       2       3       …       5       6       end
Leofoto Quick Detach Strap - SP-01
Andrew2
p.1 #1 · Leofoto Quick Detach Strap - SP-01
Looks like Leofoto is going after the Magpul MS4 with their Quick Detach Strap - SP-01
I currently own the Magpul MS4 for my Nikon D850 with the RRS Modular L-Bracket. Had I known (had it been released then?) of the SP-01, I might have given it a look considering the SP-01 is $39 bucks vs. the Magpul's $59 bucks. That said, I'm extremely happy with my Magpul MS4 strap.
Thoughts? Here's a picture of the Leofoto SP-01 and the Magpul MS4...
Leofoto SP-01 Strap
Magpul Dual Sling Gen2 MS4 Strap
Apr 29, 2021 at 09:09 AM
sjms
p.1 #2 · Leofoto Quick Detach Strap - SP-01
as they are going after just about everyone else they can "emulate". its so much easier when someone else does the hard work of design.
Apr 29, 2021 at 09:26 AM
Andrew2
p.1 #3 · Leofoto Quick Detach Strap - SP-01
While that may be true, let's not pretend they are the only ones doing it. Everywhere you look there's a knock off of something. Even well known technology companies have been successfully sued for infringement
Anyway Leofoto can can claim being different from Magpul in the QD design. And it's not like Magpul has a lock on strap design. That said, I like the Magpul's simpler less pieces to brake design
Edited on Apr 29, 2021 at 10:51 AM · View previous versions
Apr 29, 2021 at 10:43 AM
sjms
p.1 #4 · Leofoto Quick Detach Strap - SP-01
with the exception of the tip diameter it is essentially a PMG design on the leofoto. not the best design to emulate to begin with.
that is irrelevant.
Edited on Apr 29, 2021 at 11:05 AM · View previous versions
Apr 29, 2021 at 10:49 AM
Andrew2
p.1 #5 · Leofoto Quick Detach Strap - SP-01
sjms wrote:
except of the tip diameter it is essentially a PMG design on the leofoto.
Not sure what you mean, but Is there a patent on "tip diameter"?
Anyway, as you know, but for others... I do have the Magpul; though I'm not going to lie and say I may not have gone Leofoto had I seem their offering... especially being a third less the price - $39 vs. $59.
That said, again, NO complaints with my Magpul. You got lucky on that suggestion
Apr 29, 2021 at 11:04 AM
sjms
p.1 #6 · Leofoto Quick Detach Strap - SP-01
its a simple situation. the design may or may not be patented and that is irrelevant. they, in this case, actually improved on the PMG usability/design.
the Magpul also has a the slider assembly which is their design too. i have a feeling they would defend their designs if they hold a patent
as to getting lucky, not so much. i buy on design, execution and functionality. that price differential is minimal. if i can purchase local i do.
Apr 29, 2021 at 11:17 AM
SSO-Images
p.1 #7 · Leofoto Quick Detach Strap - SP-01
I immediately thought of the PMG SS2 plug upon looking at the Leofoto strap image. It looks the same except for the tip. Comparing the two above, Leofoto's has the look of a camera strap proper whereas the Magpul has the look of its originally intended design, i.e., rifle strap that is repurposed as camera strap.
Personally, I like the PMG SS2 plug design, so I'm liking the look of the Leofoto's. I'll probably get one.
Apr 29, 2021 at 11:19 AM
sjms
p.1 #8 · Leofoto Quick Detach Strap - SP-01
everything is to taste. i actually prefer the ALG design, materials and execution.
Edited on Apr 29, 2021 at 11:36 AM · View previous versions
Apr 29, 2021 at 11:22 AM
SSO-Images
p.1 #9 · Leofoto Quick Detach Strap - SP-01
ALG design looks pretty good, too, first time seeing it.
I'm liking the Leofoto quick release system that comes with the strap. This, too, looks like a PMG copy:
https://www.amazon.com/dp/B088Q56BC1?psc=1&smid=A117K1DEQYNJIS&ref_=chk_typ_imgToDp
Apr 29, 2021 at 11:34 AM
sjms
p.1 #10 · Leofoto Quick Detach Strap - SP-01
actually RRS started that. i tried it. nifty as it was not needed still like my tripod scabbard. multifunctional.
Apr 29, 2021 at 11:41 AM
Andrew2
p.1 #11 · Leofoto Quick Detach Strap - SP-01
sjms wrote:
everything is to taste. i actually prefer the ALG design.
Why ae you so defensive and uptight? Good grief relax man
And BTW, even local, the Magpul price is still $59 bucks. I know because I found it at a couple of places in my area after purchasing it online (wasn't available at first locally). Even at the local base Exchange, the price is 59 bucks.
brad-man
p.1 #12 · Leofoto Quick Detach Strap - SP-01
Leofoto SP-01 + DC-22Q Strap & Clamp
I was watching this combo for $70. The seller sent me an offer for $60 for both strap & clamp, so I took it. All of my attachments are currently thru AS clamps, but I'm certainly willing to broaden my horizons. I'll soon see how good Leofoto's manufacturing abilities are. If they are as good as I hope, I may replace my Manfrotto 410 geared head with their G4 head. It looks very promising.
Apr 29, 2021 at 11:46 AM
sjms
p.1 #13 · Leofoto Quick Detach Strap - SP-01
and $59 it is. i not defensive its simply the the way i look at things and how i choose.
Apr 29, 2021 at 11:50 AM
Andrew2
p.1 #14 · Leofoto Quick Detach Strap - SP-01
They also use that design for the ridiculously expensive tripod strap - Leofoto Push Button Quick Detach Modular Tripod Strap 32LS.
That said, I wouldn't mind giving it a try if the price was a little cheaper. The other issue I have with that strap is the attached leg being spread apart. Yeah, you could tighten the leg but that's could be a constant battle. I question the design there.
Apr 29, 2021 at 11:51 AM
Andrew2
p.1 #15 · Leofoto Quick Detach Strap - SP-01
Wake up man; it's listed as a ripoff 59 bucks on e-bay but on Amazon it's $39 bucks.
And yes, you are defensive
Apr 29, 2021 at 11:54 AM
Andrew2
p.1 #16 · Leofoto Quick Detach Strap - SP-01
I just saw that same combo at B&H for $53 bucks - Leofoto SP-01 Push Button Quick Detach Strap & DC-22Q Clamp Kit
Edited on Apr 29, 2021 at 12:08 PM · View previous versions
Apr 29, 2021 at 12:07 PM
sjms
p.1 #17 · Leofoto Quick Detach Strap - SP-01
no i am referring to the Magpul.
the clamp is a RRS design. i have one of those for about 4 years for non QD plates.
i get the gear a choose when i need it. its a tool. nothing more nothing less. nothing to defend here. the only thing for me is the devils in the details. and i do details.
Edited on Apr 29, 2021 at 12:13 PM · View previous versions
Andrew2
p.1 #18 · Leofoto Quick Detach Strap - SP-01
Which post are you referring to?
Yeah, we feel the same; yet you seem to take offense with our choices or other choices available.
Edited on Apr 29, 2021 at 12:15 PM · View previous versions
Apr 29, 2021 at 12:12 PM
sjms
p.1 #19 · Leofoto Quick Detach Strap - SP-01
the DC-22Q clamp.
Edited on Apr 29, 2021 at 12:21 PM · View previous versions
Apr 29, 2021 at 12:14 PM
Andrew2
p.1 #20 · Leofoto Quick Detach Strap - SP-01
Got it.
       2       3       …       5       6       end
       2       3       …       5       6       end
