Moon over Tulsa
Bruce Marriner
p.1 #1Moon over Tulsa
Here's a photo I took of the moon over downtown Tulsa a weekish ago.
I've gone out to this spot twice so far to try this and I'm still not entirely happy with my result yet but hopefully I'll keep getting better. I think I need a smaller aperture to get a bit better focus across the different buildings and I want to improve my balance of getting detail in the moon but still getting detail from the buildings. Might require some HDR stitching or using a different camera. These were taken with an OM1 and I can't quite pull the shadows up as much as I can with my GFX but I don't have ideal focal length lens for this specific photo on that camera.
Open to suggestions from the group
Jan 13, 2026 at 03:01 PM
Bill Gass
Details
p.1 #2Moon over Tulsa
Killer shot-!
Jan 13, 2026 at 04:55 PM
RWNPhoto
Details
p.1 #3Moon over Tulsa
The Tulsa skyline location I can't figure out, as you have the river there and BOK tower and center where they are, but I'm assuming a fairly long lens in FF terms, maybe even long on the OM. Was the aperture at f/4, or above that?
Jan 13, 2026 at 06:53 PM
Bruce Marriner
Details
p.1 #4Moon over Tulsa
The photo was taken from Chandler Park, just a bit west of downtown. Another similar view that's also great is actually getting on the turnpike right by Chandler Park that goes directly over the river and taking the photo from there, which I've done once so far, costs a dollar for the turnpike fee and risks getting ran over.. but it's a good spot.
I should have included more shot details, but it's the OM1mk2, 50-200f2.8 lens @ 116mm, 200iso, .5s shutter, and f4.
Jan 13, 2026 at 07:54 PM
gregfountain
Details
p.1 #5Moon over Tulsa
I think this image demonstrates how proper use of lens compression pulls those distant objects forward and makes for a nice shot!
Greg
Jan 14, 2026 at 12:03 AM
Jim Dockery
Details
p.1 #6Moon over Tulsa
Looks good to me. My first thought is that it would have been good to catch the moon closer to the horizon (although from the look of the clouds that might not have been possible that night). I would also try a longer exposure if you want more shadow detail, shoot the moon faster to get more detail, then replace the blown moon with the properly exposed one.
Jan 14, 2026 at 06:45 AM
Bruce Marriner
Details
p.1 #7Moon over Tulsa
The clouds were blocking the moon until it got to about that point. I knew what time the moon should have shown up and I couldn't really see the clouds at night and was standing around like "where the heck is the moon" lol. Then it finally showed up between some clouds.
I probably do need to do an HDR composite. I like to try and make a photo work without any stitching and that's probably at least partly because I haven't got around to learn how to do that effectively and may not even have a good tool to do it with and also the added time spent at my computer at home instead of outside. I need to get force myself to take time to learn how to do it and find a program I like to do it with.
Thanks for the suggestions and kind words Jim and also @RWNPhoto, @gregfountain, @Bill Gass
Jan 14, 2026 at 08:25 AM
Taperwing
Details
p.1 #8Moon over Tulsa
FWIW, you can take multiple exposures, adjusting for both the city and moon, and mash them together in Lightroom with 1 click (Photo Merge HDR).
Better yet, take two optimal images, on a tripod, drop each on a distint layer in Photoshop, or any other program that lets you layer and mask, optimize each. Then, add a layer mask on the top image to block off the parts of the underlying image that should not be included.
Jan 14, 2026 at 09:57 AM
Bruce Marriner
Details
p.1 #9Moon over Tulsa
I don't have Lr or Photoshop and I'd prefer to not need to sign up for another monthly subscription. I do use Capture One to edit images and it can do an auto-HDR and I've used that successfully for some things but the moon size and halo and it's light cast on the clouds and sky changes quite a lot of the image and I've had a bit less success with things like that and I feel like something that gives me a bit more manual control would be better.
I do have Affinity Photo and I can probably do it in that but I've not taken the time to learn.
But, next time I go out I'll try to intentionally take some photos I can try HDR stacking and see what I can do with the tools I already have and see how that goes.
Jan 14, 2026 at 10:37 AM
Taperwing
Details
p.1 #10Moon over Tulsa
You can certainly perform the indivual layering, adjustment and masking in Affinity Photo. While more tedious, it will give you far more control over the final image, versus and auto HDR stack. While it doesn't have the newer, automated, AI-type tools baked into Adobe products, Affinity does have edge detection and color-based masking.
