Wedding Resource List
       2       3       4       5       end
Archive 2012 · so wich triggers u using ?
DimaVazinovich
p.1 #1 · so wich triggers u using ?
i have been using the PT - 04 for sometime and the last couple of weddings they started doing some problems when the dance floor is big , and not responding and also missing,
Jun 01, 2012 at 10:52 AM
RobertLynn
p.1 #2 · so wich triggers u using ?
Paul
Buff cybersync.
Reliable. Well built. Affordable.
Jun 01, 2012 at 11:59 AM
Jon Uhler
p.1 #3 · so wich triggers u using ?
I will echo what Robert said.
Love my syncs.
Just have to come up with a creative way to mount them.
Jun 01, 2012 at 12:05 PM
joelconner
p.1 #4 · so wich triggers u using ?
phottix strato.
the best non-ttl triggers i have ever used.
Jun 01, 2012 at 12:06 PM
swoop
p.1 #5 · so wich triggers u using ?
Microsync
Jun 01, 2012 at 12:08 PM
thorne88
p.1 #6 · so wich triggers u using ?
phottix strato ii
awesome, 100% reliable, better than cybersyncs (in my experience)
ChiShutter
p.1 #7 · so wich triggers u using ?
joelconner wrote:
phottix strato.
I have the Calumet-branded Strato II. They're great, and moderately cheap. About to pick up another set today, actually, because I'm somehow missing a receiver!
Jun 01, 2012 at 12:09 PM
johnrg
p.1 #8 · so wich triggers u using ?
joelconner wrote:
phottix strato.
+1
Jun 01, 2012 at 12:19 PM
broken-taco
p.1 #9 · so wich triggers u using ?
phottix stratto II, a lot more functional then cybers and inexpensive
Jun 01, 2012 at 12:25 PM
maxwell1295
p.1 #10 · so wich triggers u using ?
Phottix Strato II
Definitely a step up from Cybersyncs.
Having 4 flashes on 4 different channels and being able to fire them in ANY combination is amazing.
Not having to deal with cables and PC sync cords.....Priceless!
Jun 01, 2012 at 12:43 PM
Scott Mosher
p.1 #11 · so wich triggers u using ?
Pocketwizards (not the flex ones)
Jun 01, 2012 at 12:45 PM
sherijohnson
p.1 #12 · so wich triggers u using ?
RobertLynn wrote:
Paul
Buff cybersync.
ditto, as long as batteries are good, everything works
one of these days I will add a few ac powered ones and then no worries about batteries except for the transmitter
Jun 01, 2012 at 12:53 PM
sherijohnson
p.1 #13 · so wich triggers u using ?
Love my syncs.
creative for me = rubber bands
Jun 01, 2012 at 12:54 PM
RobertLynn
p.1 #14 · so wich triggers u using ?
Love my syncs.
Velcro on flash head, Velcro on back of sync.
The syncs are no-nonsense. It is plug in and go. You can use them with any makes/models. They do not support ttl. They are extremely reliable and never have had an issue.
The things I do not like are the pc sync cables on the 580exii.,,the socket is a piece of crap. But that's not the syncs fault, as you can use the much cheaper and much more reliable 1/8"-1/8" cables...just don't buy them from mpex or pcb...they are too expensive. $10 for a 16 inch cable...I can buy a damned 10' 1/4" guitar cble for a buck more.
With that said, the Strattos look nice. I don't like how they mount and I do. I think it is awesome to still have ttl on camera, but at the same time they add height to the flash on the umbrella swivel. Also (not sure as I didn't look) can you use them on non flash foot items? I know when you buy them you buy canon or Nikon. Can you still use manual OCF if it's another brand?
Jun 01, 2012 at 12:59 PM
amonline
p.1 #15 · so wich triggers u using ?
thorne88 wrote:
phottix strato ii
Plus.... what are we up to? 3? 4, now?
Jun 01, 2012 at 01:01 PM
maxwell1295
p.1 #16 · so wich triggers u using ?
Yep. I shoot Canon and use Nikon SB24 and SB25 off-camera. You can also use them to trigger strobes (I trigger AlienBees with them), but that requires the use of a 3.5mm cable.
Jun 01, 2012 at 01:15 PM
DimaVazinovich
p.1 #17 · so wich triggers u using ?
how far can u work with ur phottix stratto II ? ,
cause i tried firing my flash's from around 10-12 M yesterday and only one of them worked
Jun 01, 2012 at 01:17 PM
LivLif
p.1 #18 · so wich triggers u using ?
phottix strato IIs FTW!!!!!
maxwell1295
p.1 #19 · so wich triggers u using ?
I haven't done a distance test yet, but they they worked fine at opposite ends of a decent size reception hall. I'm going to assume working distanec is similar to the Cybersync. I got 100yds+ on a football with those.
Jun 01, 2012 at 01:21 PM
DimaVazinovich
p.1 #20 · so wich triggers u using ?
sounds awesome ,
from what i see now they are around 170$ for 1 Transmitter 2 Receiver ?
Jun 01, 2012 at 01:25 PM
       2       3       4       5       end
       2       3       4       5       end
