Sony A7R6 EVF stutter
speedmaster20d
p.1 #1Sony A7R6 EVF stutter
I have observed the following behavior on my A7R6
- when continuous tracking AF is engaged the EVF image can show stutter and lag when panning (looks choppy).
- the stutter is worst when raw quality is set to lossless and less pronounced when the raw quality is set to lossy
not sure if this caused by some random setting or if it is universal behavior
to test this
1-mount a 100mm or longer lens,
2-set the EVF frame rate to HIGH
3-set the EVF quality to high under Finder/Monitor
4-set your camera to continuous AF, choose any AF pattern (for e.g. zone)
5- set RAW quality to to lossless compressed
first pan without AF (do not half press shutter if that's how engage AF/AE) the EVF image is smooth while panning
then half press shutter to lock AF on something and the pan around. the stutter / choppy image should be quite visible
go to step 5 and set RAW quality to lossy compressed --> now it should be better
the rear screen does not show this issue so could be some EVF limitation in this camera or a bug
Jun 09, 2026 at 12:25 AM
snapsy
Details
p.1 #2Sony A7R6 EVF stutter
From the a7vri manual:
"When performing continuous shooting in the RAW format, setting [RAW File Type] to [Compressed] will make the display in the viewfinder/monitor smoother."
Source: https://helpguide.sony.net/ilc/2620/v1/en/contents/0407C_drivemode_continuous.html
This is likely from the lower sensor fps available for LV / EVF when shooting at the slower readout speeds of 14-bits. As to why it's only perceptible in the EVF, I'm guessing maybe it's higher base frame rate.
Jun 09, 2026 at 01:57 AM
duncangr
Details
p.1 #3Sony A7R6 EVF stutter
Check you have pre-capture turned off.
Jun 09, 2026 at 02:14 AM
speedmaster20d
Details
p.1 #4Sony A7R6 EVF stutter
The issue I am describing is not during continuous shooting so nothing to do with this.
Edited on Jun 09, 2026 at 10:19 PM · View previous versions
Jun 09, 2026 at 10:14 PM
speedmaster20d
Details
p.1 #5Sony A7R6 EVF stutter
that is it, it's the pre-capture buffering that is causing the issue. I don't know if it is a bug or real limitation of the camera, I contacted Sony Pro. Will share their feedback. the A1 II does not have this issue
of course I need to have pre-capture ON for certain sitautions and this can turn it into a dealbreaker
Jun 09, 2026 at 10:16 PM
snapsy
Details
p.1 #6Sony A7R6 EVF stutter
speedmaster20d wrote:
duncangr wroteCheck you have pre-capture turned off.
Could you possibly try the same setup and methodology but with pre-capture OFF and shooting in continuous mode with the shutter held-down acquiring images and see if you observe the same EVF stutter as with pre-capture ON? Perhaps the camera employs the same full image processing pipeline for pre-capture as it does for continuous shooting, with the only difference being whether the images are stored to media. If so, Sony might need to expand the EVF warning to include the pre-capture case as well.
Jun 10, 2026 at 10:07 AM
speedmaster20d
Details
p.1 #7Sony A7R6 EVF stutter
before digging more into it I am waiting for Sony to get back about this... after all I paid $4500 for this camera and user is not supposed to debug / root cause the bugs!
Jun 10, 2026 at 08:46 PM
duncangr
Details
p.1 #8Sony A7R6 EVF stutter
I'll put money on the fact that it is 'within specification'.
A1ii and A9iii have EVF glitches with pre-capture on so no surprise this one does too - at least in the 240p mode which is the only mode I use.
Pre-capture itself works fine but the evf stuttering 'gets in the way' when you don't need pre-capture so best only turn it on when it is really required.
Jun 10, 2026 at 09:37 PM
snapsy
Details
p.1 #9Sony A7R6 EVF stutter
I agree. Pragmatically speaking though, the more data points you can provide Sony, the more likely your query will get an answer (and hopefully a correct one at that).
Jun 10, 2026 at 11:25 PM
speedmaster20d
Details
p.1 #10Sony A7R6 EVF stutter
duncangr wrote:
speedmaster20d wrotebefore digging more into it I am waiting for Sony to get back about this... after all I paid $4500 for this camera and user is not supposed to debug / root cause the bugs!
My A1 II has no such stutter , it's unique to A7R6.
Edited on Jun 17, 2026 at 09:56 PM · View previous versions
Jun 17, 2026 at 09:51 PM
speedmaster20d
Details
p.1 #11Sony A7R6 EVF stutter
update :
I have been in touch with Sony Pro, they confirmed this issue and that is a bug (not expected to happen)
They have forwarded ticket to the right department for possible fix via FW update.
Jun 17, 2026 at 09:53 PM
gordonyz
Details
p.1 #12Sony A7R6 EVF stutter
It's in 50fps mode when taking 14 bit raw pre capture at 30fps
I'm really curious what the actual video feed looks like, if that feed is 30fps it'll be
Jun 17, 2026 at 11:15 PM
Switch to mobile view