I have zero experience with the following program, but you might take a look at:
https://www.sns-hdr.com/full.html
The have a freeware version, but it sounds like you would need to 'upgrade' to the home version (30 Euro) for the masking option. But, no harm in seeing if the free version is useful.
Jan 14, 2026 at 11:07 AM
Bruce Marriner
Details
p.1 #11Moon over Tulsa
Thanks @Taperwing - those are some good suggestions that I'll give a try. I should also dig deeper into what I can pull off in Capture One, I know i can do some masking and layers and maybe mixing that with it's HDR tool I can get some better results. Just all comes down to needing to dedicate some time to learning this side of photography better.
Jan 14, 2026 at 11:21 AM
Bruce Marriner
Details
p.1 #12Moon over Tulsa
Not sure if you meant this or not, but Affinity does have auto hdr, focus, and astro stacking built into it now. Unsurprisingly, I haven't used them much. I did try out the astro stacking once but not enough to really learn what I was doing with it.
Jan 14, 2026 at 11:30 AM
Taperwing
Details
p.1 #13Moon over Tulsa
While I have some experience with Affinity working up figures for professional documentation and publication, I have never had reason to try an HDR stack in that application.
I have dabbled a bit more with HDR stacking in Lightroom, but for the most part, have not been impressed with the automated results. On other hand, I have had great luck mixing exposures by stacking in layers and selectively masking, although that requires jumping over to Photoshop. Again, Affinity Photo could also work, if you want to give it a try. From my perspective, this is quite powerful, as the user has the ability to make any adjustments to each layer, and gets to control how they are mixed in the final presentation by selective masking.
Jan 14, 2026 at 11:45 AM
Bruce Marriner
Details
p.1 #14Moon over Tulsa
I need to go take some photos to merge and then try out Affinity, C1, and SNS and see what results I get from each and then come back with a report
Jan 14, 2026 at 11:47 AM
Details
p.1 #15Moon over Tulsa
I think it is a fine composition Bruce. On my 30" calibrated monitor, it is very nice!! Bigger da better! I agree about a longer exposure time to bring out finer detail and sharpness if possible. I carry a mono and a tripod in my van for instances like this!
Again well done!
Jan 14, 2026 at 12:16 PM
Bruce Marriner
Details
p.1 #16Moon over Tulsa
Again well done!
Thanks Dan! You're doing a great job at buttering up my ego here, hah. I also think it's a good photo but I think I can do a little bit better with a couple of tweaks and since it's a reasonably repeatable photo (I do have to have the moon show up) it's a good one to learn with.
Jan 14, 2026 at 12:51 PM
Details
p.1 #17Moon over Tulsa
Bruce Marriner wrote:
Danpbphoto wroteI think it is a fine composition Bruce. On my 30" calibrated monitor, it is very nice!! Bigger da better! I agree about a longer exposure time to bring out finer detail and sharpness if possible. I carry a mono and a tripod in my van for instances like this!
Again well done!
For most of us, that is the "why" we post here. Not buttering up any ego's here. Just fine photography! Why can't we link photography with fun AND learning?
I encourage ANY photographer to post here. Since you are new to FM, you have become pro-active on FM.
Now you can gripe and cuss at everyone who sez different!
"Rank(double entendre meaning) has it's priviledges" eh?
Jan 14, 2026 at 01:24 PM
Details
p.1 #18Moon over Tulsa
One fine skyline, Bruce!
Jan 14, 2026 at 04:00 PM
RWNPhoto
Details
p.1 #19Moon over Tulsa
RWNPhoto wroteThe Tulsa skyline location I can't figure out, as you have the river there and BOK tower and center where they are, but I'm assuming a fairly long lens in FF terms, maybe even long on the OM. Was the aperture at f/4, or above that?
Ah, okay, Chandler Park. For a time I lived a just down the road from it, right off 41st. Chandler Park is a long ways away from downtown, so wasn't thinking about it.
Jan 14, 2026 at 06:39 PM
Bruce Marriner
Details
p.1 #20Moon over Tulsa
Just a tad over 3 miles but the distance helps the moon look larger
Jan 14, 2026 at 07:21 PM
FM ForumsCity, Street & ArchitectureJoin Upload & Sell
Switch to mobile view
