       2       3              86       87       end
Fujifilm GFX100RF Discussion and Image Thread
RoamingScott
p.1 #1 · Fujifilm GFX100RF Discussion and Image Thread
Available April 2025, $4900 USD, black and silver options available.
102mp sensor
35mm f4 integrated lens
5.76mp EVF
7.9" MFD
Leaf Shutter
4 stop ND
1/4000 max shutter speed
Dual UHS-II SD slots
3:2 3.2", 2.1mp Tilt Screen
Digital Teleconverter supporting 45mm, 63mm, 80mm
Dedicated aspect ratio dial supporting 1:1, 3:2, 3:4, 4:3, 5:4, 7:6, 16:9, 17:6, 65:24, and C settings
740g with battery and memory cards
https://jonasraskphotography.com/2025/03/20/impossibly-possible-the-fujifilm-gfx100rf-review/
Edited on May 09, 2026 at 10:02 AM · View previous versions
Mar 20, 2025 at 08:08 AM
RoamingScott
p.1 #2 · Fujifilm GFX100RF Discussion and Image Thread
It seems that most of the youtube reviews mention that the lack of IBIS, while unfortunate, is somewhat mitigated by the leaf shutter.
I think most people who are used to using the X100V will know exactly what they mean. You can get slow, but not IBIS-capable slow.
Nice to see lots of love for the aspect ratio dial. I do wish 65:24 was closer to 4:3 instead of 3 clicks away, with lowly 16:9 between them.
Mar 20, 2025 at 08:18 AM
524f44
p.1 #3 · Fujifilm GFX100RF Discussion and Image Thread
Lot's of comparisons to the X100V/VI. Will it be just as hard to obtain?
Rod
Mar 20, 2025 at 08:34 AM
RoamingScott
p.1 #4 · Fujifilm GFX100RF Discussion and Image Thread
Rod
I would anticipate a not insignificant number for sale here within 2-3 months as people like me realize the camera is nice but more than we need
Mar 20, 2025 at 08:36 AM
saxguy
p.1 #5 · Fujifilm GFX100RF Discussion and Image Thread
I'm so torn on this. I like the idea and I'm sure the images will be great under the right circumdstances. The lack of IBIS may be a real issue - 100MP image with the GFX100RF without stabilization vs the 60MP image of a Q3 with IBIS and a wider aperture when faster shutter speeds are needed is something I think about.
I preordered one but will keep an eye on real world user reports.
Mar 20, 2025 at 08:50 AM
TN_nato
p.1 #6 · Fujifilm GFX100RF Discussion and Image Thread
Help me understand the slower lens here and the comparisons to the Q3. Does the larger format have a higher than f4 equivalent for 35mm FF?
Also - what's this going to do to X100 F/V/VI X Pro 2/3 prices?
Mar 20, 2025 at 08:55 AM
RoamingScott
p.1 #7 · Fujifilm GFX100RF Discussion and Image Thread
This lens is a 28mm f2.8 in terms of FOV and bokeh. The only similarity to the Q it has is that it's a similar FOV and fixed lens camera that costs lots and lots of money.
This camera exists well outside of the X100 market, it will likely not affect it much, short of some people selling off their X100 camera to partially fund this.
Mar 20, 2025 at 08:58 AM
snapsy
p.1 #8 · Fujifilm GFX100RF Discussion and Image Thread
Why does a leaf shutter mitigate the absense of IBIS? IBIS isn't design to handle the frequencies induced by shutter vibration - in fact shutter vibration is known to interfere with some stabilization implementations. IBIS is designed to reduce hand-holding motion, ie frequencies of human cyclical movements. Also, an EFCS is effective at eliminating shutter vibration.
Mar 20, 2025 at 08:59 AM
RoamingScott
p.1 #9 · Fujifilm GFX100RF Discussion and Image Thread
The conversation here is about the absolute minimum shutter speed a given person will be able to obtain.
Having a leaf shutter on a camera with no IBIS will allow you to push that number lower than if you had a slappy shutter with no IBIS. Pedantry and real life often don't intersect
Of course this number would be lower if the camera had IBIS.
Mar 20, 2025 at 09:02 AM
buggz
p.1 #10 · Fujifilm GFX100RF Discussion and Image Thread
Moved to other thread...
