fredmiranda.com Login
This topic is in the 2018 archive. You can read it and like its posts here. It is read only.
Archive 2018Contax 35-70/3.4 is ruining me.
Michael Everet
p.1 #1Contax 35-70/3.4 is ruining me.
For a lot of reasons, mainly problems with changing lenses, I am leaning toward zooms. I had the FE 24-70/4, and it was lacking in a lot of ways. I got the FE 24-105, after reading many glowing reviews, and it is indeed much better. Everyone says for best IQ use primes, and I agree. Problem is the CY 35-70 is so good, I can't be satisfied with any other zoom. I don't want the size of the GM, and I want AF. If it weren't for the CY zoom I would probably be happy with the 24-105, but now I wonder, would the new Tamron be better? Anyone have both?
End of rant.
Jul 05, 2018 at 03:26 PM
DavidBM
Details
p.1 #2Contax 35-70/3.4 is ruining me.
...Show more →
If you look around on this site, @Fred Miranda has some crops of both the c/y and the g 24-105. Of course not taken at exactly the same time.
My recollection is that stopped down, the g zoom is at least as good as the c/y. And though I rarely use my c/y in Images with corner detail wide open, Zeiss own mtf makes me think that’s not the c/y strength especially at the wide end.
I guess what I’m trying to say is before concluding the g zoom is worse than c/y do some careful tripod mounted tests, general shooting can be misleading. And if that reveals the g is worse, consider sample variation.
The Tamron is very appealing because of speed and size, one of the team at Phiilipreeve has switched from c/y to it. But not for reasons of image quality, rather for the combo of speed, size and AF.
Jul 05, 2018 at 03:40 PM
Charlie N
Details
p.1 #3Contax 35-70/3.4 is ruining me.
I cant imagine keeping the cy 35-70 much longer, especially since the Tamron does similar, but much more practical. Both are *macro* on the wide end, with the CY probably being able to get closer.
the tamron might be sharper wide open? definitely wider aperture wide open, and the autofocus is a lot better
Size wise, they are more similar than they are different.
Jul 05, 2018 at 05:36 PM
chez
Details
p.1 #4Contax 35-70/3.4 is ruining me.
For a landscape lens, it's manual focus that counts. How do the two compare using manual focus. I've had bad experiences trying to do fine manual focus with an AF lens.
Personally I'm looking at the Tamron as a travel / street lens where I use AF as much as possible...but for landscape, it's manual all the way.
Jul 05, 2018 at 06:12 PM
Charlie N
Details
p.1 #5Contax 35-70/3.4 is ruining me.
I'm not really sure why you'de have to do that. I was shooting cityscapes at night, and generally find that I'm using AF most of the time now.
AF-S + single shot, I can focus on most lighting conditions. Focus on something, then disable AF, pretty darn simple.
my workflow is take a shot and then review sharpness (I have a habit of doing this anyhow, looking for flaws that I simply missed when not zoomed in). if necessary, take more shots. Using this method, I cannot remember the last time I missed a shot, so AF is simpler and quicker. Along with really good MF experience with any lens, true MF is less and less needed unless you're the type to do precise focus pulls for video. I cant be bothered by that since the transition of these lenses in video mode are so excellent.
There are a lot of things done right with the CY 35-70, and finding a true successor was tough, but I think the tamron is overall the better package and darn close enough at landscape apertures. It's likely better at wider apertures.
now, would like someone to build a lens that can replace the cy 100-300..........
Jul 05, 2018 at 06:53 PM
mudlake
Details
p.1 #6Contax 35-70/3.4 is ruining me.
I won’t give up my Contax 35-70. Paired with the 16-35/2.8 GM, I’ve been in heaven. But I use it for landscapes only. For people, I’d rather have autofocus. But for people I’d rather shoot with primes.
Jul 05, 2018 at 06:56 PM
chez
Details
p.1 #7Contax 35-70/3.4 is ruining me.
Charlie N wrote:
chez wroteFor a landscape lens, it's manual focus that counts. How do the two compare using manual focus. I've had bad experiences trying to do fine manual focus with an AF lens.
...Show more →
I always use the rear LCD zoomed in to focus. I scan through the entire scene zoomed in to ensure what I want in focus is still in focus. Sometimes I need to adjust the aperture to get everything in focus...sometimes I can back off the aperture to more the sweet spot for that lens.
Just AF on what you want in focus does not guarantee everything in the image ( foreground to far background ) is in focus and you might also be using an aperture setting that is not optimal.
From my experience, detailed manual focus provides better results than letting the camera decide on the focus.
Jul 05, 2018 at 07:52 PM
CalebAllenPhoto
Details
p.1 #8Contax 35-70/3.4 is ruining me.
@f8 the FE24-105 is not going to hold up to the 35-70 @50mm or @70mm. No way. The Tamron will be much worse again.
Jul 05, 2018 at 08:48 PM
CalebAllenPhoto
Details
p.1 #9Contax 35-70/3.4 is ruining me.
C/Y35-70 stopped down can compete with a Sony 55 1.8. No way any 24-105 will do that. Not saying the FE24-105 isn’t a very good lens, but it isn’t that good. The micro contrast won’t be like the best lenses.
