louhand Registered: Aug 17, 2004 Total Posts: 1230 Country: United States |
I just ordered a Cyber Commander, 4 Receivers, and an extra Transmitter. |
GeekChicPhoto Registered: Oct 07, 2009 Total Posts: 70 Country: United States |
Yes, both shooters can trigger the flashes. If you are using hot shoe flashes, you might run into recycle problems, especially if you and your partner are constantly shooting. |
dmward Registered: Apr 12, 2002 Total Posts: 1699 Country: United States |
I've done the two shooters with one strobe deal a couple of times, including last Saturday. |
Matt Leitholt Registered: May 27, 2008 Total Posts: 3451 Country: United States |
To my knowledge you can. What I did was I ordered my CC separately from my receivers and transmitter so I could get my Cybersyncs and be using them and not have to wait for the CC to ship. It never hurts to have an extra transmitter for a backup or a second shooter if needed. Hell, I might even use the transmitter on camera and keep the commander in my pocket. |
a2rob Registered: May 21, 2003 Total Posts: 437 Country: N/A |
I would download and print the instructions to familiarize myself with the unit now! |
E-Vener Registered: Jun 18, 2009 Total Posts: 4248 Country: United States |
Absolutely +1 on a2rob's advice. The CyberCommander is a sophisticated tool and you don't want to learning it's ins and outs while on the job. |
RDKirk Registered: Apr 11, 2004 Total Posts: 8477 Country: United States |
Thanks for all your help. |
I got my Cybercommander but can't get it to work. |
jprezant Registered: May 19, 2006 Total Posts: 7467 Country: United States |
did you use the same csrb when you switched lights? maybe the sync cord |
jprezant wrote: |
kenyee Registered: Jul 08, 2008 Total Posts: 1272 Country: United States |
louhand: are the bees charging up all the way when you fire them w/ the CC? |
kenyee wrote: |
tamara328 Registered: Jun 30, 2008 Total Posts: 39 Country: United States |
Just as a point of reference, before I activate the Cyber Commander my lights are set at the highest power but fire at a low power when the test button is pushed on the CSR+. It's only when I disconnect the jack cord or open one of the saved set-ups do my lights power up to full. It's the same on two different lights so I'm assuming that's the way it should be because everything is working now. Do your lights fire at the same power with and without the jack cord? |
tamara328 wrote: |
I spoke to PCB Tech Support. We figured out that the CSR+'s were defective in that they coTuldn't control the AB800. I used a CSRB+ (Battery Version) and it worked fine. |
Thanks for keeping us updated, it will probably help in the future |
Latest update: 3 new CSR+'s have been shipped. ![]() |
