Archive 2011 · Ideal 0.5, 1.0, 1.5kg lens set?
jotdeh
p.1 #1 · Ideal 0.5, 1.0, 1.5kg lens set?
I think this will be interesting... consider you will be travelling (backpacking or hiking so you have to take everything with you at all times) what lenses would you choose? Of course it depends on the places you go (landscape, street) but let's just say "for your style".
I'm on a 5DII, but it would be interesting to see what other systems you come up with (NEX, m43, M9...). The 5D is 0.8kg, so if you take a lighter body feel free to use the weight savings towards lenses!
500g
1000g
1500g
2000g
here are mine:
0.5kg
CY Zeiss 35-70/3.4 (475g)
Adapter (25g)
total: 500g
1kg
CY Zeiss 100/3.5 (286g)
CY Zeiss 50/1.7 (195g)
Adapter (25g)
total: 981g
1.5kg
CY Zeiss 21/2.8 (530g)
Adapter (25g)
total: 1501g
2.0kg
CY Zeiss 100-300/3.5-5.6 (925g)
2 adapters (50g)
total: 1980g
ok, I'd probably sneak in one adapter per lens, but trying to keep close to the limits
Feb 11, 2011 at 08:44 PM
mpmendenhall
p.1 #2 · Ideal 0.5, 1.0, 1.5kg lens set?
I see your choices are rather "heavy" on the Zeiss
For a highly versatile ~1.5kg system:
Zuiko 21/3.5 185g
Contax 35/2.8 240g
Zuiko 50/2 Macro 320g
Contax 85/2.8 260g
Voigtlander APO 180/4 485g
= 1490g + adapters
Feb 11, 2011 at 09:49 PM
Steve Spencer
p.1 #3 · Ideal 0.5, 1.0, 1.5kg lens set?
For backpacking the kit I am looking to put together is
Panny GH2 - 392g
Olympus M Zuiko 9-18mm f/3.5-5.6 - 155g
Panny 20mm f/1.7 - 100g
Contax G 45mm f/2 - 190g
Contax G 90mm f/2.8 240 g
adapter 25g
Total - 1077g or a little over 200g lighter than your 5D2 and 35-70 kit and you have the equivalent of pretty good coverage from 18 to 180.
Feb 11, 2011 at 09:59 PM
uhoh7
p.1 #4 · Ideal 0.5, 1.0, 1.5kg lens set?
For nex
16mm 65g
21 CV f/4 136g
35 CV f/2.5 116 g
55 Industar 61 LD f/2.8 129g
74 CV f/2.5 230g
100 Canon f/3.5 LTM 184g
6 primes for 860 grams and about 1100usd.
the 16 is OK, but the other 5 are very good glass.
beat that !
Feb 11, 2011 at 10:07 PM
alexandre
p.1 #5 · Ideal 0.5, 1.0, 1.5kg lens set?
474g:
e-pl2 + batt + card 362g
14-42 112g
971g:
474g kit
Zuiko 21/3.5 185g
Zuiko 50/1.2 310g
1545g:
5D 895g
Tamron 28-75 510g
Zuiko 40/2 140g
2010g:
5D 895g
Zuiko 21/3.5 185g
Tamron 28-75 510g
Zuiko 50/1.4 230g
270EX 190g
Feb 11, 2011 at 10:56 PM
philip_pj
p.1 #6 · Ideal 0.5, 1.0, 1.5kg lens set?
Oh, I'll play also. Important to balance IQ with weight, and for travel and landscape it does not get any better than CZ, IMNSHO. And FF/tripod is great for any potential killer images with high enlargement potential or cropping, for the kind of shot that simply cannot be re-shot later on. I'm using a Sony A900 but with virtually the same setup, great minds eh?
1. 1000 grams
28/2.8 Contax (280 grams)
35-70/3.4 (500 grams)
100/3.5 Contax (290 grams)
2. 1500 grams
21/2.8 Contax (580 grams)
3. 2000 grams (my mountains kit)
Minolta 200/2.8 APO HS (790 grams)
Minolta 1.4 TC APO (170 grams) for 280/4 eq.
All these lenses are good enough to force me to shoot no matter how much AMS or fatigue I am suffering!
If Leitax can help, the 100-300mm Contax is to replace the 200mm Minolta/TC, as much for flexibility in focal length as for the Zeiss look and killer short end performance. The 100/3.5 will then stay behind for light backcountry work to help get the weight penalty down.
