Thypoch got this lens out to a bunch of reviewers, what is being posted looks excellent and not just for the fact that its 7x less than the Summilux close focus. Looks like a really solid lens. Got rid of the infinity lock on this version and added a focus tab. Thypoch is much sharper at close focus than the Lux, but slightly loses out at infinity. 14 blades vs 11 makes those out of focus areas at f/2.8 much more pleasing on the Thypoch. Very interesting lens
I will be very interested in the micro contrast and color of the lens. I tried to 35/1.4 —the structural draw was smooth, and the sharpness was fine for me, I found a look at the files very muted and didn’t take processing well when pushed.
I love if it had some hot and we got a cheaper alternative to lens like the CV 50/1.2. That Lux is now quite old
My shop Camtec in Montreal received last week the 50 1.4 that I had preordered.
I am very impressed with this lens. I sold my Summilux some time ago because I did not like the field curvature that resulted in weakness in the outer areas.
I now have done two separate tests against my 50 APO M, a SL 50 Summilux, a 50 2.8 Elmar, and a 50 1.4 Milvus. These tests were both of a bookcase, at distances of 34" and 90".
The results astounded me. The Thypoch at f2, was equal to the APO 50 with only a very slight difference at the corners that could have been in the focussing. I really did not expect that.
It was slightly superior to the SL 50 Summilux in the outer areas with both shot wide open. I always thought the SL Lux was superior to the M as the field was flatter.
The Thypoch shows no sign of focus shift at all. CA is barely visible in my tests, with the exception of the Milvus which really surprised and disappointed me.
I really love the handling of this lens. The aperture ring has more resistance. It can be set and not accidentally changed. However when it is set to the click setting, the click can hardly be felt. It is a little to subtle.
The weight is identical to the 50 APO which is near perfect IMO.
I prefer the lens hood to the little APO 50 hood, and the metal cover cap is held on by magnets.
I choose the black finish and it looks perfect on my M-P 240.
It trounced the Zeiss Milvus and the Elmar.
I am pretty high on the Thypoch 50.
I am pretty high on the Thypoch 50....Show more →
I have to see these book case pictures that “astonished” you. Has to be a pretty special book case! 😀
50mm has a nice pop wide open, but you need to stop down f8 to get corner sharpness for landscapes on Kolari mod A7C, which matches to mtf graph as below. It doesn't have the Summilux midframe drop... In comparison, CV 50mm f2.2 is sharp wide open on A7C mod... There is still a hard stop at 70cm rf min focus distance which bothers me focusing on shorter distances...
That's very impressive and interesting, in equal parts. It's very cinematic to my eyes, and that's a look we need more of. I much prefer it to the Summilux in the main respects and it would not be a far distance lens in any event. Skin treatment is still very good, more images needed. But a very good start for the simmering Simera.
The palette is excellent, the 14 blades are a major benefit and the bokeh seems to stay preferable at near wide open. The MTF pattern is surely preferred for many compositions, the Leica lens and its mid-frame is an edge case, I think many might agree with that. The block design is very similar, but glass matching is very different.
If you draw a visual line at 18mm - the wide edge - the fall-off and vignette lying past that will be fine with many. It looks like a great cafe and indoor lens, easier to use. thanks.
Looks like Thypoch did a great job with this one, I'm interested as well. Their parent company, DZOFilm, has also been making some excellent lenses for the cine market, especially their T 1.4 16-blade Arles primes: https://dzofilm.com/products/arles-prime
I noticed B&H sells Thypoch cine lenses for Sony E mount, including a 75 T1.5... Wondering if we will see a 75/1.4 released eventually...
Doing some due diligience, some of the pre-release reviews spend half their air time talking about (and waving around) the Summilux 50mm, but once they settle down and show some images the talk melts away. A lot of them look a little downcast. This new one does not compete, it's certainly good enough to stand on its own substantial cinematic merits. Apparently this company actually listens to its customers and makes significant changes in a very timely fashion.
The best review for more imagery is Benj Haisch's effort, he actually called it:
'The Summilux For All of Us | Thypoch Simera 50mm f/1.4 Review'
Well, the last thing I want is the Leica lens they are rusted on to. But I can read MTF, and none of them appear to think that matters. All remark favorably on the build quality. The front drifts in and out on focus, a strange look. The Simera/Summilux designs may superficially appear similar, but are in fact very different when viewed side by side:
Also the other Summicron competitor is Ttartisan 50mm 1.4, which is at half price of Simera with a heavier/bigger size. It doesn't have the floating design and might not be as sharp in close shots, but it might be sharper for landscapes. Also it has onion/ninja bokeh.... So Simera is more corrected for shorter mfd/people shots...
The MTF is really best viewed as the pattern of performance, certainly not the level. But they surely know their glass matching, and here are some indications why that is so:
'The new Thypoch Simera-C (note:cine) lenses are a new series of compact and fast prime lenses that are small and very affordable...You may well think that it is somewhat of a strange name choice as..
*Thypoch already makes a range of lenses called Simera, however, these are essentially rehoused versions of those lenses that are being made by DZOFilm. Thypoch is actually a brand that is owned by DZOFilm.*
Here is what DZOFilm has done: Removed the depth-of-field indicator and focus ring resistance point.
The focus ring was moved to the front, the aperture ring to the rear, and industry-standard cine gears were added. The aperture blades have been increased to 16 for smoother, rounder bokeh.'
Yes, and they are light and sturdy, from a company that is well-established with four other ranges of cine lenses.
All ranges feature 75mm as the step from 50mm to 100mm, and the other main Simera-C is indeed a 75mm T1.5. This 75/1.5 is a 9/8 design for plenty of performance: with '75mm: 1 ASPH., 2 ED, 2 HRI' it will not be lacking and might be a winner for them if it makes its way into M/E/Z/RF, as any sane person would expect. Adorama is selling these C lenses for $880.
The C 75mm model has a filter thread of 72mm and weighs 470g. For comparison, Leica's Summilux-M 75/1.4 weighs in at 560g or 600g, uses 10 aperture blades; their 75/2 M-APO is 430g (for a stop down), it has an 8 blade aperture. And they are stills lenses.
All the C lenses feature 16 blade apertures for even better bokeh, up from 14 in the regular Simeras.
'The aperture blades have been increased from 14 to 16 compared to the Simera photography series, producing smoother, rounder bokeh and minimizing "onion rings" or irregular highlights. This natural and soft background blur enhances image purity and elevates the artistic aesthetics of every shot.'
Another interesting advantage they display over Cosina is that the stills Simeras released so far appear to not penalise the MILC mounts with massive percentage increases in weight. Taking the 28/1.4 as an example, they list as follows: 330g (M); 368g (Z); 353g (RF); 344g (E). Cosina's 50/2 APO grew from 290g in VM to 370g in Z-mount, just one of many examples of punishing MILC users unnecessarily.
PS the 75mm 'lux focus throw is 180 degrees, reported by Phillip Reeve's site.
I am using CV 75mm 1.9 a lot due to smaller size and shorter mfd in comparison to CV 75mm 1.5. It will be interesting if Thypoch can make it smaller for m mount. CV 75mm 1.9 is same size as Simera 50mm 1.4...
Other issue is the flare. I have not tested for that. Again Leica m lenses also are not perfect for that. There is a nice preview on film versions:
