fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
chiron
p.1 #1New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
In the first comparison of these lenses, in another thread--link below-- the Sony FE 50mm 1.4 ZA was preferred by most--but not all--viewers to the Canon EF 50mm 1.2L.
https://www.fredmiranda.com/forum/topic/1604454/0#14910583
I was a bit surprised by the results, so I decided to do an additional comparison of the same lenses under different lighting conditions. I was going to attach the new comparison to the original thread, but then I couldn't re-do the poll and there would be no count of which lens was preferred
Please don't try to guess which is which, but rather to observe and comment on the rendering by the two lenses. I hope that this will be more useful in thinking about each of the lenses and also that it will avoid any sense of being right or wrong about a guess.
The images were taken on an a7r3, on a tripod, steady shot off, mechanical shutter but electronic first curtain was on, lenses shaded, no filters on lenses, 2 second delay on shutter release. The day was sunny with no clouds. There was light breeze. The shots were all made within about 4-5 minutes. The Canon was on a Sigma MC-11 adapter with current firmware. No adjustments were made in Lightroom except that the Lens Profile for each lens was used. The box for correcting chromatic aberration was unchecked.
Focus is on the tree trunk.
Edited on Jul 19, 2019 at 08:46 PM · View previous versions
Jul 18, 2019 at 06:07 PM
chiron
Details
p.1 #2New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
© chiron 2019
Lens 1 50mm at f/1.4
© chiron 2019
Lens 2 50mm at f/1.4
© chiron 2019
Lens 1 50mm at f/5.6
Lens 2 50mm at f/5.6
Edited on Jul 18, 2019 at 09:19 PM · View previous versions
Jul 18, 2019 at 06:11 PM
vdo1
Details
p.1 #3New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
I’m not playing until you turn EFCS off. First photo, out of focus bush to the left - the effect is so pronounced that it obliterates the native character of the lens bokeh.
OTOH the main attraction for me is to guess the lens. You know that I quickly and correctly did it the previous round (although I had the decency to do it on PM as to not distract other posters - and I’m willing to continue to be decent ). If you’re taking that little guilty pleasure away, I’d rather go swimming lol.
P.S. based on the EFCS images, and without knowing that the lenses are Canon or Zony, and without mentally trying to subtract the EFCS effect, I would have identified Lens 1 as a Plasmat or Helios or one of their cousins.
Jul 18, 2019 at 06:39 PM
chiron
Details
p.1 #4New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
...Show more →
I think it's more likely you're seeing the effect of the breeze. But if it concerns you, just compare the shots at f/5.6.
Jul 18, 2019 at 08:21 PM
vdo1
Details
p.1 #5New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
chiron wrote:
vdo1 wroteI’m not playing until you turn EFCS off. First photo, out of focus bush to the left - the effect is so pronounced that it obliterates the native character of the lens bokeh.
OMG. EFCS + breeze. What am I supposed to do here, show a preference over their combined effect?
Now seriously. I’d like to see a “controlled test” i.e. one where you change only one variable between the shots. The lens.
Jul 18, 2019 at 08:28 PM
hiepphotog
Details
p.1 #6New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
I didn't even look at the f/5.6 shots since I'm not sure why it's important, especially for the L 50/1.2, where most of its "magic" disappears. I personally prefer lens 2. It's hard to spot the sharpness difference this time since the focus point is further and size is small. But if I really look at it, lens 2 has more bites as well. Good thing this one is not about which one is more 3D . Personally, I'm not surprised by the result last time. Maybe you want to ask the same thing in Canon room to see if it will be different.
Jul 18, 2019 at 08:38 PM
numbertwo
Details
p.1 #7New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
Did you use AF or manual focus? The canon 50 1.2 has some focus shift, and if focused with AF at 1.2, then take the picture at 1.4, there might be a bit of back focus, but at this distance I don’t think it would be too evident anyways.´
At 1.4, lens 2 looks much better: better sharpness, less funky bokeh, 0 spherical aberration, much less coma, etc.
However, the lens 1 shows more dimensionality, maybe because of some field curvature, the center of the frame behind the tree looks more out of focus than in lens 2, and this spherical aberration gives an extra “fog” (less contrast) to the background that makes the foreground pop up more. So for portraits, I can see hoy lens 1, at 1.4, could give more interesting results.
At f5.6, it’s very difficult to tell differences in my iPad screen without pixel peeping, maybe still the whites are a bit brighter in the picture one, and still looks with a tiny bit more depth (because the center part behind the tree still looks a bit more oof And with less contrast)?
Jul 18, 2019 at 08:42 PM
lunar module
Details
p.1 #8New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
I think you got your labelling wrong on the second image. Says f/5.6. I think you meant f/1.4.
I prefer the bokeh of lens 2 at 1.4. The yellow flowers and the leaves on the bush on the left look a bit funky to my eye on the lens 1 image but good on lens 2.
The background is slightly more defined on lens 2 at f/5.6.
I prefer lens 2, but the 3D pop of both lenses at both apertures is quite impressive.
Jul 18, 2019 at 08:44 PM
DaveFP
Details
p.1 #9New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
...Show more →
Yep; These lenses are optimized to shoot at or near wide open.
My guess is that comparing them at smaller apertures is irrelevant for most users most of the time.
