       2       3       …       5       6       end
Archive 2010 · T-stop depends on sensor design
Empire
p.1 #1 · T-stop depends on sensor design
Interesting analysis and conclusions by DxO regarding loss of light gathering ability at wide apertures (1.2 and 1.4) as a function of sensor design and how camera makers get around this to give correct exposures.
http://www.dxomark.com/index.php/en/Our-publications/DxOMark-Insights/F-stop-blues
Over at LL there was mention of the possibility that the light gathering angle could also affect depth of focus. Apparently DxO is investigating this.
Food for thought - although I'm not giving up my fast glass any time soon thank you
Dec 13, 2010 at 12:56 PM
Empire
p.1 #2 · T-stop depends on sensor design
LL's write up on the subject
http://www.luminous-landscape.com/essays/an_open_letter_to_the_major_camera_manufacturers.shtml
Dec 13, 2010 at 12:57 PM
HerbChong
p.1 #3 · T-stop depends on sensor design
the effect of a sensor on light gathering power to light rays that aren't perpendicular to the sensor plane isn't exactly a secret. the effective aperture of the sensor's wells is a well known design-time specification and that is why the big deal over back-illuminated sensor fabrication techniques. same with the falloff from the lens axis that is steeper than the lens's falloff on film. it's the overall compensation for it based on aperture that isn't well known.
Herb...
Dec 13, 2010 at 01:28 PM
cogitech
p.1 #4 · T-stop depends on sensor design
Yet another reason to keep lovin' my 5D.
The conclusion of the DxO chief scientist: "I am therefore inclined to question the real benefit of faster lenses.” - Spoken like a true scientist.
Dec 13, 2010 at 01:56 PM
Lotusm50
p.1 #5 · T-stop depends on sensor design
Hmm. I wonder what he considers to be the "true benefit of faster lenses" to be.
Dec 13, 2010 at 02:15 PM
HerbChong
p.1 #6 · T-stop depends on sensor design
well if the idea is to shoot a lower ISO with a wider aperture to preserve noise then what is the point? it's not the only or even necessarily the main use of fast lenses but it is in fact one justification for having one.
Herb...
Dec 13, 2010 at 02:52 PM
cogitech
p.1 #7 · T-stop depends on sensor design
Herb...
So, if you remove that one benefit, would you be inclined to "question the real benefit of faster lenses"?
No, I didn't think so.
Dec 13, 2010 at 02:58 PM
Romain
p.1 #8 · T-stop depends on sensor design
I don't think much people on the alt forum are looking for extremely high speed, most are looking for short depth of field.
And I don't get their conclusions either. Yes a T stop is not a F stop, and the T stop is different on each camera. But on a given camera a f/1.4 lens will still be faster and have a shorter depth of field than an f/2 lens, and that's all that matters.
Finally I don't think there is any influence on the depth of field, and if there is one its easy to prove: shoot the same lens on a film camera, and one - or several - digital camera. I'm still waiting for evidences rather than cryptic maths =p
Dec 13, 2010 at 03:03 PM
cogitech
p.1 #9 · T-stop depends on sensor design
Indeed. In this age of ISO 12,000,000 (or whatever it is at now) I really do not think anyone can imagine that speed is the only (or even primary) benefit of large aperture lenses (except scientists, I guess).
Dec 13, 2010 at 03:21 PM
edwardkaraa
p.1 #10 · T-stop depends on sensor design
Having shot both film and digital until recently (2 years ago) I too have noticed shallower DOF and more vignetting with digital.
Dec 13, 2010 at 04:09 PM
HerbChong
p.1 #11 · T-stop depends on sensor design
i sometimes shoot in situations where it and only it matters. however, it doesn't happen enough that i am going to do anything about it.
Herb...
Dec 13, 2010 at 05:16 PM
Empire
p.1 #12 · T-stop depends on sensor design
This is a result of the 'depth' or thickness of the film's emulsion which helps record rays at slightly different focal distances points as being focused.
IIRC this affects the presence of CA too.
To the comentators on horseback - good on you. I never said this revolutionary info.
Dec 13, 2010 at 10:10 PM
AhamB
p.1 #13 · T-stop depends on sensor design
I'm surprised that no one has brought up the point that most DSLR's increase the sensor gain to compensate for the loss of light at wide apertures (anything below f/4). This only works with electronically coupled lenses of course.
Dec 13, 2010 at 10:22 PM
theSuede
p.1 #14 · T-stop depends on sensor design
It (the thread title) is also one of the few remaining "very good" reasons for going recommending FF/FX cameras, since the actual, TRUE gain you get is even bigger than what just the area theory says when you shoot at large apertures.
Modern high-density APS cameras loose so much light at large apertures that they're almost a full stop down in T-stop measurements.
