I'm sure there will be a shiny thread about this lens which was just announced.
I also see that the 35/1.2, 40/1.2 and 50/1.2 VM have all been redesigned (mechanically not optically) to have scalloped focus rings and black front bayonets which should please some users. I wonder if we will ever see silver variants of these or the APO lenses.
To be honest, I didn’t think this lens was even possible at this size. I'm very surprised Cosina was able to achieve this, and according to them, it will be a very high-performance lens with axial CA at 'zero' while striving to eliminate all other aberrations.
From the press-release: “The highest-performing wide-angle lens in Voigtlander’s history, optimized for the M-mount sensor with extremely high performance. The apochromatic lens is designed to minimize the axial chromatic aberration of the three primary colors of light, RGB, to zero, and to eliminate all aberrations in pursuit of the ultimate performance in terms of resolution and contrast reproducibility.”
Cosina mentioned that the lens will be equipped with 12 aperture blades but didn't specify if the mechanism will be similar to the Voigtlander 35mm f/2 APO-Lanthar, which also has 12 blades but features different shapes depending on the setting (circular aperture at f/2, f/2.8, f/5.6, and f/16).
Would like to see the data sheet / page. Sounds like a complex one, maybe four asph surfaces, 5-6 APD, maybe 14/11. F2 at 28mm is very nice with a close MFD. It's good to see them stretch their legs. The best Zeiss wide angles were 15/16 elements.
It's 12 elements in 8 groups according to their CP+ news page. They didn't yet specify the types of elements used.
Cosina didn't mention which special glass are used but the design is 12 elements in 8 groups.
The CV 35/2 APO-Lanthar VM is equipped with 11 elements (4 aspherical surfaces and 5 APD), so your prediction makes a sense.
Just for comparison, the CV 50/2 APO-Lanthar VM has 10 elements. (4 asph and only 2 APD)
Size wise, it's only a touch bigger/heavier than the VM Nokton 28mm f/1.5
Compared to the 28mm Nokton:
+ 15g heavier (265g Apo vs 250g for type 1 and 330g for type 2)
+ 1.6mm diameter
+ 4.5mm length
ø49 filter vs ø43 filter (ø49 matches the 35/50 apo)
Considering the diameter is nearly identical, I do think they could have added a focus tab. I appreciate the matching filter size, it will complement my 50 Apo for a 2 lens kit. If only the Apo Ultron was ø49 instead of ø52!
Looks very promising! Even if it's ONLY as good as the 35 APO, it will be an incredible achievement. The smaller size, especially the shorter overall length, is very welcome. The black nose is also a welcome improvement.
+ 1.6mm diameter
+ 4.5mm length
For those who own the CV 28mm f/1.5 Nokton VM Type II, the new lens offers a noticeable weight reduction of 65 grams. Apart from the added length, which may cause more viewfinder blockage, both lenses are roughly similar in size.
It looks like Cosina decided not to add a focus tab to the new 28mm f/2 APO to stay consistent with the other f/2 APO-Lanthar lenses, only changing the front section from chrome to black while keeping the overall aesthetics very similar. Personally, I like the chrome front, but Cosina must have received plenty of feedback to switch it to black...and they did.
It's intriguing everyone, the 28/2 APO. It will be a very popular lens by the looks of it, small and light and with no real competition in that space. A lot of interest from Leica people as well as other mount users, so maybe they can fast track those versions.
12/8 suggests they are moving away from the stack of stand alone elements, we see this with other manufacturers too working in the M-mount arena.
I guess their glass technology has progressed and it seems it's much harder to make high quality f1.4 lenses than the not so large step it took to be confident about reaching the APO performance level. It makes you wonder why it took so long if 28mm is not much more difficult than 35mm for such a a project. You would expect the multiple round apertures to be a fitting in this premium lens, to help with bokeh options.
At 265g, that is 40 grams lighter than the 35/2 APO in VM form. That weight compares with the latest Summicron-M at 257 grams and similar dimensions - it's a $4500 9/6 optic with an MFD of 0.7m. How will the new APO render, how different will it be? The 35/2 APO is four years old. Hopes are high, and they don't tend to brag.
Watching this one closely... I've been on the fence with 28mm options and this could be what I've been waiting for. Could pair nicely with my 50 apo.
Would be nice if the black ring on the front was made available for the 50mm. Not a fan of the mismatched look in the series. I wonder if its the same part, the diameter is same..
choijm0715 wrote:
Any news on when it will be released? I hope it comes out in the 2nd quarter
Cosina doesn't usually give any info on release dates of the new lenses that they pre-announce / introduce at CP+ at the show. Usually all those lenses will be released in the following 6-8 months one by one, starting from April at the earliest (could also start later). The order in which they will release the pre-announced lenses will also be up to guesswork... So basically have to wait for official announcements to come in the following months.
Since they will release Otus ML 50/1.4 in May (in Japan) in 3 mounts, I think they might also skip releasing any of the new CV lenses in the same month.
I think they might release only 1 or 2 of the newly pre-announced lenses in the 2nd quarter and the rest mostly in 3rd quarter.