Jul 18, 2019 at 09:01 PM
chiron
Details
p.1 #10New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
Well, actually, now that I think about it, the shutter speed was fast enough at both apertures to obviate the breeze. I'm in the Mark Galer camp on EFCS--that the difference it makes to bokeh is more a matter of taste than of right or wrong, and he geneerally prefers EFCS-on bokeh. But when I get a chance, I'll add some images with it off. However, I don't think it will be this weekend--too hot in NY.
Jul 18, 2019 at 09:02 PM
hiepphotog
Details
p.1 #11New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
This will be more fun if the Canon is the RF one. I would take that one over the ZA any day, though not for some vague Canon magic dust.
Jul 18, 2019 at 09:14 PM
chiron
Details
p.1 #12New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
...Show more →
I think this is a very accurate read. Lens 1 has more spherical aberration, which is part of its design, and it is not noted for its sharpness but for its rendering. I did use AF focus.
Jul 18, 2019 at 09:17 PM
philip_pj
Details
p.1 #13New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
Lens 2 is preferable here, in both sets: in set 1, better depiction of either sharp or bokeh content. Lens 2 has better foreground bokeh (set 1). Lens 1 looks lost in a sea of fuzziness and edgy bokeh (set 1). Lens 2 color/tonality better integrated. Lens 1 (set 1) looks fuzzy/harsh in bokeh content, whereas Lens 2 has better edges of house window frame, brown posts, etc. Garden colors are more 3D, road is more road coloured. Lens 2 has better hue separation (garden). Better small purple flowers, stronger yellows, deeper greens. Lens 2 is more 'pictorial' and has handled the contrasty scene well. Highlights are not a strong point for Lens 1.
Having said all this, the scene is far from what these lenses are designed for, and personal preferences play a big part in responses. [Lens 2 50mm at f1.4 (perhaps) mislabelled as f5.6.]
Maybe you can post snips of the histos, as they often have a story to tell about the gradation of tones through the range and pixel distributions in peaks. cheers.
chiron
Details
p.1 #14New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
Yes, thanks, caption fixed.
Jul 18, 2019 at 09:21 PM
chiron
Details
p.1 #15New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
EF not RF, as noted in OP.
Jul 18, 2019 at 09:24 PM
hiepphotog
Details
p.1 #16New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
chiron wrote:
hiepphotog wroteThis will be more fun if the Canon is the RF one. I would take that one over the ZA any day, though not for some vague Canon magic dust.
That's why I said if
Jul 18, 2019 at 09:33 PM
vdo1
Details
p.1 #17New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
Beyond personal preferences re bokeh - and according to Sony’s literature, EFCS side effects would affect adapted lenses more visibly than native ones, so maybe it was altering the rendering (as to make the lens unrecognizable by themselves, vs historical photos) but also accentuating the difference between the adapted vs native one, thus giving us additional clues over which is which from the stated candidates.
Jul 19, 2019 at 04:15 AM
milkod2001
Details
p.1 #18New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
At 1.4 lens 2 has IMO slightly better and smoother bokeh (i'm judging by leaves on left part of images).
Foreground tree seems to have the very same sharpness. Contrast, colours and overall rendering seems way too close to make a clear winner here.
If i had to pick one of those, it would be Zeiss 50 1.4 as it has native AF.
Jul 19, 2019 at 06:24 AM
chiron
Details
p.1 #19New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
Interesting point, and may be.
I have read the Sony lit on this in the online Help guide, but it hasn't been a problem that I have noticed. I will try to do some samples with and without EFCS. But we are going to have three days of heat warnings here in NY, so I love being inside and air conditioned at the moment. It will be very interesting to me if the EFCS comparison shows a significant effect on the Canon lens since I have a number of Canon lenses that I adapt and like to shoot with.
Mark Galer has a very interesting discussion of EFCS in a fairly long video, which includes a number of adapted lenses on a Sony 7 series body. He went through his Lightroom catalog looking for examples of EFCS "problems," which are usually described as either creating some uneveness in exposure or as affecting the bokeh. His conclusion on the issue of uneven exposure from EFCS is that he could only find one example of the problem out of many images shot with EFCS at high speed and wide aperture, and that was at 1/8000 of a second. His conclusion on the issue of Bokeh and EFCS, following the same search through his catalog, is that EFCS gives slightly more structure to the bokeh in a way that he personally prefers and that he thinks produces greater image clarity. He also thinks that the differences between bokeh with EFCS on and off are very slight and hard to pick up in real images. He says he leaves EFCS on almost all the time because of its real advantages in shooting and that he likes to shoot and often shoots at maximum aperture, including with adapted lenses.
Here is a link to the video. The bokeh discussion begins at 19min:
http://www.markgaler.com/e-front-curtain-shutter-switch-it-off-or-leave-it-on
Jul 19, 2019 at 07:03 AM
Admin
Details
p.1 #20New Images Comparing Sony 50/1.4 & Canon/1.2L EFCS/No EFCS
Mark Galer
...Show more →
Wow, I love Mark's reviews but disagree with him here. EFCS + faster lens wide open + shutter speeds > 1/2000s degrades rendering substantially to the point that this ill-effect is easy to spot even in resized images.
For side by side tests like this, one can just use 'silent shutter' and avoid the issue. (plus it saves your shutter. )
https://www.fredmiranda.com/forum/topic/1443700/7#13668929
Which lens do you prefer?
Jul 19, 2019 at 07:13 AM
