naturephoto1 wrote:
realVivek wrote
I will take out my ZM 35 when there is no rain and check it out.
Rich, As I said (check with Kolari to confirm what I said), they can not remove the cover glass. Only NKIR will do it commercially.
naturephoto1 wrote
realVivek wrote
Rich, See the addition/correction to the earlier post.
The cover glass on A7 series sensors is 0.7mm thick. That plus 0.8mm (in your A7R mod) makes it 1.5mm.
To get 0.7mm, the cover glass has to be removed completely and cleanly. I do not think Kolari have the capabilities. Only one person from Taiwan (NKIR) does it commercially (as posted here a while ago).
Daniel @ monochromeimaging did a mod removing the cover glass for Dan (“thrice”). Unfortunately, that was not clean and had some glass debris that comes from the glass cutting/grinding. OK. Thanks for the correction. Even 1.5mm is 1mm thinner than the stock 2.5mm. So, I guess that I live with what I have and just learn to live with stopping down my fast glass Zeiss 35mm f1.4 ZM to about f2.8 or so. My Minolta 28mm f2.8 M-Rokkor I have found that I can get by with f5.6 or better f8. My Minolta 40mm f2 M-Rokkor I think should be OK by around f4 but will do better still at f5.6 or f8. My Leica 24mm f3.8 Asph. I think I am OK at f4 or f5.6. My Leica M WATE does OK on my stock camera at or by f8 but should do better on the A7r V3 probably around f5.6. Both the 35mm ZM and the 24mm Asph lenses need to be corrected with Corner Fix so I use them less often, but...
Rich I modified what I posted so you might review what I posted. It could be worth my having Kolari replace the Thin Sensor glass with the UT sensor glass in the future. I may want to talk with Ilija about this. It may not be as thin as yours, but it may be something to consider.
Rich
I just called Kolari but did not speak with Ilija since he was not in. But, they checked with the technician and they indicated since they installed the V3 cover they would have no problem in getting it out and replaced with the UT cover. It is just going to be expensive at $400 plus shipping. I think that I could get $10 off of the price. Color correction could either be done in camera or custom white balance.
Rich
