       2       3       4       end
Archive 2019 · Nikon 85 1.8S vs 105 1.4E Results
aerospace99
p.1 #1 · Nikon 85 1.8S vs 105 1.4E Results
Wondering if anyone can comment on how these 2 lenses compare for general portraits. Besides the obvious difference in FL, are you seeing that the 105 deserves its price premium when compared to the 85? I have been impressed with what I have seen so far from the 85 but cannot see having both. I first would have to acquire a Z7, but would not rule out swapping out the 105 for the 85 as I have the 70-200 FL as well. I just find the 105 a bit tight at times, and I rarely shoot it wide open as it can be just a tad soft at 1.4, but its capable of some great shots. Just wondering if anyone else sold off the 105 in favor of the 85. I really think I would get more use out of an 85 but I know that the 105 is capable of some very special looks. My plan would be to keep my 70-200 pretty much fixed on my D810 and use the Z7 for the 35/58/85 trio. I really am trying to avoid having too much glass and like I said, would rule out having both.
Nov 09, 2019 at 06:29 AM
AcuteShadows
p.1 #2 · Nikon 85 1.8S vs 105 1.4E Results
85 S has smooth, but a little bit timid bokeh, probably due to the smaller front lens. 105 E has lively, bold bokeh, but a little bit of chromatic aberration. The larger front lens and the wider maximal aperture help with the bokeh characteristics, also at f/1.8 (or f/2.8, for that matter). Nobody will complain about photos taken with the 85 S, but your chances of getting people excited about a photo are much larger with the 105 E. The 105 E is more challenging to build, so it's more expensive. I have the 85 S and skipped the 105 E, because I've got three fast 135mm lenses. But every once in a while, I'm thinking about swapping two of those for the 105 E.
Edited on Nov 10, 2019 at 08:43 AM · View previous versions
Nov 09, 2019 at 07:21 AM
Coltrane
p.1 #3 · Nikon 85 1.8S vs 105 1.4E Results
I've seen many photos taken with both of these lenses and to me there is a huge difference in how they render. It's not the focal length as much as they difference between 1.8 and 1.4. I personally think the price premium of the 105mm is certainly warranted. But the fact that you actually asked this question leads me to believe you might be more satisfied with the 85mm 1.8 in the long run.
Nov 09, 2019 at 08:42 AM
umsl12
p.1 #4 · Nikon 85 1.8S vs 105 1.4E Results
I don't have 105/1.4 but I love my 85S a lot! I like it even better than 50S.
Little bit to pixel peeping but Ricci's review may help you make your decision.
For me, I go with native lenses whenever possible.
https://youtu.be/PhUnZ49hF1c
Nov 09, 2019 at 10:45 AM
MayaTlab
p.1 #5 · Nikon 85 1.8S vs 105 1.4E Results
AcuteShadows wrote:
85 S has smooth, but a little bit timed bokeh, probably due to the smaller front lens. 105 E has lively, bold bokeh, but a little bit of chromatic aberration. The larger front lens and the wider maximal aperture help with the bokeh characteristics, also at f/1.8 (or f/2.8, for that matter).
I don't think that I've ever read actually knowledgeable people establish a direct causal relationship between the size of the front element and bokeh.
Nov 09, 2019 at 10:46 AM
Ripolini
p.1 #6 · Nikon 85 1.8S vs 105 1.4E Results
Me too. Unless we consider the maximum aperture, which depends on the size of the entrance pupil, which in turn is related to the diameter of telephoto lens front element.
Dr. H. H. Nasse (Carl Zeiss - Camera Lens Division) wrote on 2010:
" ...rules about bokeh: • Some caution is advised when making judgments about the bokeh depending on the lens correction, because bokeh is extremely variable. • The correction balancing has an especially strong influence on the blurriness of the rendition at small deviations from the focal point. If there is a lot of blurriness, it usually becomes more and more negligible. • The aperture has a strong influence; even closing the aperture a small amount can cause very visible changes to the nature of the blurriness. Slower prime lenses generally have smaller spherical aberration by nature. So it is no wonder that their bokeh is praised for its appeal. • The spherical aberration of a lens also changes depending on the imaging scale. Bokeh characteristics therefore depend on the focusing distance as well."
