       2       3       …       5       6       end
New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Admin
p.1 #1 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
The updated 35,40 and 50mm f/1.2 Nokton lenses, along with their matching hoods, are now in stock at:
B&H Photo: Voigtlander 35mm, 40 and 50mm f/1.2 Nokton lenses
CameraQuest: Voigtlander 35mm f/1.2 IV Nokton, Voigtlander 40mm f/1.2 II Nokton and 50mm f/1.2 II Nokton
_____________
Cosina has recently updated their f/1.2 Nokton lenses. The new versions are: Voigtlander 35mm f/1.2 IV Nokton, Voigtlander 40mm f/1.2 II Nokton, and Voigtlander 50mm f/1.2 II Nokton, all designed for the Leica M-mount.
Since the optical formulas, number of aperture blades, and minimum focus distances remain the same, I won't be doing a full in-depth review this time because these lenses have already been reviewed extensively in both Leica M and Sony E-mount versions. Instead, I'll be comparing them side by side, focusing on resolution, contrast, color correction, and overall rendering.
   Voigtlander 40mm f/1.2 Version II, 50mm f/1.2 Version II, and 35mm f/1.2 Version IV Nokton lenses
So what's new? At first glance, it's mostly cosmetic. The front ring material has been updated from silver chrome-plated brass to black, giving the lens a more unified and understated look. This change was driven by feedback from photographers who preferred an all-black finish. I'll admit, I initially liked the chrome "nose" for its classic touch, but after spending time with the all-black Voigtlander 35mm f/1.2 Version IV, 40mm f/1.2 Version II, and 50mm f/1.2 Version II, I've come around. The cleaner, all-black finish has grown on me and now feels more cohesive, especially on modern cameras.
Even though the core design hasn't changed, there's something worth noting. It looks like Cosina has improved the aspherical element manufacturing. With the original 40mm f/1.2, for instance, the onion ring pattern in bokeh highlights was quite noticeable. That artifact seems to have been significantly reduced in the new version. For those who were bothered by that, along with the chrome front, this updated model might be a solid reason to consider switching.
   Voigtlander 40mm f/1.2 Version II Nokton lens
That said, if you already own these lenses and don't mind the look or the earlier aspherical quirks, there's not a major technical reason to upgrade.
Instead of reviewing each one individually, I'll be comparing the three focal lengths — 35mm, 40mm, and 50mm — focusing on differences in resolution, contrast, and overall rendering. Even though they share a modern, high-contrast signature, there are subtle but important differences between them. I'll include plenty of samples to help show how each one performs in real-world shooting.
   Voigtlander 50mm f/1.2 Version II Nokton lens
Aside from the differences in focal length, size, and weight, there are a few spec differences worth pointing out.
The Voigtlander 35mm f/1.2 Nokton Version IV, 40mm f/1.2 Nokton Version II, and 50mm f/1.2 Nokton Version II share a similar optical philosophy with 4 aspherical surfaces each, but differ in other ways. The 40mm is the only one with 10 straight aperture blades, while the 35mm and 50mm have 12. It’s also the lightest and most compact of the three. The 35mm is the longest and can only use the LH-14 hood, as the larger LH-15 will cause vignetting.
   Voigtlander 40mm f/1.2 II Nokton and Voigtlander 50mm f/1.2 II Nokton with the LH-14 (smaller) and LH-15 (larger) hoods
The 50mm is the heaviest and has the longest minimum focus distance at 0.7m, whereas the 35mm and 40mm can focus down to 0.5m. While they share a similar modern rendering style, these subtle differences in handling and design may influence which focal length is the best fit.
Here’s a breakdown:
Aperture blades (straight)
The CV 40/1.2 II Nokton is the only one with 10 blades. The other two have 12.
• CV 40/1.2 II: 10 blades
• CV 35/1.2 IV: 12 blades
• CV 50/1.2 II: 12 blades
Weight (measured without caps)
The 50/1.2 II is the heaviest of the three.
• CV 40/1.2 II: 267g
• CV 35/1.2 IV: 299g
• CV 50/1.2 II: 323g
Length
The 35/1.2 IV is the longest.
