chris78cpr Registered: Aug 27, 2003 Total Posts: 5467 Country: United Kingdom |
hey all, |
Gregg Heckler Registered: Aug 07, 2005 Total Posts: 1380 Country: United States |
The primary benefit of wireless is just that (wireless). No sync cords to trip over, go bad, etc. The other benefit is that you can fire your strobes from greater distances and multiple strobes close in if the slave might be blocked, as in the case of a back light. I have both Pocketwizards and El-Skyports. Both are excellent tools but I prefer the size and features of the Skyports (the price is better too). However, I have RX-600's so that's where the RX systems really shines. But I have D-lite 2's also and the Universal Skyport is very hand also. |
DaveEP Registered: Aug 14, 2004 Total Posts: 3706 Country: United Kingdom |
The thing I hate about sync cables is that fact I was often tripping over them, or getting distracted simply by knowing I had to avoid them when moving about. |
Cheers for the replies so far. Yeah the thought of tripping on the cables had crossed my mind, but i figured that for now the £150-200 would probably be better spent on a couple of soft boxes? I would definitely get a set of triggers at some point as like you said they make things a hell of a lot simpler and hassle free, however i think they would only really be worth it if i was shooting on location with outdoor lights and a power pack and such. |
chris78cpr wrote: |
Cheers for that Dave, i'll take a look at those and maybe pick one of them up. |
The Sekonic is the best in it's class, especially with the Pocketwizard module. Very accurate and very easy to use. However, even if you go the with the Skyports you can just plug one of their transmitters into it and use it that way too. |
I didn't know you could plug in a Skyport to the 358. It's becoming more and more the favourite it seems. |
Matt Leitholt Registered: May 27, 2008 Total Posts: 3451 Country: United States |
Radiopopper is coming out with their new series in Febrauary, you might look into that. |
Realmstalker Registered: Dec 29, 2004 Total Posts: 220 Country: United States |
I'm using Cybersyncs. Im never going wired ever again! EVER. EVAR. I won't even bother with optical slave any more because it's just too convenient. Bite the bullet, get some wireless trigers, all your pain will go away! Cables suck! |
Yep, you just take the miniplug/pc sync cord the universal set comes with and plug it into the pc socket on the 358. This will allow you to trigger your Skyport receiver with the 358. |
Beni Registered: May 31, 2005 Total Posts: 6960 Country: United Kingdom |
There is a setting on my sekonic where it will wait for a flash and then show the metering, no need for anything to be connected, I hold the trigger in my hand (or on the hotshoe) and just press the test button. On my Sekonic 308S all you need to do is press the main button for a few seconds till the flash symbol starts blinking then fire your strobes. |
