rvh23 Offline Upload & Sell: Off
wind30 wrote:
Mine is weak on the right TOP at 24mm f2.8.
Do u have samples at the Long end for all 4 lens for comparison?
I am thinking if I should try another copy. It is perfect at f5.6... i probably should not as I don’t require corner to corner sharpness at f2.8. Just bugs me that my copy might not be so good.
It’s very good at 14mm. The dencetering shows up at 18mm onwards
Having said that the weak TOP right corner at f2.8 is as sharp as my Sony 12-24mm at f4. Basically the weakest corner of the sigma Beats the Sony hands down at same aperture.
...Show more →
I don't have side by side comparison for all 4 copies, but if you look at the initial copy I reviewed in the "first impressions" thread, you will see that even for the weakest corner at the long end, astro performance was just fine, and that's the main application I want sharp corners for wide open. Maybe test yours for that as well if you shoot astro?
Otherwise, if your copy is good from 5.6 onwards, it sounds fine. Looking for a better centered copy is more theoretical than practical in that case, and might take a lot of copies or good luck.
Below are the four corners of the best copy I've tried, and which I may well end up just keeping. This was focused for best balance across the four corners. I can get better left side performance in particular with this copy, but at the expense of the right side.
First image shows 100% crops from 61MP with minimal default CR sharpening, second one shows the same but resampled to be equivalent to 42MP capture for comparison with previous tests.
61MP
...resampled for 42MP
Edited on Sep 19, 2019 at 10:34 PM · View previous versions
