DOF Diff's Between Crop & FF?
/forum/topic/689610/0
2 3 end
therock
Country: United States
I caught a glimpse of someone saying DOF charactoristics between a Crop and FF behave differently.
Can anyone varify?
cwphoto
Country: Australia
Affirmative.
All things being equal, FF photos have less DoF than those from smaller sensors.
invalid2
Country: N/A
yes.
dhphoto
Country: United Kingdom
Yes, and no.
Lenses behave like lenses regardless of what camera they are mounted on, their characteristics, depths of field, etc don't change. A 24-105L lens is still the same length on a crop camera.
What changes is the amount of the field of that lens seen by the sensor (the crop seeing proportionately less, obviously). This means that in order to photograph the same subject at the SAME SIZE in the viewfinder with both a full frame camera and a crop camera (using THE SAME lens), you will be proportionately further away from that subject on a crop camera, which means you will have the benefit (or handicap depending on your desires) of a greater depth of field, as the further you get away from a subject the larger the depth of field becomes.
There is a small variation due to the relative size of the pixels in the two types of camera, but for the purposes of a simple explation you can disregard it.
David
ChrisDM
Experiment with a couple different sensor sizes with a few of your favorite focal lengths here and you'll soon understand the difference:
http://www.dofmaster.com/dofjs.html
Chris M
www.imagineimagery.com
michael49
I'll post this again...
This is a repost of a comparison I did between my 40D and 5D.....
How about a photographic answer....
40D @ f/4, 50mm on left, 5D @ f/4, 80mm on right.....
Now, 40D @ f/2.8 vs 5D at f/4, same FL's (DOF at f/4 on 5D is roughly equivalent to f/2.8 on the 40D at the "equivalent" FL)....
ChrisDM
A great example michael49, thank you! What's most notable to me is in the top photo (equal apertures) is not only is the DOF more shallow on the 5D shot, but the OOF areas are "more OOF". More blur.... Thanks again,
Chris M
PhotosByRDD
Chris M
No, not a great example in my opinion. Apples to oranges...50mm to 85mm. Those lenses are going to have different characteristics. Compare with the same lens on each camera, "zooming with your feet" to maintain the same field of view. Then compare shots from the same distance with the FF image cropped to the same FOV digitally.
Dave King
Country: N/A
Like many things, it depends on the situation. If you use the same lens, at the same distance from the subject, then the FF camera will have the greatest DOF. If you use the same lens, but adjust the distance so that the FF and crop images have the same FOV, then the crop camera will have the greatest DOF.
gfiksel
Can anyone varify?
Caught a glimpse? I thought this subject has been banned from FM for being the most frequently and ferociously disputed.
Photon
But is that how you photograph? I think most of us, at least when we have the chance, choose our position to get a certain perspective and relationship of objects in the frame, and from there we choose a focal length to give the angle of view that includes only the things we want to show. I think the example is well done and 100% appropriate.
Photon
Another way to look at it is that FF is a larger format than 1.6 crop. Sure, it's "apples to oranges" to compare them, but isn't it perfectly valid to say that 4x5 film has less DOF than 35mm film? If you set up the same scene with different formats, you end up using different lenses to get the same photo. If you want the same DOF, you have to compensate with the f/stop. Compare digicams to SLRs for a more contemporary example.
omarlyn
(bad links -will repost later)
JSeaman
dhphoto wrote:
Yes, and no.
David
an enthusiastic +1
therock
gfiksel wrote:
Can anyone varify?
I must have missed it or it was before my time.
The glimpse was seen elswhere.
Thanks Guys
Mike Mahoney
Country: Canada
DOF is determined by three things, and three things only:
1) Lens focal length
2) Aperture used
3) Distance to subject (focus distance)
Notice that sensor size is not included in the three DOF determinants.
Repeat as often as required for it to sink in.
cogitech
Country: Canada
PhotosByRDD wrote:
Chris M
6 of one, 1/2 dozen of the other.
