fredmiranda.com Login
This topic is in the 2018 archive. You can read it and like its posts here. It is read only.
Archive 2018Sony 24-105mm Big Bronco Test
GMPhotography
p.1 #1Sony 24-105mm Big Bronco Test
Went out to test the loaner I got from Sony
So C1 has no specific profile but if you use Manufactuer Profile there is a lens correction and its a big difference. I can see the hard vignette.
Check this out. Now I will just keep the profile in as thats how we would use the lens anyway. It cleans up very nicely as you can see.
Jan 18, 2018 at 11:13 AM
GMPhotography
Details
p.1 #2Sony 24-105mm Big Bronco Test
At 28mm its better than at 24 and for those folks looking for a great 28mm we just found it. Case closed
Looks to me and this is very critical 29mm and 50mm are the best focal lengths in the corners wide open. Just found my two missing lenses the 28/50. IM BUYING
Jan 18, 2018 at 11:14 AM
GMPhotography
Details
p.1 #3Sony 24-105mm Big Bronco Test
Very large download 1.72 gbs so this is taking awhile.
https://spaces.hightail.com/receive/TdjbfvIN0b
Jan 18, 2018 at 11:15 AM
GMPhotography
Details
p.1 #4Sony 24-105mm Big Bronco Test
Okay have a lot of stuff to do since I just got back home after 2 weeks in LA but Ill catch up and I also have shots in low light work. But wanted to get at least the Raws up since I have to ship back the lens. But I cant buy it it since it is a loaner as i just checked. So i will start looking soon here
Jan 18, 2018 at 11:16 AM
GMPhotography
Details
p.1 #5Sony 24-105mm Big Bronco Test
I focused at F4 than stopped down
Jan 18, 2018 at 12:38 PM
MikeEvangelist
Details
p.1 #6Sony 24-105mm Big Bronco Test
That 24mm vignette in the upper-right doesn't seem right.
I've used two copies, and in both cases the profile completely eliminated the vignette at 24mm. In your shot, it's gone in the other three corners, but not upper-right. Were you using the hood (I know you usually don't).
Jan 18, 2018 at 12:56 PM
GMPhotography
Details
p.1 #7Sony 24-105mm Big Bronco Test
No hood on it. All I can think of it’s not a specific profile like other lenses in C1 . It’s called a manufacturer profile. So it could be somewhat generic. It could use a little more correction as it still has a touch of barrel still
Jan 18, 2018 at 01:08 PM
MikeEvangelist
Details
p.1 #8Sony 24-105mm Big Bronco Test
Sorry, I should have mentioned that even with the specific profile in Lightroom that bit of vignetting is still there.
Jan 18, 2018 at 01:11 PM
ajamils
Details
p.1 #9Sony 24-105mm Big Bronco Test
Better than 28 f2?
Jan 18, 2018 at 01:12 PM
GMPhotography
Details
p.1 #10Sony 24-105mm Big Bronco Test
Yes my 28 f2 and 50 1.8 are on the block. Both new
Jan 18, 2018 at 01:18 PM
ajamils
Details
p.1 #11Sony 24-105mm Big Bronco Test
Good to know. I might just replace my "all prime" kit with this zoom in future and just keep 85/1.8 for portraits.
Jan 18, 2018 at 01:43 PM
GMPhotography
Details
p.1 #12Sony 24-105mm Big Bronco Test
I bought the 28 and 50 as a temp. Fix until this came out
Jan 18, 2018 at 02:04 PM
GMPhotography
Details
p.1 #13Sony 24-105mm Big Bronco Test
Thanks Mike so it’s a 25mm. Lol
Jan 18, 2018 at 02:05 PM
jamato8
Details
p.1 #14Sony 24-105mm Big Bronco Test
I get vignetting on mine at times and then don't (at same f stop). It is like the software works and then doesn't kick in. Haven't figured it out yet.
Jan 18, 2018 at 02:32 PM
Admin
Details
p.1 #15Sony 24-105mm Big Bronco Test
ajamils wrote:
GMPhotography wroteAt 28mm its better than at 24 and for those folks looking for a great 28mm we just found it. Case closed
Better than 28 f2?
Yes, for sure! The 24-105/4G @24-35mm is really amazing from center to corners wide-open! Starting at 50mm, it only needs f/5.6.
Now, there is something I am still scratching my head. I tested my copy multiple times at infinity and 20-30 feet (like Big Bronco) and my lens does not benefit when stopping down f/4 to f/5.6 or f/8 at the wide range. Actually at f/8, I already see signs of diffraction when viewing at high magnifications like 1:1 or 2:1.
That's for the corners but it's also true for center and mid-areas where the improvement is almost nil....Not sure how that's even possible but I'm not complaining.
Guy's Big Bronco test shows a noticeable improvement going from wide open to smaller apertures. Chuck's infinity tests also show improvement but to a lesser degree.
Thanks for posting Guy!
I'm waiting for less haze to take new samples and post it on the board.
Jan 18, 2018 at 02:38 PM
jamato8
Details
p.1 #16Sony 24-105mm Big Bronco Test
Fred Miranda wrote:
Better than 28 f2?
...Show more →
In actual practice now I notice an improvement to around 5.6 and 8. I don't understand the differences from what you say and various lenses. The more I have put this lens to use though, in practical use, it is proving good.
Jan 18, 2018 at 03:05 PM
mjm6
Details
p.1 #17Sony 24-105mm Big Bronco Test
Fred,
I didn't see the info in here, but could this have to do with field curvature and where you and Guy focused for your respective test images?
I'm used to somewhat compensating for FC by focusing a bit off center most of the time, but if you focused purely in the center and Guy didn't (or vice-versa) it could produce different results.
The other possibility is that the subject distance is still different enough between your tests that FC is affecting one more than the other. Since yours are effectively infinity, and Big Bronco is somewhat shorter (I'd consider it mid-field personally), there may be enough difference in field geometry to cause a difference.
Jan 18, 2018 at 03:07 PM
pdmphoto
Details
p.1 #18Sony 24-105mm Big Bronco Test
The consensus seems to be that the lens performs best at Infinity, then IQ degrades as the focus distance is decreased.
Jan 18, 2018 at 04:01 PM
GMPhotography
Details
p.1 #19Sony 24-105mm Big Bronco Test
Interesting. I focused slightly above center that horizontal strip above the big bronco words. Also I focused manual at F4 than shot the series. Also remember I’m moving backwards at each focal length. At 105 I shot half the building because of a wall behind me.
So I am varying the distance . I’d say from 24-70 by about 30 ft
Jan 18, 2018 at 04:07 PM
GMPhotography
Details
p.1 #20Sony 24-105mm Big Bronco Test
Sorry I’m still catching up on house stuff since I’ve been gone and my wife really has the whip out. Lol
Jan 18, 2018 at 04:08 PM
