fredmiranda.com Login
This topic is in the 2015 archive. You can read it and like its posts here. It is read only.
Archive 2015High DR for 5d4
PhilDrinkwater
p.1 #1High DR for 5d4
This is a rumour. Nothing more than a rumour. Just making sure you can see its a rumour and don't complain that it's not real yet
http://www.canonrumors.com/2015/04/eos-5d-mark-iv-to-use-eos-c300-mark-ii-technology-cr2/
Apr 10, 2015 at 10:28 AM
PhilDrinkwater
Details
p.1 #2High DR for 5d4
"We’re told that the upcoming Canon EOS 5D Mark IV sensor will employ the same dual-channel readout as the EOS C300 Mark II.
The source says:
… this essentially works as a hardware implementation of what the Magic Lantern guys did with software, and actually takes it a bit further.
There has been no real confirmation that the EOS 5D Mark IV will shoot 4K video like the EOS C300 Mark II. Although, a lot of people almost expect it to be able to.
An announcement for the EOS 5D Mark IV is not expected until late summer at the earliest.
Apr 10, 2015 at 10:29 AM
arbitrage
Details
p.1 #3High DR for 5d4
And for those not knowing what the C300II is doing it is taking two readouts at two different ISOs and combining them for a claimed 15 stops of DR. Canon even mentions the DR in the C300II press release where as they have never mentioned number of stops before.
Apr 10, 2015 at 10:39 AM
NCAndy
Details
p.1 #4High DR for 5d4
Hopefully those two readouts are instantaneous at the time of exposure so they blend perfectly into one raw file with greater DR. As I understand it, the ML solution is to take two exposures at different ISOs to blend in software.
Apr 10, 2015 at 10:42 AM
PhilDrinkwater
Details
p.1 #5High DR for 5d4
Yes. That's correct. It was an interesting inclusion..
Apr 10, 2015 at 10:43 AM
snapsy
Details
p.1 #6High DR for 5d4
NCAndy wrote:
arbitrage wroteAnd for those not knowing what the C300II is doing it is taking two readouts at two different ISOs and combining them for a claimed 15 stops of DR. Canon even mentions the DR in the C300II press release where as they have never mentioned number of stops before.
The ML implementation is a dual ISO readout of the same exposure, the same as Canon is likely using for the C300II (if rumors are true). The blending will always be necessary although Canon's implementation would likely be done at the sensor/DIGIC rather than in software. Hopefully Canon has improved the sensor implementation so that the full resolution can be sampled at both ISOs vs half the sensor in the current implementation.
Apr 10, 2015 at 10:51 AM
arbitrage
Details
p.1 #7High DR for 5d4
Yes it would have to be that way to make it worthwhile as a general DR bumping solution. Otherwise limited to strict tripod use like the high MP mode of the EMII. I think the C300II is reading it off a single RAW exposure. Although so far the only place I have even read about how they are doing the 15 stops was at EOSHD site and they didn't go into to many details.
Apr 10, 2015 at 10:52 AM
PhilDrinkwater
Details
p.1 #8High DR for 5d4
Could they not use the new 50mp sensor and bin half of the resolution? Making a 25mp 5d4?
Apr 10, 2015 at 11:01 AM
Access
Details
p.1 #9High DR for 5d4
IMO it makes some sense that the 5d4 would return the focus to video. The 5d2 was sold heavily on its video functionality, but the 5d3 offered little to no improvement in this respect.
Also in the embedded world the line between hardware and software is blurred. The sensor had to support the dual-ISO readout in hardware for the ML guys to use it at all.
There must have been at least some forethought by Canon to have designed a sensor with this capability. It's more likely that the full implementation of that capability (whether in the DIGIC or in firmware) was lost in the development.
I know this might seem like a waste to you guys -- but it happens all the time in the real world, when you factor in things like schedules, cost, management, ego, etc.