• CV 40/1.2 II: 44.7mm
• CV 35/1.2 IV: 51.8mm
• CV 50/1.2 II: 50.4mm
Bayonet hoods (sold separately)
Note: the LH-15 is too large for the 35/1.2 IV and causes vignetting.
• CV 40/1.2 II: LH-14 or LH-15
• CV 35/1.2 IV: LH-14
• CV 50/1.2 II: LH-14 or LH-15
Optical formulas
All three use 4 aspherical surfaces, but the layout differs:
• CV 40/1.2 II: 6 groups 8 elements
• CV 35/1.2 IV: 7 groups 9 elements
• CV 50/1.2 II: 6 groups 8 elements
Minimum focus distance
• CV 40/1.2 II: 0.5m
• CV 35/1.2 IV: 0.5m
• CV 50/1.2 II: 0.7m
Next, I'll compare how the Voigtlander 35mm f/1.2 Nokton IV, 40mm f/1.2 Nokton II, and 50mm f/1.2 Nokton II perform at infinity, focusing on resolution, contrast, and lateral chromatic aberration correction.
Jun 02, 2025 at 07:03 PM
Admin
p.1 #2 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Infinity Resolution and Contrast: Voigtlander 35mm f/1.2 IV, 40mm f/1.2 II, and 50mm f/1.2 II Nokton lenses (M11)
This section compares the Voigtlander 35mm f/1.2 IV, 40mm f/1.2 II, and 50mm f/1.2 II Nokton lenses in terms of resolution, contrast, vignetting and color aberration correction. I tested them wide open at f/1.2 (which renders similarly to f/1.4) and also at f/4, where each lens reaches its optimal sharpness.
All three share similar optical traits, and you'll notice this in the sample crops. Wide open at f/1.2, they show strong vignetting (which I left uncorrected for this comparison), along with a noticeable amount of spherical aberration and both axial and lateral chromatic aberration. These flaws vary slightly between the lenses, and that's exactly what this comparison is meant to highlight.
The crops show performance across the center, mid-field, and corners. While these lenses deliver comparable results in some areas, differences in contrast and resolving power become clear depending on the region of the frame.
Since images usually speak more clearly than words, I hope these side-by-side comparisons help you decide whether one or more of these lenses fits your shooting needs.
  1. Distance: Infinity
  2. Focus: Center - Best of three shots at maximum magnification
  3. White Balance: Daylight
  4. Both lenses are perfectly centered, as verified with my decentering test.
  5. Software used: Lightroom with FM Default Landscape Sharpening; all other settings are at default.
    PS: Vignetting, Chromatic Aberration (CA), and distortion were NOT corrected either in post-processing or in-camera.
    _______________________________
    Center Performance Analysis:
    All three lenses perform similarly in the center when shot wide open, with good contrast and resolution. That said, the 40mm and 50mm lenses show slightly better sharpness than the 35mm f/1.2 IV Nokton. In terms of axial chromatic aberration, both the 35mm and 40mm exhibit more noticeable color fringing compared to the 50mm, with the 40mm showing the highest level of color error.
    Once stopped down to their optimal aperture, center performance improves across the board. Axial CA is no longer visible, and both resolution and contrast hit their peak. The 50mm still appears to have a slight advantage in sharpness, but overall, the differences between the lenses become very small at this point.
    Center Resolution and Contrast at f/1.2
    Voigtlander 35mm f/1.2 IV Nokton @ f/1.2
    Voigtlander 40mm f/1.2 II Nokton @ f/1.2
    Voigtlander 50mm f/1.2 II Nokton @ f/1.2
Jun 03, 2025 at 07:03 PM
Admin
p.1 #3 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Center Resolution and Contrast at f/4
Voigtlander 35mm f/1.2 IV Nokton @ f/4
Voigtlander 40mm f/1.2 II Nokton @ f/4
Voigtlander 50mm f/1.2 II Nokton @ f/4
Jun 03, 2025 at 07:04 PM
Admin
p.1 #4 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Mid-field Performance Analysis:
Wide open, none of the three lenses perform particularly well in the mid-field area. Among them, the 50mm delivers the best results, followed by the 35mm, while the 40mm shows the weakest performance. This drop in quality is not caused by field curvature, as refocusing specifically on the mid-field does not lead to any noticeable improvement.
