p.1 #1Initial NEX 7 impressions from a NEX 5N owner
Got the NEX 7 today and wanted to share my initial impressions of it with the other NEX 5N owners out there who've been wondering whether to "upgrade".
My first and overarching reaction is that the NEX 7 is not a bigger/better NEX 5N. It's a very different camera and some people will like it better than the NEX 5N, some people will like it less.
It feels quite different in the hand, at the eye, and in use.
- The grip is bigger, differently shaped, and covered in a different material. My initial reaction is that I'll probably like the 5N better with small/light lenses, and the 7 with bigger/heavier ones.
- Having the viewfinder at the top left rather than top middle feels quite different.
- It has a lot more buttons, dials and switches for a totally different user experience
- The screen articulates differently - clearly better on the 7
- It doesn't have a touch screen which I personally miss quite a bit
Also, the results I'm getting are quite different:
- Amazing resolution. I'm seeing a difference between 16 and 24 mpix.
- The NEX 7 seems to have a tendency to underexpose, something I haven't seen on the 5N
- The auto WB doesn't seem quite as good on the 7, again not a problem on the 5N
- The color red seems oversaturated on NEX 7 JPGs, again not something I noticed on the 5N.
Overall, here are the good surprises from my first few hours with the NEX 7:
- 24mpix does seem qualitatively different from 16mpix for cropping or printing big, or just pixel peeping and going "wow"
- Noise at ISO 800 and 1600 with this sensor seems well under control compared to my expectations
- My right thumb is much happier -- the three controls I've set at the top right of the camera -- MF magnification, shutter speed control, and exposure compensation are much better positioned than they are on the 5N
Here are the bad surprises from my first few hours:
- The JPGs seem more problematic with worse auto WB, and oversaturated reds
- The NEX 7 seems to want to underexpose a bit
- It's definitely more cumbersome to choose a focus/magnification point or to check your focus after taking a picture without the touchscreen
So ... here are some "test shots" from my first afternoon with the NEX
p.1 #7Initial NEX 7 impressions from a NEX 5N owner
flashinm wrote:
Awesome. Thanks for the samples and I look forward to seeing how the rangefinder lenses perform.
OK -- I really should be in bed but you got me curious and so here's a little test of my widest rangefinder lens - the Konica Hexanon m-mount 28mm f2.8
While obviously not at good as the center, I can tell you from having looked at many many lenses' corners with this test subject that this is good performance for a wide open lens in the extreme corner at less than minimum focusing distance (using the hawk adapter that lets you go to less than minimum focusing distance).
I'd say this quick little experiment bodes very well for real world usage.
p.1 #8Initial NEX 7 impressions from a NEX 5N owner
Thanks for the test. It'll be interesting to see how the corners do when the center is focused at infinity, as that is where many issues tend to pop up.
p.1 #14Initial NEX 7 impressions from a NEX 5N owner
Me too, thanks!
And I also wanna see it at the highest ISO settings, not just 1600 please. But post RAW with the lumi-NR set to zero. Color NR is fine at whatever. If you have the time that would be appreciated!
p.1 #15Initial NEX 7 impressions from a NEX 5N owner
Thats great Brandon.
One question I have is how the weight distribution is with a larger lens; I found the previous NEXs unbalanced given the location of the lens toward the left; does the 7 feel a little less obvious on this?
p.1 #16Initial NEX 7 impressions from a NEX 5N owner
Does the NEX-7 firmware allow you to toggle focus peaking off and on, assigned to a button? And/or is there a way, default or otherwise, to configure it such that a half-press of the shutter disables both magnification (if toggled on) and focus peaking (if on globally)?
p.1 #17Initial NEX 7 impressions from a NEX 5N owner
Awesome! I feel that things like problems you mentioned with underexposure and mediocre jpegs are things that can they can fix with firmware updates, right?
p.1 #18Initial NEX 7 impressions from a NEX 5N owner
Where did you get your NEX-7?
Your supplier obviously has a higher priority than Amazon.com. I order mine on the first day to pre-order and still don't have a estimated ship date.
p.1 #19Initial NEX 7 impressions from a NEX 5N owner
+1
Infinity will be the real test and will be very interested in your results, especially the CV35 f/1.2 II (not sure how much difference there will be between the two versions if you have the original one), which I found worked very nicely on the 5N for corner sharpness compared to my C Biogon ZM35.
p.1 #20Initial NEX 7 impressions from a NEX 5N owner
rscheffler wrote: douglasf13 wroteThanks for the test. It'll be interesting to see how the corners do when the center is focused at infinity, as that is where many issues tend to pop up.+1
Ron
Agreed. I'm sure the CV 35/1.2 will be fine, although, at that size, it should be! So far, I find the ZM 35/2 to be quite a bit better on the 5N in the corners than my ZM 35/2.8, and I'd be curious how both do on the NEX-7.
