This topic is in the 2022 archive. You can read it and like its posts here. It is read only.
Archive 2022Help: Sony 200-600mm lens focus issue: Show F---
stonebird
p.1 #1Help: Sony 200-600mm lens focus issue: Show F---
The 200-600mm lens was ordered two years ago when it was released and is rarely used. Just bought a 1.4x last week, want to test the effect, and found that the 200-600mm lens can not autofocus.
It shows F---, as shown below. Tested several other Sony lenses, no problem!
Has anyone encountered similar problems?
Thanks,
Gary
Apr 06, 2022 at 09:07 PM
tzhang4284
Details
p.1 #2Help: Sony 200-600mm lens focus issue: Show F---
I had this happen to me with a lens that I bought used that got damaged in shipping. It turns out that the aperture blades got misaligned and stuck that led to this mode - must be some sort of error mode.
I would suggest you look into the barrel and see if there are any odd misalignment issues. I ended up having to get the lens repaired (luckily the seller and I came up with some sort of amicable agreement). Maybe your lens sustained a drop somewhere along the way?
Apr 06, 2022 at 09:23 PM
Zayne12
Details
p.1 #3Help: Sony 200-600mm lens focus issue: Show F---
Did you try cleaning the gold contacts on the lens? Usually that can be an issue I've seen with a lens if mine. Just grab a qtip and wipe away at it l, that might be the fix you need.
Apr 06, 2022 at 09:29 PM
stonebird
Details
p.1 #4Help: Sony 200-600mm lens focus issue: Show F---
Thank you very much for your reply. This lens was bought more than 2 years, only taken out 2 times, the rest of the time in the moisture-proof box sleep. As far as I can remember, it has never been dropped, there has been no violent vibration.
Apr 06, 2022 at 09:36 PM
freaklikeme
Details
p.1 #5Help: Sony 200-600mm lens focus issue: Show F---
This, but a fresh pencil eraser works best, if you've got one of those curiosities of the dark ages hanging around.
Apr 06, 2022 at 10:00 PM
stonebird
Details
p.1 #6Help: Sony 200-600mm lens focus issue: Show F---
freaklikeme wrote:
Zayne12 wroteDid you try cleaning the gold contacts on the lens? Usually that can be an issue I've seen with a lens if mine. Just grab a qtip and wipe away at it l, that might be the fix you need.
Thanks very much. But I just tried it with an eraser, and unfortunately, it still doesn't work.
It seems that I have to contact Sony's service center.
Apr 06, 2022 at 10:27 PM
jeffbuzz
Details
p.1 #7Help: Sony 200-600mm lens focus issue: Show F---
Is the connection "F---" issue happening with only the bare lens attached to the camera? Or is this with the TC mounted? Did you clean all contacts including camera? Long shot I know if other lenses work OK. You might check if the lens mount screws are loose. JIS 3.0mm driver should be the correct tool size.
Apr 07, 2022 at 11:04 AM