Once stopped down to their optimal aperture, all three lenses show a significant jump in mid-field performance. Axial chromatic aberration is no longer present, and both resolution and contrast reach their maximum levels. The 50mm still holds a slight edge in sharpness, but the differences between the lenses become much less noticeable at this point.
__________________
Mid-Field Resolution and Contrast at f/1.2
Jun 03, 2025 at 07:06 PM
Admin
p.1 #5 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Mid-Field Resolution and Contrast at f/4
Jun 03, 2025 at 07:07 PM
Admin
p.1 #6 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Extreme Corner Performance Analysis:
Wide open, all three lenses show strong vignetting in the extreme corners. The 35mm has the most noticeable vignetting, followed by the 40mm and 50mm, which are pretty similar in this area. Considering these are f/1.2 lenses tested on a 60MP sensor and viewed at the pixel level, I’d say they actually hold up fairly well in terms of sharpness and contrast. Detail is a bit soft, and lateral chromatic aberration is visible --- most prominently on the 35mm, then the 40mm. The 50mm handles this the best, showing the least amount of lateral CA.
Once stopped down to their optimal aperture, corner performance improves across the board. Vignetting is much less noticeable, contrast picks up, and fine detail becomes more defined. The 50mm still shows a slight edge in sharpness, but by this point, the differences between all three are minor.
___________________
Extreme Corner Resolution and Contrast at f/1.2
Jun 03, 2025 at 07:08 PM
Admin
p.1 #7 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Extreme Corner Resolution and Contrast at f/4
Jun 04, 2025 at 11:01 AM
ZdevilH1
p.1 #8 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Great to see Cosina evolving these lenses. If I am reading the spec's correcty, is the new 35mm f1.2 IV a bit longer than the previous version?
Version III is 50.5mm tall vs 51.8mm for verion IV.
Jun 04, 2025 at 11:56 AM
Steve Spencer
p.1 #9 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
That is correct. The new black front ring is lighter but does make the lens a bit longer. It also allows the hood to be reversed.
Jun 04, 2025 at 12:03 PM
Geoff CB
p.1 #10 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Thought it was great news about the updated quality of the 40mm 1.2. Would love to see a direct comparison .
Unfortunately I looked at the price on B&H. Yikes! A $350 price increase to $1150 from $800
Jun 04, 2025 at 12:12 PM
rscheffler
p.1 #11 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
As with refreshes from many other brands, it's not only an opportunity to potentially improve a product, but also to reset the price point. Whether or not that's coming from Cosina is another matter though, because the v2 lens is listed at Map in Japan for JPY 100,473 pre-tax, which is about USD 700... FWIW, the 35 and 50 are both around USD 750. FWIW 2, I checked a Canadian retailer and the 35 v4 is CAD 1300, which is about 950 USD. As is the 50/1.2 v2 and the 40/1.2 v2 is about USD 75 less. Interestingly the new lenses are slightly lower price than the previous versions at that store.
I'd guess there's some early adopter premium combined with a buffer due to the current uncertainties around international trade tariffs. This makes current price comparisons a bit less apples to apples. If someone was building a Voigtlander/Zeiss kit from scratch involving a number of lenses, it might be worth the flight to Tokyo. I doubt you'd save money after including the flight, hotel, meals and incidentals, but you'd potentially get a trip in addition to lenses out of the same buying power. This price discrepancy has been somewhat persistent with Voigtlander and Zeiss lenses but is not universal across all brands. Many are quite similar globally, which likely is no coincidence.
Jun 04, 2025 at 10:19 PM
maly149
p.1 #12 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Voigtlander and Zeiss stuff is usually ~20% cheaper in Japan. Assuming it's due to being manufactured there? Hasseblad lenses are also cheaper. The 50 Color Skopar and 28 Nokton also had a similar price gap in US pricing Vs Japan. You can order on Map through Buyee and save some change, even with the fees.
