Archive 2011 · Q about ZE 21 & 100
joeisayo
p.1 #1 · Q about ZE 21 & 100
I just picked up the Zeiss ZE 21 and 100. Can someone tell me how to activate the AF confirmation on my 5D II?
Thanks!
Feb 10, 2011 at 09:27 PM
crazeazn
p.1 #2 · Q about ZE 21 & 100
half press and when its in focus it should beep
Feb 10, 2011 at 09:55 PM
joeisayo
p.1 #3 · Q about ZE 21 & 100
Thats the first thing I tried with no success.
Feb 10, 2011 at 09:59 PM
crazeazn
p.1 #4 · Q about ZE 21 & 100
thats odd, it should just work
Feb 10, 2011 at 10:00 PM
mikek200
p.1 #5 · Q about ZE 21 & 100
Check the settings in the camera menu,maybe its turned off??
Feb 11, 2011 at 12:54 AM
Makten
p.1 #6 · Q about ZE 21 & 100
Are you normally using the thumb for focusing? I suppose that won't work.
Feb 11, 2011 at 04:29 AM
johntodd
p.1 #7 · Q about ZE 21 & 100
Joe,
Going back to basics, are you in single-shot focus mode? I don't believe it'll confirm in servo mode. Then, all I do is to hold the shutter release half-pressed and turn the focussing ring until the appropriate red box lights up.
Feb 11, 2011 at 09:09 AM
adamdewilde
p.1 #8 · Q about ZE 21 & 100
It's a setting in the menu system.
Feb 11, 2011 at 10:44 AM
AhamB
p.1 #9 · Q about ZE 21 & 100
Isn't that only for the AF-points (lighting up red)? I thought you can't turn off the green focus confirm light on the right.
Feb 11, 2011 at 12:05 PM
joakim
p.1 #10 · Q about ZE 21 & 100
I don't think it's a setting either and AI server mode is always disabled with a MF lens isn't it?
One possibility is if you have automatic AF point selection active then the confirmation light will only work if you focus using the center AF point.
Feb 11, 2011 at 12:27 PM
Mirek Elsner
p.1 #11 · Q about ZE 21 & 100
Does it work on your Canon AF lenses switched to MF?
Feb 13, 2011 at 12:14 PM
Caldiar
p.1 #12 · Q about ZE 21 & 100
It has something to do with the custom function IV 1 (Operations/Others, Shutter button/AF-ON button). The beep can be turned on in the first menu.
Feb 13, 2011 at 03:18 PM
jdben622
p.1 #13 · Q about ZE 21 & 100
Is the problem that it works for your other lenses, but not the ZE lenses? If that's the case, then you have an issue with the lenses (although that would be odd with 2 lenses). The ZE lenses act just like any other EF lenses. I use my thumb for regular focus and get focus confirmation with ZE lenses using my thumb.
Feb 13, 2011 at 03:24 PM
joeisayo
p.1 #14 · Q about ZE 21 & 100
Apparently there is a defect as the AF light does not come on even with the EF lenses. I guess I never noticed it.
Feb 13, 2011 at 10:56 PM
crazeazn
p.1 #15 · Q about ZE 21 & 100
what camera?
Feb 14, 2011 at 09:44 AM
Lars Johnsson
p.1 #16 · Q about ZE 21 & 100
crazeazn wrote:
what camera?
The camera he wrote in his post of course
Feb 14, 2011 at 09:50 AM