One way or the other, it is the photographer's actions that ultimately make the DOF difference. With FF, we either move closer or we increase the focal length in order to maintain the same framing that would suit our style.
The DOF of the lens does not change when you stick it on a different camera. The geeks are correct there. But they always forget the most important part of the formula; the photographer.
cogitech
Country: Canada
2) Aperture used
The sensor size, since it determines FOV, directly affects the photographer's actions when framing a subject. As I just explained, in order to shoot "the same shot" the photographer either increases focal length or moves closer to the subject, both of which decrease the DOF of the shot.
So, indirectly, sensor size affects DOF.
Anyone who can still argue this point is a gearhead who is forgetting the most important part of photography; You.
Mike Mahoney
Country: Canada
Exactly .. in the hands of a skilled photographer with an adequate assortment of lenses DOF can be created pretty much the same regardless of the sensor size.
And the shooters style is often ignored in these discussions .. some prefer to be closer to their subjects while shooting but still maintain a shallow DOF.
cogitech
Country: Canada
Mike,
Regardless of how skilled a photographer is, they have a style (good or bad).
When switching from a crop camera to a FF camera, the photographer's style does not change (good or bad). What happens is they shoot just as they did before. They frame things in exactly the same manner. In order to do so, they either move close or increase their focal length. It really is as simple as that and that is why everyone immediately notices a difference when they buy a FF camera.
cogitech
Country: Canada
gfiksel wrote:
Can anyone varify?
There is no dispute. The answer is incredibly obvious.
cogitech
Country: Canada
Let's look at scenario:
Photographer Joe has been using his 85mm "portrait" lens on his 1.6x crop factor camera. He likes the results, but he hears that FF cameras will give him less DOF, allowing him to isolate his subject more.
So, photographer Joe rents or buys a shiny FF camera. He wants to see how his portraits are going to look, so he goes out to the park with his kid and his 85mm "portrait" lens on his new camera.
He gets home and cannot believe his eyes. "Wow! look how shallow the DOF is!" His conclusion is that the DOF is shallower on his new camera.
We all know what really happened (don't we?).
He framed his subjects as he always did. His style has not changed, after all. In order to maintain the same shots that he did before, he moved closer.
Now, IMO, it doesn't really matter whether this DOF difference is due to the camera or due to the photographer. In fact, I think it doesn't even really matter if photographer Joe is aware that he is the cause of the reduced DOF.
cogitech
Country: Canada
Scenario 2 involves Photographer Jim.
Unlike Joe, Jim likes zoom lenses and he likes to shoot animals at the zoo. From the fence at the monkey cage, he often uses a setting of about 85mm on his 24-135mm lens to capture the monkeys with is 1.6x crop camera.
Again, he hears "somewhere" that FF will reduce his DOF and create a more blurred background.
So he gets a FF camera, slaps on his trusty zoom, and off the zoo he goes.
He shoots the monkeys as he always does (he really like monkeys), goes home and is amazed. "Wow!...."
But we all know what really happened, right?
He zoomed (changed the focal length) to 135mm, to maintain the same framing of his beloved monkeys. The focal length change directly affects the DOF.
Again, it was the photographer's reaction to the new format that changed the DOF, but that is irrelevant. The DOF changed.
CKrueger
gfiksel wrote:
Can anyone varify?
How can it be disputed when it's a simple, and easily demonstrable (see Michael's post) fact?
A nice easy way to think of the crop factor's effect on DOF is to use the crop factor to calculate aperture equivalence. Given these crop factors:
FF = 1.0
APS-H = 1.3
APS-C = 1.6
Four Thirds = 2
The following lenses will have almost identical AOV and DOF:
5D + 50/2.8
1DMk3 + 38/2.2
40D + 30/1.8
E-3 + 25/1.4
ghozer
PhotosByRDD wrote:
Chris M
Disagree. Using different lenses is fine. F/stop behavior doesn't change with the lens. In other words, f/4 is the same on a 70-200 f/4 as it is on an 85 f/1.2. The only thing that matters is that the same f/stop is used for the same field of view. Lens is irrelevant.
2 3 end