Jun 05, 2025 at 12:51 PM
rscheffler
p.1 #13 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
It seems to be somewhat unique to Cosina-made products. It has been the case for at least 10 years and it kind of ebbs and flows, in respect to how significant the price differences are. Some items are not much, while others are. For example, my wife was just in Tokyo and picked up the VM 50/2.2 for me for about USD 450, while it's $600 at B&H. It seems like the significant price gap with the new f/1.2 lenses is possibly half attributable to tariff buffer. I think right now it should only be 10%, but that may change. I think the threatened tariff for Japan was supposed to be somewhere around 25-30%.
Regarding Buyee: you used to be able to buy new cameras and lenses from Map via Buyee but at some point over the last couple years they rescinded that and it appears they now only allow some accessories (at least the last time I checked a while back). Used cameras and lenses though appear to be purchasable through Buyee. A downside of using forwarders is you have to pay Japan's 10% domestic consumption tax, and as you mentioned, also pay the fees and shipping. For a difference of $150-200 before fees and shipping on a $700-900 lens, it might not be worth it considering the hassle to return if there is a problem. But the f/1.2 trio price difference is more like $400 per lens and more tempting to exploit.
Jun 05, 2025 at 09:16 PM
Juha Kannisto
p.1 #14 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Cosina announced the official release date of 40/1.2 II VM today, it's 20th of June:
https://www.cosina.co.jp/news/%e3%83%95%e3%82%a9%e3%82%af%e3%83%88%e3%83%ac%e3%83%b3%e3%83%80%e3%83%bcnokton-40mm-f1-2-ii-vm-%e7%99%ba%e5%a3%b2%e6%97%a5%e3%81%ae%e3%81%8a%e7%9f%a5%e3%82%89%e3%81%9b/
Jun 06, 2025 at 03:19 AM
Xavier Rival
p.1 #15 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Do you think this means that stores like Yodobashi should have it at this date or shortly thereafter ?
Jun 06, 2025 at 10:10 AM
Juha Kannisto
p.1 #16 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Japanese stores that sell CV lenses always get them a couple of days earlier but they will start selling them to customers precisely from the official release date. And the online shops usually ship them on the previous day to those who have pre-ordered so that they will receive them on release day. I haven't bought CV lenses from Yodobashi since I usually buy mine from Map Camera or Fujiya Camera but as long as they get stock, they should have them available from the release day.
Jun 06, 2025 at 10:23 AM
Xavier Rival
p.1 #17 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Many thanks!
Jun 06, 2025 at 10:30 AM
Admin
p.1 #18 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
As I mentioned earlier, one of the noticeable optical improvements was the updated aspherical lens element in the Voigtlander 40mm f/1.2 Nokton v2. The previous version was the first Nokton to use a double aspherical design with four aspherical surfaces. Since it was produced much earlier, starting with the E-mount version, onion rings are clearly visible in specular highlights. This is not the case with the other two versions, or at least they show the effect to a much lesser degree.
This is a known issue, and there are many examples online that show the onion ring pattern. I also ran a quick test to show how much clearer the inner structure of the highlight rendering is now.
As a bonus, I included the onion ring pattern from the hand-produced aspherical element in the Light Lens Lab 50mm f/1.2 "1966" version for comparison. This lens shows the most obvious artifact, but it closely matches the original Leica from the 1960s. Since that lens was mostly used with film cameras, the onion rings were not as noticeable compared to shooting digital with it.
Light Lens Lab 50mm f/1.2 Noctilux "1966"
Jun 06, 2025 at 09:26 PM
Nick YR
p.1 #19 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
Oh wow that onion ring pattern on LLL 1966 is much worse than i anticipated, very distracting
Jun 07, 2025 at 12:41 AM
Knut.
p.1 #20 · New Voigtlander 35mm, 40mm & 50mm f/1.2 Nokton Review
It is quite funky. I wonder if we will start liking union rings when in 10 years they are gone from the main stream lenses.
A lot of aberations have had or are having their revival to date.
Jun 07, 2025 at 06:54 AM
       2       3       …       5       6       end
       2       3       …       5       6       end
