fredmiranda.com Login
This topic is in the 2020 archive. You can read it and like its posts here. It is read only.
Archive 2020Sigma 24-70mm DG DN internal dust?
MikeEvangelist
p.1 #1Sigma 24-70mm DG DN internal dust?
I saw a post on DPR the other day about heavy dust in a used Sigma 24-70 that the poster had bought. At first I dismissed it as another DPR-esque over-reaction. However, when I had a look at my copy of that lens I was rather surprised/disappointed to see quite a lot of internal dust. I've had the lens just since January, and this seems excessive to me. (I know it takes a lot more than this to affect the images. I'm thinking more of the long-term accumulation.)
Note that this dust is behind the front element/group, in the gap that changes size when the lens is zoomed.
Thoughts?
Any other owners care to peak inside theirs and report what you find?
My Sigma 24-70mm. How does yours look?
Aug 27, 2020 at 09:18 AM
wittyphrase
Details
p.1 #2Sigma 24-70mm DG DN internal dust?
In just took a look and I have some. If everything in your picture is internal then that's more than I've got. Don't know what's normal or not, though. I don't use zooms that much so this lens sees less use than my other lenses.
Aug 27, 2020 at 12:12 PM
Alan Parker
Details
p.1 #3Sigma 24-70mm DG DN internal dust?
I have one spec of dust in mine, but it's really quite small and there's really only one spot. I don't use it every day so it sees a lot less use than you guy's versions.
I'll try to keep an eye on it.
Aug 27, 2020 at 12:23 PM
nhsonyshooter
Details
p.1 #4Sigma 24-70mm DG DN internal dust?
...Show more →
Seems like a lot to me. I'd be sending it back to have them clean it.
Aug 27, 2020 at 12:29 PM
hesb
Details
p.1 #5Sigma 24-70mm DG DN internal dust?
I have had this lens this summer, and I had some dust inside also, which I found a bit disapointing since it is normally weather sealed. I don't have dust in my other lenses, even in 30 years old FD Lens!
Aug 27, 2020 at 12:35 PM
mogul
Details
p.1 #6Sigma 24-70mm DG DN internal dust?
I wonder if the accumulation of dust is indicative of fungus spore egress?
Aug 27, 2020 at 12:38 PM
MikeEvangelist
Details
p.1 #7Sigma 24-70mm DG DN internal dust?
Think I'll have to. Inconvenient, since I use it frequently, but that's life I guess.
Aug 27, 2020 at 01:44 PM
j4nu
Details
p.1 #8Sigma 24-70mm DG DN internal dust?
Yep, mine also has unusual amount of dust behind the front element, considering I have it only for a few months (I'll have to compare to my other lenses though). Still, I don't think it affects photos in any way...
Edited on Aug 28, 2020 at 10:07 AM · View previous versions
Aug 28, 2020 at 04:40 AM
jmcy
Details
p.1 #9Sigma 24-70mm DG DN internal dust?
I had one for a few months before selling it, used only for a handful of shots. There was some internal dust but just a few specks and not like the image you posted. I was surprised though because I used it so infrequently.
Aug 28, 2020 at 09:34 AM
teddoman
Details
p.1 #10Sigma 24-70mm DG DN internal dust?
I was planning on getting this lens eventually. That's quite a turnoff.
Aug 28, 2020 at 10:06 AM
lcfrs
Details
p.1 #11Sigma 24-70mm DG DN internal dust?
Me, too. Can someone comment on how it compares with 24-70GM and Tamron 28-75 in terms of internal dust?
Aug 28, 2020 at 10:32 AM
Gandalf2401
Details
p.1 #12Sigma 24-70mm DG DN internal dust?
Hello, I just found a description to clean the lens:
Aug 29, 2020 at 12:55 AM
sismailian
Details
p.1 #13Sigma 24-70mm DG DN internal dust?
Damn that's a major turn off as i was interested too. Even in that dust cleaning video the person says this lens catches dust 5 times as much. Now i guess we know where they cut corners to keep cost down.. noway i am opening a lens to clean. I rather take it to a pro.
Aug 29, 2020 at 02:10 AM
joychris
Details
p.1 #14Sigma 24-70mm DG DN internal dust?
I started that thread on DPR, it was pretty shocking how much dust had accumulated in the lens. I've spent a lot of time in some incredibly dusty environments with the Zony 16-35 and 24-70, more than a year exploring SE Asia, India, Africa, South America and Central America and they were much cleaner when I sold them for the Tamron 28-75. I plowed through sensor swabs when using those lenses because my sensor had crud the rocket blower couldn't remove - the lack of a rear gasket on the Zony's was the reason I moved on from them as other travel friendly alternatives became available.
I bought the Tamron right when it was released in 2018 and used it heavily until last fall when I picked up the 24-70 GM, almost all of its use was outdoors and it was completely dust free inside when I sold it back in January. I know dust really doesn't do much to an image, but I shoot a lot of video in bright sun so any extra artifacts are really difficult to work around. I also work in the humidity of south Florida, and if its that easy for dust to get sucked into that lens, I'm concerned about it long term. I decided to take a pass on the Sigma for now and repurchased a great copy of the Tamron here.
The zoom is more of a convenience for me since I shoot a lot of video. I just picked up the 24 GM and I'm looking at getting a couple more fast-ish primes similar in size/weight for a lightweight travel kit.
Cheers
Chris
Aug 29, 2020 at 06:33 AM
teddoman
Details
p.1 #15Sigma 24-70mm DG DN internal dust?
People love to read about a LensRental teardown but are probably terrified of actually doing one to an expensive lens they own.
Aug 29, 2020 at 07:02 AM
tdlavigne
Details
p.1 #16Sigma 24-70mm DG DN internal dust?
lcfrs wrote:
teddoman wroteI was planning on getting this lens eventually. That's quite a turnoff.
Just checked my GM that I've had since April 2018, 2 small specs of dust that I can see. I shoot a lot in the desert and dunes, so I'm surprised it's done so well.
Aug 29, 2020 at 07:37 AM
MikeEvangelist
Details
p.1 #17Sigma 24-70mm DG DN internal dust?
That looks like a relatively straightforward procedure. Good to know for the future.
Aug 29, 2020 at 07:40 AM
joychris
Details
p.1 #18Sigma 24-70mm DG DN internal dust?
teddoman wrote:
Gandalf2401 wroteHello, I just found a description to clean the lens:
I’m fine with home construction and auto repair or modifications, but I’m not too keen on the idea of cracking open a lens a couple times a year to clean it. It’s just one tiny slip from a B&S ad that says “I accidentally scraped the inside of the front element trying to clean it, the scratch only shows up in photos when there’s light present. $300 obo” 😂
Cheers
Chris
Aug 29, 2020 at 08:22 AM
MikeEvangelist
Details
p.1 #19Sigma 24-70mm DG DN internal dust?
Been there.
Aug 29, 2020 at 08:23 AM
Hodie
Details
p.1 #20Sigma 24-70mm DG DN internal dust?
I don’t have this lens but the new 100-400. I’m hoping that lens is a bit more dust resistant.
Aug 29, 2020 at 10:09 AM