Feb 12, 2011 at 01:01 AM
ManWearPants
p.1 #7 · Ideal 0.5, 1.0, 1.5kg lens set?
All exceed the weight limit but will mount nicely on 5D and FF.
627g:
Zuiko 21/3.5, 185g
Contax N 50/1.4, 310g
Kenko 1.4x TC, 132g
1195g:
Distagon 35/1.4, 600g
Planar 85/1.4, 595g
1580g:
Zuiko 18/3.5, 250g
Contax N 24-85, 570g
Canon 70-200/4 IS, 760g
2390g:
Contax N 17-35, 900g
Canon 70-200/2.8 IS II, 1490g
Feb 12, 2011 at 03:36 AM
slungu
p.1 #8 · Ideal 0.5, 1.0, 1.5kg lens set?
Well I'll play too, with 3 primes sets :
500g category, good for the NEX:
Voigtlander Heliar 15mm/4.5 105g
Zeiss ZM Biogon 35mm/2.0 240g
Voigtlander APO-Lanthar 90mm/3.5 260g
Total 605g
If we replace the Biogon with the Skopar at 135g we get a 500g combination
Under 1kg combination for FF :
Zeiss Distagon 28mm/2.8 280g
Zeiss Planar 50mm/1.7 195g
Zeiss Sonnar 85mm 2.8 260g
Total 735g
1,5kg top combo for FF :
Zeiss Distagon 28mm/2.0 530g
Zeiss Planar 50mm/1.4 290g
Zeiss Planar 100m/2.0 670g
Total 1490g
Hm, seems like I am a Zeiss fan . Actually, I had combo 3 and now I am running around with combo 1 on a NEX.
Feb 12, 2011 at 11:58 AM
JimU
p.1 #9 · Ideal 0.5, 1.0, 1.5kg lens set?
this is interesting, here's mine
sony a900: 895g
500 gram-ish category (which I've done on a 4 day trip to Philadelphia)
474g - Minolta 58/1.2
474g - Total
1,000 gram-ish category (which I've done on a 7 day trip to New York City)
490g - Minolta 35/1.4
315g - Minolta 50/2.8 Macro
560g - Minolta 85/1.4
1,365g - Total
This kit was mostly experimental, I didn't really use the 85, and the 50 Macro could have been totally replaced by the 35. In the future I would do this:
285g - Minolta 20/2.8
290g - Leica 50/2
1,065g - Total
1,500 gram-ish category (which I've done on a 21 day trip to China)
790g - Minolta 200/2.8
1,549g - Total
i think i like my 20, 50 & 200mm kit the best.
Feb 12, 2011 at 12:36 PM
jotdeh
p.1 #10 · Ideal 0.5, 1.0, 1.5kg lens set?
I agree it doesn't seem to be in the spirit of alternative gear (which, imo, is to choose the "best" from all options, for a certain purpose and budget), but I do think it gives the best IQ per weight performance. If more flexibility is required then the Zuiko 18 or 21 (to save weight on the Zeiss 21) and Canon 70-200 F4 IS (to save weight over the 100-300 and reduce need for a tripod), would be my next choice.
philip_pj, what tripod and head do you use?
Panny GH2 - 392g
adapter 25g
That is very impressive! Could add a Contax G and a few rolls of film for even more flexibility in terms of look and as backup, at 6-700g weight penalty.
Feb 12, 2011 at 01:07 PM
Bifurcator
p.1 #11 · Ideal 0.5, 1.0, 1.5kg lens set?
Tamron SP 17-50/2.8 ..................................... 430g
SMC Pentax-FA J 75-300mm F4.5-5.8 AL ............ 385g
#3 58mm Closeup filter ................................... 25g
Pentax K5 ..................................................... 670g
1510g
Feb 12, 2011 at 01:11 PM
Bifurcator
p.1 #12 · Ideal 0.5, 1.0, 1.5kg lens set?
For actual backpacking tho:
• 5x zoom
• 11 elements in 9 groups (5 aspherical elements)
• 5-25mm (approx. 28 - 140mm in 35mm format) F3.5 - F5.5
157g
http://www.digitalcamera.jp/html/HotNews/image/2011-02/09/P1050873-L.JPG
Feb 12, 2011 at 03:40 PM