Nov 09, 2019 at 11:30 AM
AcuteShadows
p.1 #7 · Nikon 85 1.8S vs 105 1.4E Results
Consider a medium format lens with the same focal length as a full format lens. Then, generally, you will have less vignetting. The vignetting characteristics of a lens also impact the bokeh. And larger front lenses generally result in less vignetting. In the end, all depends on the complete optical formula, of course.
Nov 09, 2019 at 12:58 PM
BSPhotog
p.1 #8 · Nikon 85 1.8S vs 105 1.4E Results
Should we complicate things further and add in the Sigma 105 Art? I picked up a refurbed unit from Sigma for $1200
Nov 09, 2019 at 01:53 PM
MayaTlab
p.1 #9 · Nikon 85 1.8S vs 105 1.4E Results
But then that can't simply be caused just by enlarging the front element, otherwise the MF lens would struggle to produce a decent image on a MF sensor in the first place, no ? It's probably because the entire lens has been designed for a larger format that it theoretically vignettes less, no ?
Yep.
So we're back to square one, basically. It "all depends on the complete optical formula", and the front element isn't the direct cause for it. I'd be surprised if vignetting arose just because of one single element on most lenses. This is not something I grasp well, but wouldn't that result in significantly asymmetrically cut bokeh balls in the corners across the tangential plane ?
Perhaps a good idea would be to actually evaluate both lenses vignetting under various parameters instead of throwing around dubious causes for it and possibly wrong presumptions as a result ?
Nov 09, 2019 at 04:23 PM
AcuteShadows
p.1 #10 · Nikon 85 1.8S vs 105 1.4E Results
Optical formulae that result in less vignetting often show a more lively bokeh. In order to achieve less vignetting, the front element generally has to be larger, lest it become the bottleneck for the whole formula. Thus, I used the language "larger front element" as pars pro toto for a lens with less vignette and thus more lively bokey. (Whether the bokeh is smooth is another matter, often more vignette means smoother bokeh.)
"Here, what impacts the shape is the physical size of the front and rear elements, the length of the lens barrel and the size of the aperture." https://photographylife.com/what-is-vignetting
Yep.
...Show more →
Nov 09, 2019 at 05:00 PM
MayaTlab
p.1 #11 · Nikon 85 1.8S vs 105 1.4E Results
Nov 09, 2019 at 05:20 PM
AcuteShadows
p.1 #12 · Nikon 85 1.8S vs 105 1.4E Results
MayaTlab wrote:
By "lively bokeh", I mean larger bokeh balls of specular lights, although the balls edges can be somewhat unruly.
By "smooth bokeh", I mean bokeh balls that are generally smaller but have smoother edges.
These characteristics translate into bokeh in general, they are just more easy to see with out-of-focus specular lights.
Nov 09, 2019 at 05:37 PM
Dj R
p.1 #13 · Nikon 85 1.8S vs 105 1.4E Results
I’ve had both. I did sell my 105e when I got the 85s. But I only own Z bodies, now.
I didn’t end up keeping the “better lens”. I kept the better “every day lens”
I decided to go with the best lens for me, right now. And that is the lighter, faster focusing lens, which happens to balance much better on the Z’s and be a more comfortable and more versatile focal length (for me).
I have owned the 105 a few times and it will always be a legend to me. Until I get a 85 1.2 or 85 1.4 or 50 1.2 S - I’ll miss the 105.
Edited on Nov 09, 2019 at 10:25 PM · View previous versions
Nov 09, 2019 at 07:38 PM
Lance B
p.1 #14 · Nikon 85 1.8S vs 105 1.4E Results
I have both the 85 f1.8S and the 105 f1.4E. In reality, they are different lenses, different focal lengths for different scenarios. Yes, at a pinch you can probably use one or the other but if you need 85 you need 85 and if you need 105 then you need 105 or if you need f1.4 you need f1.4. However, I guess they are close enough in focal length to be sort of interchangeable. For the moment, I am keeping both because I think I can get more isolation with the 105 at the right distance to get enough DOF and great bokeh at that distance.
