting images from the RAW Burst file
I thought Canon was using the CR3 format. Are you saying that the RAW burst file contains the individual files as DNG?
Jul 09, 2026 at 12:15 AM
stanj
Details
p.1 #11Extracting images from the RAW Burst file
Right! That's it! it wasn't slow - it was useless
Jul 09, 2026 at 12:42 AM
stanj
Details
p.1 #12Extracting images from the RAW Burst file
The R7 and R6m2 did.
Kameratrollet
Details
p.1 #13Extracting images from the RAW Burst file
No, but DNGLab converts them to DNG.
Jul 09, 2026 at 04:11 AM
Switch to mobile view