I also hope that the 5d4 offers things like true downsampling to 4K and 1080p in hardware rather than just the straight sampling of pixels that it seems to do now (?).
Apr 10, 2015 at 11:17 AM
Stoffer
Details
p.1 #10High DR for 5d4
A word of caution is warranted regarding the dynamic range of "up to 15 stops" on the EOS C300 Mark II.
The number is used in conjunction with the new CANON LOG2, not necessarily the sensor itself:
The Canon Log2 gamma profile increases the range of creative possibilities by achieving a uniform output in a wide area of the log space, giving greater flexibility in post-production processing. It does this by widening the dynamic range by up to 15 stops, enabling the extremes of highlight and shadow details to be recorded, extending the scope of colour grading.
http://cpn.canon-europe.com/content/product/cinema_eos/eos_c300_mark_ii.do
I haven't seen anything mentioned about the sensor itself?
Apr 10, 2015 at 11:27 AM
retrofocus
Details
p.1 #11High DR for 5d4
Earlier quoteThe Canon Log2 gamma profile increases the range of creative possibilities by achieving a uniform output in a wide area of the log space, giving greater flexibility in post-production processing. It does this by widening the dynamic range by up to 15 stops, enabling the extremes of highlight and shadow details to be recorded, extending the scope of colour grading.
It might be a feasible workaround to increase DR with an older tech based sensor. Curious how this works out in the end when compared to the Sony FF sensor.
I wonder why this workaround only goes into the 5D MkIV and not into the 5Ds camera versions where it might help a lot, too.
Apr 10, 2015 at 11:39 AM
PhilDrinkwater
Details
p.1 #12High DR for 5d4
But surely it wouldn't provide that many stops unless the sensor was capable of it? Or is that wrong?
Apr 10, 2015 at 11:40 AM
snapsy
Details
p.1 #13High DR for 5d4
Sony claimed 15.3EV of DR for the A7s but that turned out to be based on some type of slog2 interpretation. The sensor itself only measured 13EV per DxO.
Apr 10, 2015 at 11:50 AM
gdanmitchell
Details
p.1 #14High DR for 5d4
But wait, isn't that just a rumor? ;-)
therealthings
Details
p.1 #15High DR for 5d4
Why would anyone respond to that. I thought canon folks didn't care for more DR
Apr 10, 2015 at 12:04 PM
dhphoto
Details
p.1 #16High DR for 5d4
wouldn't this immediately render the 5Ds/r rather obsolete?
I can't see why Canon would do this to themselves.
Apr 10, 2015 at 12:20 PM
NCAndy
Details
p.1 #17High DR for 5d4
Not if one camera is 24 mp and the other 50mp. Different uses I would think.
Apr 10, 2015 at 12:40 PM
chez
Details
p.1 #18High DR for 5d4
NCAndy wrote:
dhphoto wrotewouldn't this immediately render the 5Ds/r rather obsolete?
But wouldn't the 50mp camera that seems to fit nicely for landscapes benefit the expanded DR more than the 24mp camera which is more events or photo journalist focussed.
Apr 10, 2015 at 12:57 PM
PhilDrinkwater
Details
p.1 #19High DR for 5d4
gdanmitchell wrote:
PhilDrinkwater wroteThis is a rumour. Nothing more than a rumour. Just making sure you can see its a rumour and don't complain that it's not real yet
Oh it's not is it? I feel like I've misrepresented it
Apr 10, 2015 at 01:01 PM
PhilDrinkwater
Details
p.1 #20High DR for 5d4
This makes me wonder if it IS the same sensor (as I posted above) and they just will halve the resolution for the 5d4, in the same way as the magic lantern guys. Why otherwise would they not delay the 5ds for a few months and make it higher DR?
If so .. clever move .. they're using the same for the 7d2, 5ds and 5d4!
Mind you im not an engineer so I'm probably missing a point
Apr 10, 2015 at 01:05 PM