I did a bit of a fun "comparison" a few days ago, but these things can never be the perfect comparison as there are way too many variables. If I set them both wide open than that really isn't a fair test as the DOF of the 85 f1.8 is greater than that of the 105 and you really need to equalize the distance to get the same image size etc which throws other issues into the equation. Whatever the case, I really do not like to do comparisons as there are way too many variables and if you are off in focus by just a bit then the comparison is void and your test always gets holes picked in it by those with an agenda or think I have an agenda. Whatever the case, I have no reason to favour one lens over the other other than I *want* the 85 to be as good or better than the 105 as it means I can sell off the 105 and keep the lighter cheaper lens. However, I have yet to see that the 85 is actually better (or worse) they are just different.
I have some absolutely stunning shots of my grandson that I took with the 105, the light was perfect and the overall IQ is just incredible, but the bokeh is amongst the best I have ever seen, so smooth and creamy. The shots were at that perfect subject to camera distance and the background was also at the perfect distance where it all just came together for superb results. I used various apertures from f1.8 to f4. Unfortunately, I don't share photos or friends of family on the net and any tests I do and share are of inanimate objects. I really want the 85 to be able to replicate those photos and I hope to get to take similar photos in those "perfect" conditions.
Anyway, these were taken one afternoon when I was bored and just fooling around. This is in no way meant to be a test or a proper comparison, just a couple of photos comparing the 85 f1.8S @ f2.5 to the 105 f1.4E @ f3.2, adjusting the apertures to give similar DOF for each. Both shot in my computer room with afternoon light in through the window to the right. I tried to keep Tigger the same size in each photo and I did remarkably well considering I did these handheld. The WB for both seemed to change on the EVF even when I was taking them, you could see the difference with the lens change. The 85 f1.8S ended up with a much bluer WB than the 105. After I adjusted the WB of them both in post process in Capture One Pro, the histograms were very similar and differences may be attributed to the fact that the different perspective of 85 to 105 meant that there was slightly more background in the 85 shot. I altered exposure, WB, saturation and levels applying the same to one as the other. In other words, WB from the camera was different for each lens, but I set the same WB is post process the same for both and the histograms ended up almost identical albeit for the slight difference in the amount of background and thus the very slight difference in each color channel in the histogram.
These are near the minimum focus distance, *about* 1.4mts for the 105 and *about* 1.1mts for the 85. At this distance they are very similar, not seeing a clear advantage of one over the other as far as sharpness of bokeh or CA, but then CA is automatically corrected via Capture One and the Nikon lens correction algorithms that they use.
The wall behind Tigger is only about 200mm (8-9") behind him so, this will have a bearing on how the bokeh will look. I do believe that Nikon would design each lens to have optimal bokeh (within the limits of lens design) to be best at certain camera to subject distances and background distances depending on the focal length and the aperture.
I focused on the same spot, the closest eye and thus the DOF etc should be almost identical, which it appears to be.
This was also posted in the 85 f1.8S image thread.
Anyway, all a bit of fun.
Z7 + 85 f1.8S, 1/50s f/2.5 at 85.0mm iso64
Z7 + 105 f1.4E, 1/30s f/3.2 at 105.0mm iso64
Nov 09, 2019 at 10:19 PM
charles.K
p.1 #15 · Nikon 85 1.8S vs 105 1.4E Results
Very nice examples Lance
I always remember Nikon for the 105mm portrait lenses even with film. The 105mm give you a unique compression, harder to squeeze for indoor shoots but the look at f/1.4 and 105mm is well worthwhile if you are into portraits. It is like the 200/2 that gives you that truly unique look and I would love to own one of these
That said the 85 FOV is a better workhorse lens, more adaptable. I do not own the 85/1.8 S... yet but I will eventually. My logic is I will sell of my 85/1.4G and 85/1.8G for the 85/1.8 S.