Mar 20, 2025 at 09:17 AM
snapsy
p.1 #11 · Fujifilm GFX100RF Discussion and Image Thread
An EFCS on a focal plane shutter effectively eliminates blur from shutter vibration - the vibration from the second mechanical curtain closing doesn't start resonating through the camera until after the exposure is over, which is why they're so effective. To address my pedantry, can you point me to some real life examples comparing a leaf vs EFCS on a comparable camera design?
Jim Kasson performed comparisons of the A7r III's EFCS vs fully electronic shutter and saw no difference in blur at any shutter speed. Are you saying a leaf shutter produces less vibration than no physical shutter at all?
Mar 20, 2025 at 09:20 AM
RoamingScott
p.1 #12 · Fujifilm GFX100RF Discussion and Image Thread
Have you ever shot a focal plane shutter GFX? Like, outside. Real conditions. Not doll heads.
Mar 20, 2025 at 09:26 AM
RichardPhota
p.1 #13 · Fujifilm GFX100RF Discussion and Image Thread
So impressive to have such a lightweight medium format camera. Does the lens performance good enough?
Mar 20, 2025 at 09:30 AM
Adam Au
p.1 #14 · Fujifilm GFX100RF Discussion and Image Thread
I like the idea of this but struggle to find a use case in my situation. I have an X100vi for travel.
Mar 20, 2025 at 09:32 AM
snapsy
p.1 #15 · Fujifilm GFX100RF Discussion and Image Thread
I have, with the GFX 100S I own.
Mar 20, 2025 at 09:33 AM
JadedWriter
p.1 #16 · Fujifilm GFX100RF Discussion and Image Thread
I think Fuji nailed the camera design for this. I just don't need this and I'm not paying basically 4 grand to be stuck at 28mm while I have GF glass that I like using. I hope this is a seller though.
Mar 20, 2025 at 09:49 AM
Lukacs
p.1 #17 · Fujifilm GFX100RF Discussion and Image Thread
I like the camera aesthetic, design, also the RF style built, EVF, tilting screen, huge sensor. But this camera purpose is not for me. I like 35mm sensor format for low DOF with high resolution and sharpness. On high resolution I mean resolving 24MP at wide open with high quality lenses f1.2-f2.0. It seems MF for manufacturers is about only extreme resolution, not DOF control. Fastest MF lenses are f1.7, they don't want to fight with 35mm for shallower DOF. (Also a Fuji 55 1.7 is a nice option)
This camera is for resolution (will see how the lens performs corner to corner), you have 28mm eqv. 100MP for wall size prints. Of course there is the crop ability, but I'd never consider a 28-65 f3.2-f7,4 lens on 35mm ever. I'd go either Q3 (43), RX1RII, X100VI or a bunch of ILC option. Leica Q and RX1 has a good DOF ability, X100VI is an affordable solution.
Maybe there are photographers want a 100MP street camera, or a digital zoom street camera, but I'd grab a small FF ILC with a 35 or 50f2 lens or an X100VI instead (Q3s are way out of my budget).
I think an IBIS is a good thing, but also in my opinion consumers get too addicted, or just see a technical checklist, and the same applies on Sigma BF. This is a 35mm fixed lens camera (28mm on FF), who buy Sigma BF also quite unlikely to use longer than 50-65mm. It's truly so essential to have an IBIS on a 28mm camera? I shoot over 1/100s most time because people have a bad habit like moving (especially my kids), and for high resolution landscape or art we use a tripod anyway.
Mar 20, 2025 at 09:52 AM
Jun Zhou
p.1 #18 · Fujifilm GFX100RF Discussion and Image Thread
i will wait for another 5 years when version II is released with IBIS
Mar 20, 2025 at 10:01 AM
nehemiahphoto
p.1 #19 · Fujifilm GFX100RF Discussion and Image Thread
Nice but 2 fatal flaws for me.
- Needs IBIS
- This lens needs to be 2.8
I’d rather just shoot a Q3
Mar 20, 2025 at 10:06 AM
bwcolor
p.1 #20 · Fujifilm GFX100RF Discussion and Image Thread
Perhaps a relevant review regarding your decision:
?si=Lufk1s8aMCdpsvxR" target="_blank" rel="nofollow">Three Men and an Elephant
Mar 20, 2025 at 10:16 AM
       2       3              86       87       end
       2       3              86       87       end
