Remote for a7RVI
EB-1
p.1 #1Remote for a7RVI
Is there a straightforward remote (ideally with lock) that plugs into the a7RVI with a short cable like 1m? It seems they want you to use a smartphone and app, which is totally impractical for my purposes. Thanks.
Jun 10, 2026 at 08:47 PM
Ross Martin
Details
Jun 10, 2026 at 08:51 PM
Malka_1
Details
p.1 #3Remote for a7RVI
This is not exactly what you asked for, but I bought this wireless remote for my A7V:
https://www.amazon.com/dp/B0DYNSV3WZ?th=1
It works great. I leave Bluetooth setting in the camera always on, so it's just a matter of turning on the remote to have it auto-connect and work almost immediately.
No cables, no apps, no smartphones.
Jun 10, 2026 at 09:48 PM
EB-1
Details
p.1 #4Remote for a7RVI
Ross Martin wrote:
EB-1 wroteIs there a straightforward remote (ideally with lock) that plugs into the a7RVI with a short cable like 1m? It seems they want you to use a smartphone and app, which is totally impractical for my purposes. Thanks.
I have read that you can use a USB-C cable remote in one of the ports on side of camera. They are cheap on Amazon, I’m going to try one:
https://www.amazon.com/Kiwifotos-Control-Shutter-Release-RX100VA/dp/B071CQYT3J/ref=sr_1_14?crid=32QDN24D9052X&dib=eyJ2IjoiMSJ9.WasRSd87UwYwWC0ptgYF730TIs_RY7FMxBMd_B0c0Q1deApbBVEXDooZ3vZ5MAVpCJC1pIzpSldITx54-r0vtNhbZKLyVD3ZX00ujRGfsWurfRW7lUeqHq5s68O41W7wMYWiEbjMYt_IFHDUO0WaQ3-AZMwvsHo-h6mdnsg2ImPfuADrhm4MoAhcWyI65yvPn4lGMak61GcZVcZju2zF9-hTVgZPF-8ZAKCVYOVum1Q.ouBtpujVVBVdDMsagJoxJM7-NMy03L80clCj2sHcHAE&dib_tag=se&keywords=USB-C%2Bremote%2Brelease%2Bsony&qid=1781146225&sprefix=usb-c%2Bremote%2Brelease%2Bsony%2Caps%2C150&sr=8-14&th=1
https://www.amazon.com/Control-RC301-Type-Shooting-Accessories-RC301/dp/B0F82VLL3Z/ref=sr_1_16?crid=32QDN24D9052X&dib=eyJ2IjoiMSJ9.WasRSd87UwYwWC0ptgYF730TIs_RY7FMxBMd_B0c0Q1deApbBVEXDooZ3vZ5MAVpCJC1pIzpSldITx54-r0vtNhbZKLyVD3ZX00ujRGfsWurfRW7lUeqHq5s68O41W7wMYWiEbjMYt_IFHDUO0WaQ3-AZMwvsHo-h6mdnsg2ImPfuADrhm4MoAhcWyI65yvPn4lGMak61GcZVcZju2zF9-hTVgZPF-8ZAKCVYOVum1Q.ouBtpujVVBVdDMsagJoxJM7-NMy03L80clCj2sHcHAE&dib_tag=se&keywords=USB-C%2Bremote%2Brelease%2Bsony&qid=1781146225&sprefix=usb-c%2Bremote%2Brelease%2Bsony%2Caps%2C150&sr=8-16&th=1
The 2nd one is USB-C, but the first one looks like that Multi Terminal connector that Sony had on the a7rV and older cameras. The a7rVI has two USB-C ports unfortunately.
Jun 10, 2026 at 11:17 PM
dmcphoto
Details
p.1 #5Remote for a7RVI
I use the Sony Sony RMT-P1BT Bluetooth remote with my A7R-V. It works flawlessly, but I see it has been replaced with the RMT-VP2 that has added functionality for lens control (which I don't need). I also have the Sony RM-SPR1, which is wired and connects to the USB-C port. It too works perfectly, but the Bluetooth version is a LOT more convenient, especially when L-plates make access to the ports difficult.
Jun 11, 2026 at 04:21 AM
Ross Martin
Details
p.1 #6Remote for a7RVI
EB-1 wrote:
The first one also terminates in USB-C. If you look closer you can see there is a 2nd cord as an extension when needed, which fits in between the remote shutter pad and the USB-C termination. 2.3ft for the standard USb-C cable and the extension if needed adds 4.3ft. The shutter also has a hold function which you are looking for.
Edited on Jun 11, 2026 at 12:46 PM · View previous versions
Jun 11, 2026 at 07:13 AM
Chaliel
Details
p.1 #7Remote for a7RVI
RMT-VP2 is the new Sony wireless remote control
It's a bit smaller then the RMT-P1BT and has a much longer reach. Works flawless.
To safe the battery put it on LOCK if not in use.
Jun 11, 2026 at 08:58 AM
EB-1
Details
p.1 #8Remote for a7RVI
It looks like I have little choice. The setup guide is in French for some reason although the page is supposedly English. https://www.sony.com/electronics/support/remote-controls-remotes-for-camera-camcorder/rmt-vp2/manuals
I assume that the AF-On, video (red circle) and C1 will be whatever that cameras custom setting are, correct?
It does not seem to support 2 codes, which is is a serious omission.
Jun 14, 2026 at 08:56 PM
Switch to mobile view
