       2       3       end
Archive 2011 · 35mm prime showdown
denoir
p.1 #1 · 35mm prime showdown
I've been planning for a while to make a formal comparative test of my four 35mm prime lenses and I finally got around to it today.
The lenses are:
1) Leica 35mm f/1.4 Summilux ASPH ("Lux35")
2) Zeiss 35mm f/2 Biogon ZM ("ZM35/2")
3) Zeiss 35mm f/1.4 Distagon Rollei ("ZR35/1.4)
4) Zeiss 35mm f/2 Distagon ZE ("ZE35/2")
(the lenses are always enumerated the same way which you'll see in the test image name)
The first two lenses were used on a Leica M9 and the last two on a Canon 5DII.
Mixing two camera systems was more complicated than I thought as:
1) Getting the same framing was difficult as the M9 and 5DII have different dimensions so just switching cameras on the tripod resulted in shifts in the framing.
2) Colors are different
3) White balance is different when set manually
I tried to work around those problems as best I could, but they are a source of variation between the shots - a lot in some and less in others.
Ok, the results. Open the images in separate tabs in your browser and flip between them.
Scene A:
http://peltarion.eu/img/comp/shoot35/A.jpg
f/1.4: Lux35 , ZR35/1.4
f/2: Lux35 , ZM35/2 , RZ35/1.4 , ZE35/2
f/2.8: Lux35 , ZM35/2 , RZ35/1.4 , ZE35/2
f/5.6: Lux35 , ZM35/2 , RZ35/1.4 , ZE35/2
Scene B:
http://peltarion.eu/img/comp/shoot35/B.jpg
Scene C:
http://peltarion.eu/img/comp/shoot35/C.jpg
Scene D:
http://peltarion.eu/img/comp/shoot35/D.jpg
Scene E:
http://peltarion.eu/img/comp/shoot35/E.jpg
f/5.6: Lux35 , RZ35/1.4 , ZE35/2
A couple of 100% crops from the above:
http://peltarion.eu/img/comp/shoot35/E-crop-1.jpg
http://peltarion.eu/img/comp/shoot35/E-crop-2.jpg
http://peltarion.eu/img/comp/shoot35/E-crop-3.jpg
For some reason I forgot to take a 35 Biogon shot which is a pity as I know from experience that it's the best performer stopped down - and not by a small margin.
Scene F:
http://peltarion.eu/img/comp/shoot35/F.jpg
Scene G:
http://peltarion.eu/img/comp/shoot35/G.jpg
Scene H:
http://peltarion.eu/img/comp/shoot35/H.jpg
Scene I:
http://peltarion.eu/img/comp/shoot35/I.jpg
Conclusions: My first conclusion is that tests like this are worthless Seriously, after using these four lenses for a while I have a much better and more general knowledge of what look they will give. There were some interesting things though of a technical nature to observe. Each lens has its strong points and weak points.
Leica 35 Summilux:
+Excellent performance across the frame
+Very nice sharpness-to-blur transition
+Good bokeh for the most part
-Dodgy bokeh on occasion
(-)Barrel distortion
Zeiss 35/2 Biogon:
+Über-sharp stopped down across the frame
+Zero distortion
-Dodgy bokeh
Zeiss 35/1.4 Distagon Rollei:
+Center sharpness
+Best bokeh of the lot
-Weak corners even stopped down
Zeiss 35/2 Distagon ZE:
+Good sharpness across the frame
+Decent bokeh
-Heavy vignetting wide open
The position of 'my favorite' is shared by the Summilux and the 35/1.4 Distagon. I somewhat prefer the rendering of the Distagon but the Summilux advantage in raw optical performance can't be ignored. Plus both are lenses that I use primarily handheld and for that purpose the M9 is much nice to use than the 5DII. So in the end I'm more likely to pick up the Summilux for walkaround photography.
Feb 24, 2011 at 07:07 PM
crazeazn
p.1 #2 · 35mm prime showdown
somebody please loan this man the new 35 1.4 when it comes out!
Feb 24, 2011 at 07:14 PM
abam
p.1 #3 · 35mm prime showdown
thanks for taking the time to compare these =)
Feb 24, 2011 at 07:30 PM
anscochrome
p.1 #4 · 35mm prime showdown
@Denoir-after taking a good look at your work at your website, you are doing some SUPERB photography. The very fact your are making exquisite use of these tools allows me to give a lot more credence to any conclusions you have to make about any set of lenses. For that I thank you.
In all honesty, if you had posted a bunch of poorly lit cat and dog photos to make your point, I probably not have given your website a close look, which would have been my loss, since I always enjoy looking at top notch practioneers in this field. Bravo!
Feb 24, 2011 at 08:19 PM
aleksanderpolo
p.1 #5 · 35mm prime showdown
The Lux35 on M9 is amazing, at F2 it makes the ZM looks like a Canon! On the other hand, your perfect frame matching make its distortion quite obvious when compared with ZM. Wish you have more F4-5.6 shot comparison with the ZM as it is at its sweet spot.