I still think one of the best workhorse portrait lenses is the 70-200E as at 200 @f/2.8 the compression is similar to that of 105 @ f/1.4 and gives a great amount of flexibility for portraits shoots with very fast AF.
Nov 10, 2019 at 01:34 AM
Kry27
p.1 #16 · Nikon 85 1.8S vs 105 1.4E Results
Hmmm, I should remember not to open such threads. Still saying my 85/1.4D won't go. No.
Nov 10, 2019 at 03:24 AM
aerospace99
p.1 #17 · Nikon 85 1.8S vs 105 1.4E Results
Some really good responses here. After posting I considered why I bought the 58 and 105 to begin with and think I would be crazy to unwind that position. The whole thing was started by my desire to get the Z7 as a second body to go with my D810. The idea of having a native lens is attractive but not compelling enough at this time. I demo'd the Z6 and do not find the FTZ to be a big problem. The idea of having the slight autofocus nits of the 58 resolved by the Z7 is promising. If I did not have the 58 then the decision to drop down to the 85 would be a lot easier here. Also, I find the 105 to be capable of the exceptional shot which in the end always beats out utility in my book. For me, this is the critical component of the decision. I see the advantages of the 85 in a lot of situations but I am wondering if I would give up too much of the character I love in the 105. I probably will just wait until I actually get the Z7 to consider this further. I also need to evaluate what the 58 on a Z7 really looks like. The theory that the 58/105 pair can eliminate the need for an 85 is valid. Having a 58 and an 85 and a 105 and a 70-200 is just a bit too much for my needs. I probably will have to do some comparisons with all 3 lenses at the same time to get a handle on this difficult decision. The idea of the 70-200 FL taking up the slack here is plausible but I just got through reviewing some shots of kids on a big tree swing in the shade and the extra 2 stops of the 105 made a huge difference. I love 2.8 zooms but for me at least they all deliver a certain mediocrity in a lot of situations so I cannot lean to heavily on that. No, I am staying pat for now, will plan on getting the Z7 and see what shakes out after that.
Nov 10, 2019 at 07:20 AM
charles.K
p.1 #18 · Nikon 85 1.8S vs 105 1.4E Results
...Show more →
Smart move I have just acquired 2 Z6's trading in my D850/D750 and just using the FTZ adapter. I really do not understand the fuss as it works really well with all of my lenses. Sure I will acquire some natives but for now it is great.
Nov 10, 2019 at 04:48 PM
umsl12
p.1 #19 · Nikon 85 1.8S vs 105 1.4E Results
Everyone is different.... but for me, the difference between IQs of FX lenses and their equivalent Z lenses is neglectable compared with sizes between having FTZ and without FTZ adaptor. I sold the adaptor because I felt it's bulky. Not only enjoy IQ, I also enjoy the compactness and small form factor of mirrorless Z system.
Have I wanted excellent Nikon F lenses without any compromise, I would have stayed with Nikon FX DSLR and native FX lenses like 58 and 105 1.4 G. I don't see any reasons to buy Z cameras and FX lenses then use adaptor for them (especially when start from scratch), unless if I had a tons of good FX lenses that I didn't want to get risk of them.
I'm having Z 35S, 50S and 85S .... I'm waiting for Z 105 (or 135mm) 1.4 or 1.8S. Please make it, Nikon.
Nov 11, 2019 at 01:20 PM
umsl12
p.1 #20 · Nikon 85 1.8S vs 105 1.4E Results
https://pbase.com/lance_b/image/170003266/original.jpg
https://pbase.com/lance_b/image/170003268/original.jpg
I can't justify the different costs between these two lenses at all. Thank you so much for the test!!. I'm happy to use the $ difference to get APSC Z50 and make my 85S become ~135mm equivalent :-) when I need this FL, and it would provide me enough blurry background for me.
Nov 11, 2019 at 01:32 PM
       2       3       4       end
       2       3       4       end
