fredmiranda.com Login
This topic is in the 2020 archive. You can read it and like its posts here. It is read only.
Archive 2020Topaz DeNoise A1
Ontario55
p.1 #1Topaz DeNoise A1
Looking at buying Topaz Denoise A1 but I understand it doesn't recognize RAW files and thats all I shoot
True or False?
What are others using if not Topz Denoise A1?
TIA
Oct 20, 2020 at 01:25 PM
RoamingScott
[X]
Details
p.1 #2Topaz DeNoise A1
It supports exporting directly from LR as RAW and makes a tiff file for the edit that comes back into LR. Otherwise you’ll need to convert the file yourself.
My workflow is to do all edits to the raw file first in LR, then export from lightroom to do the sharpening and noise reduction as the final step in Topaz for the files that need it.
True or False?
TIA
Oct 20, 2020 at 01:28 PM
Ontario55
Details
p.1 #3Topaz DeNoise A1
So I would continue as is with importing into LR, editing and instead of exporting the finished file I would import it into A1 and remove noise and then back into LR and the export to a folder or when I'm done in A1 do I export from A1 to the folder on my desktop? Thxs
Oct 20, 2020 at 01:37 PM
Dougo
Details
p.1 #4Topaz DeNoise A1
Why don't you download the free trial and try it.
Oct 20, 2020 at 01:54 PM
Ontario55
Details
p.1 #5Topaz DeNoise A1
Gunshy- in the past I've tried 30 and 60 day trials of other products and trying to cancel out was next to impossible. If I get positive feedback I'll buy it outright .
Oct 20, 2020 at 02:00 PM
MikeEvangelist
Details
p.1 #6Topaz DeNoise A1
Ontario55 wrote:
...I understand it doesn't recognize RAW files and thats all I shoot
Think of Topaz as a near-final output step. Do everything you want to the image with your normal processing app, except for sharpening and noise reduction. Then send it to Topaz. As @RoamingScott already said, if you use Lightroom, the process is pretty well integrated.
Topaz can't fix every noisy image, but sometimes it is almost miraculous how well it works. Well worth what it costs.
Oct 20, 2020 at 02:02 PM
DaveFP
Details
p.1 #7Topaz DeNoise A1
You have to set it up as an external editor.
As above and then right click image - Edit In - Topaz.
When you close Topaz it will reappear in LR as a TIFF.
Oct 20, 2020 at 02:07 PM
RoamingScott
[X]
Details
p.1 #8Topaz DeNoise A1
Edit raw to your taste in LR > right click the image > Edit in Topaz > Do Topaz edits > Save in Topaz > Saved TIFF with all LR and Topaz edits appears back in LR > export from LR as usual
Oct 20, 2020 at 02:09 PM
Dougo
Details
p.1 #9Topaz DeNoise A1
Ontario55 wrote:
Dougo wroteWhy don't you download the free trial and try it.
No worries I use it in PS as a plug in, I do most things in ACR except sharpening and noise reduction which I take back to zero, with me it is the first step in photoshop I then add some small sharpening with Topaz in focus after I have downsized for the web.
Topaz de noise AI is a great piece of software.
Cheers Ray
Oct 20, 2020 at 02:10 PM
davev
Details
p.1 #10Topaz DeNoise A1
I do what Dougo does, but I can use it as a stand alone and it can read and open my raw files.
I use a iMac if that matters.
When I tried to save with 'Preserve Source Format' it saved it as a DNG.
Oct 20, 2020 at 02:48 PM
pjheller
Details
p.1 #11Topaz DeNoise A1
Cheers Ray
My understanding is Topaz recommends Denoise be used as the first step before any other edits.
Oct 20, 2020 at 03:25 PM
Paul_100A
Details
p.1 #12Topaz DeNoise A1
Cheers Ray
there are posts/videos (youtube and such) which seem to show 'it' doesn't matter at which step Denoise Ai is applied.
with regards to working from Lr...i might be concerned that when one applies Denoise Ai as a first step one is left with a resulting TIFF file, and not a RAW, file to continue working with. I don't know if a TIFF file is or isn't as 'pliable' as a RAW file. might be worthwhile to figure that part out.
Oct 20, 2020 at 03:41 PM
Dougo
Details
p.1 #13Topaz DeNoise A1
Cheers Ray
Hi mate, you are right and that is what I said convert raw to PSD take into PS and apply Denoise first step.
Oct 20, 2020 at 03:42 PM
RoamingScott
[X]
Details
p.1 #14Topaz DeNoise A1
It is my experience that I personally get better results editing the raw in LR first rather than the tiff last. YMMV.
Cheers Ray
Oct 20, 2020 at 04:33 PM
Hodie
Details
p.1 #15Topaz DeNoise A1
Anthony Morganti on YouTube says that DeNoise will work best if it has more pixels to work with. In other words, an uncropped version of your image. I do see the value of doing it as a last step from a workflow/convenience perspective.
Oct 20, 2020 at 05:04 PM
jbegis
Details
p.1 #16Topaz DeNoise A1
I just started the 30 day trial, and they didn't ask for my credit card or anything. So you don't have to deal with anyone to "Cancel". It will just stop working after 30 days unless you buy it
Oct 20, 2020 at 05:21 PM
hasenbein
Details
p.1 #17Topaz DeNoise A1
Every editing step where for instance shadows are lifted or contrast is altered potentially introduces new noise.
So IMHO it makes sense to apply the denoising as the last step of the whole editing process.
Followed only by perhaps removing/cloning out things (which should be always done last since potential artifacts shouldn't be amplified by any editing).
Oct 20, 2020 at 10:00 PM
pjheller
Details
p.1 #18Topaz DeNoise A1
Topaz sent me this link to share, so if you want 15% off on Denoise (or any other Topaz product), feel free to use this (Note: I have no affiliation with Topaz other than being a satisified customer).
http://topazlabs.refr.cc/pjh003
Oct 21, 2020 at 12:32 AM
somersettr
Details
p.1 #19Topaz DeNoise A1
Actually, Topaz Denoise AI can read Sony ARW files. Just drag and drop one onto Demoise AI. Save As offers to save the output as a DNG.
I don't know if that help anyone at all but I just thought it was worth pointing out that it can read raw files.
Oct 21, 2020 at 03:42 AM
BlueBomberTurbo
Details
p.1 #20Topaz DeNoise A1
I highly recommend not using Denoise AI on RAWs. At least if you use Adobe software. The image is completely changed beyond just NR. Contrast is dramatically reduced, and no camera profiles work anymore, or are even available to be selected (not even Adobe's own). Even if the profiles are generated from RAWs that already had Denoise NR applied to them (though the profiles still work on the regular images... poorly).
The other issue is that you're adding NR to an unedited image. Adding sharpening or even contrast will bring up more noise, but you can't predict what will happen when you're just in the RAW's base state. And adding NR on top of NR is never good.
Best to leave Denoise AI for the step right before resizing for output. For some higher noise image, you might want to add a hair of NR in your editing software, as Denoise AI can sometimes pick up noise patterns as actual patterns to save/enhance, instead of remove. For everything else, I just leave all sharpening and NR off, and the quality is amazing.
Oct 21, 2020 at 04:42 PM