Feb 24, 2011 at 08:21 PM
sirimiri
p.1 #6 · 35mm prime showdown
As an aside - per your images, even the 35 Summilux causes red edges on the M9?
For $12,000 US....
Thank you for the comparison, though.
Feb 24, 2011 at 08:26 PM
denoir
p.1 #7 · 35mm prime showdown
Thank you for the kind words anscochrome!
@Aleksander, here are two ZM35 vs Lux samples that I posted in another thread:
Both @ f/2:
35 Lux @ f/2
35 ZM @ f/2
Both @ f/5.6 (I focus bracketed four shots per lens and picked the sharpest):
35 Lux @ f/5.6
35 ZM @ f/5.6
100% crop of the f/5.6 set:
http://peltarion.eu/img/comp/zcl/B-crop.jpg
In a way, I think those two examples are actually more representative of the difference in rendering - or at least that they highlight the important difference in style.
@sirimiri: Yep, the red edge is visible when you have snow and shoot at a wide aperture. You can remove it by using CornerFix but I left them as they were for the comparison shots.
This is what the color cast looks like after in-camera correction on an under-exposed white frame:
http://peltarion.eu/img/comp/shoot35/cast-1.jpg
It can be much worse - the uncorrected 25 Biogon:
http://peltarion.eu/img/comp/shoot35/cast-2.jpg
Fortunately CornerFix can be used to completely eliminate any color cast. Example:
Before CornerFix:
http://peltarion.eu/img/m9/zm25-50.jpg
After CornerFix:
http://peltarion.eu/img/m9/zm25-50b.jpg
Feb 24, 2011 at 08:42 PM
ken.vs.ryu
p.1 #8 · 35mm prime showdown
thanks for the effort denoir. I thought you had a Sony NEX? Even though it's a crop it would eliminate some factors and leave the lenses to do the work.
Feb 24, 2011 at 09:00 PM
denoir
p.1 #9 · 35mm prime showdown
Nope, never used a NEX. Yes, with a cropper you can avoid some problems at the edges, but at the same time you lose the really good stuff at the edges as well. When using good lenses, especially wides and ultra wides the lenses there is no substitute for FF.
Feb 24, 2011 at 09:41 PM
Sam N
p.1 #10 · 35mm prime showdown
That Biogon is great... it's a shame about the magenta corners. I didn't realize the Summilux had so much distortion, but I guess it only stands out when compared to the very low distortion from the Biogon.
All we need to add now are the 'Cron-M ASPH and the 35L.
Feb 24, 2011 at 10:21 PM
Ed Sawyer
p.1 #11 · 35mm prime showdown
It's hard to beat a non-retrofocus design (e.g. rangefinder lenses). Thanks for the comparison.
Feb 24, 2011 at 10:23 PM
charles.K
p.1 #12 · 35mm prime showdown
Excellent stuff Luka!
Feb 24, 2011 at 10:43 PM
spicythai
p.1 #13 · 35mm prime showdown
Very helpful examination. Thank you for your effort, Luka.
Feb 24, 2011 at 11:07 PM
bluetsunami
p.1 #14 · 35mm prime showdown
The 35Lux looks nice and bright wide open too but I agree about the overall rendering of the Zeiss 35/1.4 is more pleasing to the eye (for me that is).
Edited on Feb 25, 2011 at 02:41 AM · View previous versions
Feb 24, 2011 at 11:15 PM
jpeter
p.1 #15 · 35mm prime showdown
Luka, MANY inspiring shots on the slide show on your web site. Wow
JP
Feb 25, 2011 at 01:21 AM
sirimiri
p.1 #16 · 35mm prime showdown
I know Cornerfix can clean up the files - my buddy gave me a half-hour tutorial once...I was chagrined though, to see such a marked problem. My point was more along the lines of "people accept this from a twelve-thousand dollar setup?" :/
I agree with you, about edges containing "good stuff"...it's a pity to lose it on cropping, sometimes.
(even with red edges, I wish I had your setup, the delicious street images that could be taken here...)
Feb 25, 2011 at 01:58 AM
Bifurcator
p.1 #17 · 35mm prime showdown
Nice!
I would have loved to see other brands included as well.
Especially Nikkor and Rokkor.
Feb 25, 2011 at 02:11 AM
pdmphoto
p.1 #18 · 35mm prime showdown
Thanks for the comparison. Very nicely done.
My Rollei/Zeiss 35/1.4 seems to do much better at the edge of the frame, at f/5.6. Could it be an adapter issue? I use the hard to find Kindai adapter.
The Rollei/Zeiss is the only one being used with an adapter, so it may be at a disadvantage
Feb 25, 2011 at 02:22 AM
singletrack
p.1 #19 · 35mm prime showdown
Awesome stuff luka!
KL
Feb 25, 2011 at 03:01 AM
mortyb
p.1 #20 · 35mm prime showdown
Excellent. Thanks. And as always, great shots.
Feb 25, 2011 at 03:37 AM
       2       3       end
       2       3       end
