The 7Artisan or the TTartisan? They are both very similar in price, under $90.
Has anyone any experience with both? Something that is good for landscapes at f8 and has a decent sharpness wide open...
Why do you need a f/1.2 lens? Is there something specific in your photography that needs that instead of, say, a f/1.4 lens or even one with a smaller maximum aperture?
I’ll leave it to others to reply to you about the comparison between those two “cheap” lenses. :-)
I can't help with experiences with these two lenses. But given these are manual focus only lenses, I think that experience might steer you either way. Again without direct knowledge, the X-E5 might not be the best X system camera for manual focus given the small EVF. I have used the native XF50/f2 and its a terrific little lens, I think I found one here for $275 a few years ago. Also, the new Viltrox Air lenses, 56/f1.7, is auto-focus and a small premium over those mentioned at $144 currently on sale. It seems to get rave reviews.
Why, indeed. Why the need to jump on the thread questioning OP's choices while contributing absolutely nothing?
I have experience with the TTartisan 50/1.2 and found it a little too characterful at times. Especially with the blooming of bright highlights.
I found it a bit lacking optically compared to other lenses by them (I have the excellent 50/1.4 for Sony FF as well as the cheap and cheerful 25/2 for X-mount).
Can't say much about corner and edge performance stopped down, I didn't really use it that way much.
I also have the 7artisans 35/0.95. In general, I prefer TTartisan over 7artisans for their clicked aperture as well as general build/feel.
I had the TTArtisan 50mm f/1.2 and the 7Artisans 50mm f/1.4. The TTArtisan is better both optically and mechanically. It's quite a heavy lens. If I wanted a fast manual-focus lens, I would go for the TTArtisan 50mm f/0.95. You can't really go wrong with either of them.
I like to play with f1.2 lenses, though usually they are expensive...
Not these two.
The only lens I have for the XE5 is the 23mm f2.8.
Would a 50 f1.4 do.? I suppose, if it were in the same price range, but I saw these first...
I know there are compromises, but if there is acceptable sharpness in the middle wide open, and across the frame by f8, I would be ok. Vignetting, coma, lateral and axial aberrations and AF that I am willing to compromise...
The TTartisan lens is allegedly sharper, but looking at various reviews online, they both seem to be about the same. Both are under $100 so I doubt either of them is going to be vastly superior to the other. I would probably just go for the one that is smaller and more aesthetically pleasing on the camera.
Because sometimes questions are posted by people who are new to these decisions, and more experienced photographers can help them make the best choices.
For example, it is easy for someone to assume that the lens with the biggest aperture is always a better choice. Sometimes it may be, and sometimes it may not be — and that’s worth exploring.
And, believe it or not, some people who are price-focused and looking at the least expensive options are not yet aware that they may be sacrificing things like AF.
In fact, taking the time to consider the OP’s context is far from “contributing absolutely nothing.” I’ve seen many people learn a lot from such questions and end up making decisions that they were happier with.
Points, though, for coming up with an entirely, uh, “original” lens description: “ …a little too characterful…”
asekcsc5 wrote: gdanmitchell wroteA question or two:
I’ll leave it to others to reply to you about the comparison between those two “cheap” lenses. :-)I like to play with f1.2 lenses, though usually they are expensive...
Not these two.
C.
As you probably know, the super large aperture lenses (like the f/1.2 versions you mention) have two potential virtues.
1. They can, when used at the largest aperture, produce a very small depth of field. For some purposes, some photographers like that effect — for example in some approaches to portrait photography.
2. They can allow you to use a slightly higher shutter speed in very low light situations… if you are willing to accept that extremely narrow depth of field.
In both of those cases, there are issues to consider.
Regarding #1, while limiting depth of field (DOF) is useful, the extremely narrow DOF at f/1.2 and 50mm can be more limiting than necessary. For example, in a portrait with the head almost filling the frame, the if the eyes are in sharp focus the ears, hair, and tip of the nose may be out of focus! In fact, most often we don’t want to use such apertures for portraits, and f/1.4, f/2 or sometimes even smaller apertures can work well.
Regarding #2 (and here I speak as a person who does night street photography), while the small increase in light through the lens at f/1.2 can be helpful (it is about a half-stop), again the very narrow DOF is problematic in many shots. While I own several f/1.4 lenses that I use for this kind of photography, the great majority of my shots are at f/2.8 or f/4 for this very reason.
I’m unfamiliar with the two lenses you are looking at, so for specific information about them you’ll have to wait for someone else to reply. But were you aware that, according to another poster, that these are manual-focus-only lenses? No AF?
Of course, they don’t sound all the expensive, and if you have the money and want to play around with them, why not, I guess?
gdanmitchell wrote: twelveish wroteWhy, indeed. Why the need to jump on the thread questioning OP's choices while contributing absolutely nothing?Because sometimes questions are posted by people who are new to these decisions, and more experienced photographers can help them make the best choices.
I see no evidence so far that the OP does not know the pros and cons of an f1.2 portrait lens.
But if the OP really does not care about lens aberrations or vignetting then I don't really see the point in comparing the two lenses. Both of them will be a bit soft wide open but I doubt one would notice any difference at f8. At that aperture it becomes difficult to tell the cheap lenses from the expensive ones.
I would go with the TTArtisan. Shorter in length, closer focusing distance, and lighter.
I am a hobbyist, and have been at it for many years. Certainly not an expert, but the only f1.2 lenses that I own is the Nokton 50mm f1.2 for the Sony E mount, which I generally enjoy.
You described both what I know (in a round about way) and what I wanted to know: I know that with lenses that are f1.2 and cost $85, one should not expect much. But perhaps between the two lenses, is there one that's better than the other in some way?
Anyway, I chose the TTArtisan, and when I use it for a while I might report back on how I think it works...
I've got the TTArtisan 50mm f/1.2. I think that for anything cheaper than Samyang 50mm f/1.2 it's the best cheap 50mm f/1.2 (or faster) you can get. Glowy and full of character wide open, but decently sharp. And close up has pretty nice rendering. When stopped down, my camera auto-WB went nuts with when shooting landscape, which hasn't happened with any other lens I've used. Nice clicky aperture and was a fun companion for the 23mm Nokton.
Here's a few shots with the TTArtisan 50mm f/1.2.
Had to correct pretty rough CA's with all the chrome.
I did end up getting the TTArtisan 50mm f1.2. It is a well constructed lens, but a bit larger and heavier than I prefer to use on the X-E5. The pictures are good, I think. Here are some.
Just this morning my 13yo son took this image with the TTArtisan 50mm f/1.2 (SOOC). He loves to shoot with a manual lens. I had to buy another Fuji just so that both my kids can shoot with them. So I bought a used great condition X-T20 that came yesterday, in addition to our X-T30II, since we've had some drama over who can use the little Fuji on our trips, as I usually shoot with my Nikon Zf.
