How much depreciation should I anticipate ?
Newsonys
p.1 #1How much depreciation should I anticipate ?
I recently found this forum as i was looking for an a7c ii to replace my existing a7s to take my daughter's activities.
There was no a7cii available at the time, so i ended up purchasing an used one locally.
Then my old 24-70 gm lens was just not a good fit with the a7cii and I am trying to sell it to get other lenses for my need.
The issue is that, it had an impact and there is a front element glass damage (link) from years ago.
I still use the lens and has no impact on images, af, etc but more of the cosmetic issue.
How much price cut (us dollars or percentage) should I expect for the item ?
Id appreciate any comments
seems like i can't figure out how to add the link to the photos.
i added the where i also had posted about the issue (korean website)
Apparently, the hyperlink does not work here at all.. ( wonder if it is due to possible scam or etc).
I don't know if could copy the website address below and open in a new web brower tab and see them. .
https://www.slrclub.com/bbs/vx2.php?id=minolta_forum&no=1135841
just want to see if my price is reasonable or if i should go lower.
View previous versions
Jan 22, 2026 at 05:51 AM
Choderboy
Details
p.1 #2How much depreciation should I anticipate ?
I don't see any images and can't use those links.
I suspect nobody else can either.
Did you look at your post after posting?
Jan 22, 2026 at 07:06 AM
Newsonys
Details
p.1 #3How much depreciation should I anticipate ?
thanks, i did not notice that. (im really new and that's actually my first post)....
Jan 22, 2026 at 07:41 AM
MikeEvangelist
Details
p.1 #4How much depreciation should I anticipate ?
One suggestion: take photos of the front of the lens without the filter and lens hood attached, so it will be easier to see exactly what the damage looks like.
That said, I think your price is probably a little high. Used samples in excellent condition have sold here for around $1,000.
Jan 22, 2026 at 08:17 AM
Newsonys
Details
p.1 #5How much depreciation should I anticipate ?
thank you,
per what i have seen on the forum, excellent condition items tend to run between 1000~1200.
will try to see what i can get.
somehow i can't reply the post on my mobile device.
both with the filter and w/out the filter pictures are in the link.
Jan 22, 2026 at 09:05 AM
jeffbuzz
Details
p.1 #6How much depreciation should I anticipate ?
The front glass assembly for the 24-70 GM costs ~$300. So call it a $500 repair. Subtract that from whatever the market value of a used, previous generation lens is.
Jan 22, 2026 at 11:12 AM
chez
Details
p.1 #7How much depreciation should I anticipate ?
Personally I would not want to deal with the repair if I’m looking to buy the lens, if it’s truly a $300 repair, I suggest he repairs the lens and sells it at the higher price with the disclosure the front element was repaired.
Jan 22, 2026 at 11:29 AM
Newsonys
Details
p.1 #8How much depreciation should I anticipate ?
thank you all for the input.
the optics and everything works just fine and have been using it in that way for years now.
if I have to eat up the entire cost of the repair, (such as subtract up to 500 ) for the working lens, I may just consider to keep it (or repair them and sell them at the higher price instead).
Jan 22, 2026 at 12:21 PM
KarmaKramer
Details
p.1 #9How much depreciation should I anticipate ?
Generally look at what B&H offers for the lens used in similar condition, and subtract around $200.
...Show more →
Jan 22, 2026 at 12:29 PM
Newsonys
Details
p.1 #10How much depreciation should I anticipate ?
indeed, it probably should have been in a much better shape than I thought.
28-60 bundle lens, i received 160 dollar check, then
24-70 GM1, it got appraised at $910 even w/out the B+W filter. (i was selling the item all together for lower locally..). anyway done with 2 of 3, but just need to decide what to do w/ the 35 1.4 distagon zeiss....
Thank you all for your comments,
Feb 03, 2026 at 01:32 PM
Switch to mobile view
