How do you keep your soft shutter button attached?
munckee
p.1 #1How do you keep your soft shutter button attached?
I enjoy having a soft shutter release on my Fuji cams, but I've lost at least 3 because they come loose and disappear. Does anyone use a dab of loctite or something to keep it secure?
May 02, 2026 at 09:28 AM
gaopa
Details
p.1 #2How do you keep your soft shutter button attached?
I don't want to use locktite so I periodically check my button to make sure it is secure. So far, so good.
May 02, 2026 at 09:51 AM
gyoung143
Details
p.1 #3How do you keep your soft shutter button attached?
Usually a soft washer goes between button and shutter release, acts as a locking washer. Mine's been on Xpro2 8 yrs and never come off.
Gerry
May 02, 2026 at 10:14 AM
gdanmitchell
Details
p.1 #4How do you keep your soft shutter button attached?
I avoid this problem by…
… not using one.
May 02, 2026 at 12:44 PM
msadat
Details
p.1 #5How do you keep your soft shutter button attached?
just lost two on xe-5
May 02, 2026 at 01:51 PM
ftllens
Details
p.1 #6How do you keep your soft shutter button attached?
sometimes the pitch is not machined well and it backs out. just use high quality one that is specified for your threads. the locking washer mentioned helps as well. i just screw it in until it feels torqued and settled in without snapping then just periodically check. Loctite and super glue I would avoid (i've tried it in the past and they also just come off eventually if the threads aren't good and you're left with damage or hard to remove residue). you could try a bit of ptfe tape
May 02, 2026 at 02:47 PM
Jeffrey
★ Featured Winner
Details
p.1 #7How do you keep your soft shutter button attached?
How soft is it? Rubber? Silicone?
May 02, 2026 at 03:56 PM
gyoung143
Details
p.1 #8How do you keep your soft shutter button attached?
Dunno, haven't analysed it! Sold for the purpose, in fact supplied with the button. I suspect it's synthetic, probably silicon, hasn't deteriorated in 8 years on the Xpro2 so unlikely to be rubber.
It’s a well kmown issue so I think any decent supplier will include one.
Gerry
May 03, 2026 at 05:50 AM
FishheadLens
Details
p.1 #9How do you keep your soft shutter button attached?
I think this is a common issue, I just posted the same thread and just found this one. I've also lost 3. I'm going to start ordering from Temu since it's immensely annoying.
May 30, 2026 at 02:09 PM
munckee
Details
p.1 #10How do you keep your soft shutter button attached?
What's the relevance of Temu here? Just a cheap supply so you always have one on-hand?
I need to find one that comes with this mysterious rubber/synthetic washer (or go find a washer).
May 31, 2026 at 06:50 AM
RoamingScott
[X]
Details
p.1 #11How do you keep your soft shutter button attached?
I’ve only lost one ever, and that was on my Nikon which does not use the soft washer. Never lost a JJC on a Fuji.
May 31, 2026 at 06:53 AM
SGinNorcal
Details
p.1 #12How do you keep your soft shutter button attached?
I'm not sure what resistance people have to using Loctite. Its exactly what it is designed for. Ok, maybe don't use the green which is extra strong. I lost 3 or 4 and was nervous of over-tightening and screwing it up. Loctite Blue, no more problem. I really don't like the feel of the shutter release without the button added.
May 31, 2026 at 09:38 AM
Switch to mobile view