This means that a 5D2 with a 135F/2L @ F/2.4 (!) actually gathers more light than a 7D with an 85L @ F/1.2.... So if you REALLY need the low-light capability at medium-short reach, then FF is a much better and also CHEAPER alternative!
The 135F/2 w. 5D2 gathers almost 2/3Ev more light than the 7D w. 85F/1.2L.
The 85F/1.8 w. 5D2 gathers almost 2/3Ev more light than the 7D w. 50F/1.2L.
The 50F/1.8 w. 5D2 gathers almost a full Ev more light than the 7D w. 35F/1.4L.
Not to mention that the FF/FX combos also will be sharper, cheaper and sometimes also lighter in weight...
When you get to F/2.8+ this advantage is gone, though. So if the main bulk of shooting is at F/4.0 or higher, then reach and lens availability is of more importance than sensor size when choosing your main system.
Dec 14, 2010 at 06:47 AM
melanopsin
p.1 #15 · T-stop depends on sensor design
I am baffled and confused by this.
Consider two faster-than-f/4 lenses with identical T-stop, one manual focus lens, and one lens with aperture coupling (electronic or otherwise). With constant camera ISO and shutter speed settings, photos made with each lens will have different exposures? If camera 'knows' a fast lens is attached and aperture setting is less than f/4 the ISO (sensor sensitivity, gain) is boosted so my ISO 100 photo is actually ISO 160 (or whatever boost is)? Is there is a noise trade-off in low light, the manual focus lens requires longer exposure time (more noise), the auto lens less exposure time but more noise due to increased sensor gain? Is sensor gain increased or is sensor signal multiplied by some factor by hardware/software?
Dec 14, 2010 at 08:52 AM
hans98ko
p.1 #16 · T-stop depends on sensor design
Now! You see why many EF 50mm f1.2L users complained about the lens is not much better than the EF 50mm f1.4 or even the cheapy EF 50mm f1.8?
Only those who have the extra cash and not know how to spend it will buy into the marketing gimmick.
Even at the local Canon Regional Head Office, they use the very reliable and cheapy EF 50mm f1.8 II for testing. Or maybe they can't afford to use the EF 50mm f1.2L , for those who think that if someone don't use it is because they can't afford it.
For those who use the AIS 50mm f1.2 on film cameras will be a different story.
Now you see why Nikon or Sigma never bother to come up with a 50mm f1.2 for DSLR? Maybe the difference is just too minute.
Time to go horseback riding for more information and shoot moving targets.
Dec 14, 2010 at 09:17 AM
cogitech
p.1 #17 · T-stop depends on sensor design
Why? It is all explained in the article. There is nothing baffling or confusing about it. It is simple physics.
Yes, exactly, because the camera increases the gain to compensate for light loss.
Yes.
6 of one and half a dozen of the other.
Gain is increased, according to DxO.
Dec 14, 2010 at 09:45 AM
cogitech
p.1 #18 · T-stop depends on sensor design
No, I don't see this at all. I don't think this has anything to do with someone concluding that the 1.2L is not better than the other Canon 50s.
I completely disagree. You seem to think that more light is the only benefit of faster lenses. It is not a gimmick at all. Are you a scientist, perchance?
For testing what, and how is that relevant at all to the discussion at hand?
I can't afford the EF 50/1.2 L, but this does not mean I somehow try to explain away the benefits of f1.2 lenses. Instead, I buy and use f1.2 lenses that I can afford.
Exactly 0.25 Ev different than my 5D + Rokkor 58/1.2. I can correct for this with EC or ISO bump and still have a much cleaner, more detailed result.
No, I don't.
Dec 14, 2010 at 09:54 AM
hans98ko
p.1 #19 · T-stop depends on sensor design
I thought that you have read and understood the link well regarding about wider aperture opening does not mean more light falling onto the sensor (depends on micro lens convex angle and the dept of the light well). And also about the gain boost adjustment by each individual manufacturers (the slight aperture advantage can always be taken care by gain boost). Also there is this so call CA error kicking into effect.
Regarding the other disagreements, I can always agree to disagree with each other. No one are born equal even for twins.
But one thing we have in common and that is we still kept our antique EOS 5D, almost sold it if not for the low price it can fetch. So decided to keep it as a backup and snap shooter.
Dec 14, 2010 at 10:14 AM
cogitech
p.1 #20 · T-stop depends on sensor design
Apparently you, like the scientist at DxO, assume that increased light is the only benefit of large aperture lenses. I know this is not the case, therefore I disagree with any conclusions based on that assumption.
Dec 14, 2010 at 10:32 AM
       2       3       …       5       6       end
       2       3       …       5       6       end