The CY35-70 really shines stopped down to f5.6-f11. Below that the FE24-105 will probably do better.
The cy35-70 weakest focal length is 35mm. The fe 24-105 will have the best chance against it here in the corners. But it still lacks the micro contrast of the CY in the centre or mid zones.
Jul 05, 2018 at 09:57 PM
Dustin Gent
Details
p.1 #10Contax 35-70/3.4 is ruining me.
Also remember that the C/Y has the sought after Zeiss “3D” effect. I haven’t seen another lens display this. One of the many reasons this lens is my main landscape lens.
Jul 05, 2018 at 10:28 PM
CalebAllenPhoto
Details
p.1 #11Contax 35-70/3.4 is ruining me.
If you’re not happy with the IQ of the 24-105 over the 35-70, there is no way you’ll be happy with the 28-75.
But if your problem is size, then that is a different question.
Jul 06, 2018 at 12:44 AM
Kierzkow
Details
p.1 #12Contax 35-70/3.4 is ruining me.
Agree with you.
The C/Y 37-70mm lens is in a league of its own because of a unique 3D effect. If one like this effect one will never give it up or even compare it with other lenses. Needless to say, there are other excellent lenses. Courses for horses.
Jul 06, 2018 at 01:24 AM
Charlie N
Details
p.1 #13Contax 35-70/3.4 is ruining me.
CalebAllenPhoto wrote:
@f8 the FE24-105 is not going to hold up to the 35-70 @50mm@ or @70mm. No way. The Tamron will be much worse again.
here lies the problem with this blanket statement
the zeiss doesnt have better resolution across all focal lengths. sometimes center is better, sometimes edges are better.
Some parts of the frame have better contrast, some dont.
there may be a bit of FC that skews the result, but I find the lenses within the margin of errors to each other.
I've done my own tests on a chart I have and I've got a similar conclusion to this test:
https://www.fredmiranda.com/forum/topic/1531582/28#14479554
zeiss doesnt blow away the tamron, in fact, it loses on some occasions. To add to that, it wont AF, and wont do 2.8 or 28mm.
While F8 is the most common landscape aperture, it's not the only, sometimes you may want a faster shutter or you want some blur, the Tamron is pretty competent in that regard. If you do purely F8 landscapes, then you can say the CY is better for the most part, certainly not 100%.
Jul 06, 2018 at 08:44 AM
rioni
Details
p.1 #14Contax 35-70/3.4 is ruining me.
I shoot a 35-70 w/ TAP and autofocus works great.
Jul 06, 2018 at 10:03 AM
Dustin Gent
Details
p.1 #15Contax 35-70/3.4 is ruining me.
The sharpness on this lens really is something that blows my mind, especially for such an older, classic design. The full screen RAW file on my 27" monitor is astounding.
Jul 06, 2018 at 03:48 PM
Greggf
Details
p.1 #16Contax 35-70/3.4 is ruining me.
I have to disagree. I’ve gone through 3 35-70’s(mainly just trying other lenses) and my current one still blows my mind for landscapes. Maybe I got lucky, but @35mm my is brillaint. And throughout the range it is also superb. And I do like it for people, especially @50. Has great pop and good separation too. Hard to find a replacement, and I know when Fred was doing comparisons between his new 24-70 GM, the C/Y held it’s own pretty damn well.
You have to pick your priorities and go that route...but I can’t ever see selling mine!
Couple of grabs using the C/Y on my A7rll...
35mm, Honolua Bay, Maui
35mm again
35mm again.
Jul 07, 2018 at 12:51 PM
echelonphoto
Details
p.1 #17Contax 35-70/3.4 is ruining me.
My 24-105 must be a freak then....check out the lens at 24mm and f5.6
http://www.echelonphotographers.com/p121409335....you can download full size jpeg..also a shot at 105 on this site...never saw better resolution edge to edge.
Jul 07, 2018 at 01:11 PM
echelonphoto
Details
p.1 #18Contax 35-70/3.4 is ruining me.
Jul 07, 2018 at 01:12 PM
Valner
Details
p.1 #19Contax 35-70/3.4 is ruining me.
I am not going to besmirch your love on the CY zoom BUT.. it is a 2x zoom with a drop dead stupid easy focal range. A 10-20mm is a 2x zoom and a @@@ to design. A 40-80 is a 2x zoom that a chimp can design... The CY is a well done lens but the modest aperture, easy zoom range and zoom choice make the lens easy to design and manufacture. The 24-105g being anywhere in the same zip code is a sign of fantastic design and manufacturing. Wide to tele 4-5x lens are not trial.... If you really expect to beat the CY it will be with a very limited design or high price or high weight....
Jul 07, 2018 at 04:55 PM
tsdevine
Details
p.1 #20Contax 35-70/3.4 is ruining me.
I did some comparison shots this morning between my C/Y 35-70 and my FE 24-105. My C/Y isn’t perfect though, one corner suffers. I haven’t processed them yet, but the Sony seemed competitive. Might be there is more wrong with my 35-70 than just one corner.
-Tim
Jul 07, 2018 at 05:25 PM
