Archive 2011 · Least distorting 24mm?
hnaa
p.1 #1 · Least distorting 24mm?
I am looking for a 24mm lens for use on my D3. I will be using it mostly for landscape and architecture. When I can afford it I'll get the Nikon 24mm PC-E, but until then, I would like to find a nice manual focus lens. For my applications I will mostly be shooting at f/8-13, and I guess most 24mm primes will be very sharp at these apertures. However, I would like to get the lens with the absolute minimum of distortion, any suggestions?
Feb 13, 2011 at 05:22 AM
ken.vs.ryu
p.1 #2 · Least distorting 24mm?
here's how the olympus 24 and nik 17-35 does
http://www.16-9.net/lens_tests/24mmcup/final/24mm_final11.html#
Feb 13, 2011 at 10:33 AM
carlitos
p.1 #3 · Least distorting 24mm?
Zeiss ZF 25mm f2.8?
Feb 13, 2011 at 02:39 PM
AhamB
p.1 #4 · Least distorting 24mm?
carlitos wrote:
Zeiss ZF 25mm f2.8?
I thought about suggesting that, but I don't know anything about it's distortion characteristics...
Feb 13, 2011 at 04:07 PM
alundeb
p.1 #5 · Least distorting 24mm?
Distortion characteristics for many lenses, mostly mainstrem ones, are available at the lowest of the moronic and useless test sites, photozone.de [/sarcasm]
The ZF 25/2.8 distorts 1.8% (on the 5DII)
I don't have direct experience with many alt wides, but have a sense that asking for a low distortion alt wide is like asking for the highest mountain in Denmark Don't get me wrong, it is a legitimate question, and likely someone have good suggestions, but is far as I know, most manufacturers deliberately avoid strong correction for distortion, in a trade for other characteristics.
How do you find the distortion in a zoom? Most zooms in the 16-40 range have a sweet spot with respect to distortion around 24 mm, with barrel below and pincushion above.
Feb 13, 2011 at 04:26 PM
Makten
p.1 #6 · Least distorting 24mm?
The good old Nikkor 24/2.8 (AI, AI-S and AF) has quite low distortion actually. And stopped down to f/8-11 it's also sharp enough for most applications. My only gripe with it, is the dull colors and slight greenish cast.
Feb 13, 2011 at 04:54 PM
