24 1.4 GM diaphragm noise
ilnonno
p.1 #124 1.4 GM diaphragm noise
Hello all,
for owners of the 24 1.4 GM: does yours make noise when its diaphragm opens/closes?
When not shot wide open, the A7 III cycles it, and mine has started to make quite some noise during its movement...
Jan 31, 2026 at 02:05 AM
Daran
Details
p.1 #224 1.4 GM diaphragm noise
I think you answered your own question as your lens changed and was more silent before. Could e.g. be severe wear or a grain of whatever in the mechanism. I'd call up some repair facility. I guess this isn't exactly uncommon for them to handle. Worst case would probably be that they'd replace the diaphragm, but surely could tell you the cost beforehand. Should be better than the thing failing during a shoot.
Jan 31, 2026 at 05:13 AM
I922sParkCir
Details
p.1 #324 1.4 GM diaphragm noise
I’ve had two copies of the 24mm f1.4 GM, and they both make noise when stopping down at the moment of shutter release. I believe it’s normal.
Jan 31, 2026 at 07:26 AM
jeffbuzz
Details
p.1 #424 1.4 GM diaphragm noise
What "Aperture Drive in AF" setting are you using? That makes a noticeable difference especially on wide aperture lenses.
Jan 31, 2026 at 10:31 AM
ilnonno
Details
p.1 #524 1.4 GM diaphragm noise
Had no idea, actually, now I checked and it was standard (so thanks: learned something new!)
Silent is indeed quieter, although the camera alerts of slower focus.
I tried the 35GM and I hear the same noise, so I'd say no issue with the 24... or I have an issue with both :-)
Thanks
Jan 31, 2026 at 10:53 AM
Switch to mobile view
