Archive 2010 · SB-600 problems
artemk
p.1 #1 · SB-600 problems
Hi, all!
Having problems with my SB-600 - it won't stay open at angles, including 90 degrees. Pretty light touch closes it to 0, where it still locks.
Not sure when it started - I don't recall anything that I did to cause that, but I sure could have.
Have anybody ad a problem like this? Is there a fix for that?
Thanks.
Nov 21, 2010 at 09:59 AM
artemk
p.1 #2 · SB-600 problems
Bump... Anybody? Any ideas?
Thanks.
Jan 18, 2011 at 05:48 AM
cputeq
p.1 #3 · SB-600 problems
Sounds like it's been stripped, maybe by repeated use or it had a hard knock on it while angled?
I'd probably check with Nikon for a repair estimate.
If it's too expensive to repair, you could either sell it with the caveat it's pretty much stuck at the default angle (which really wouldn't bother a lot of umbrella shooters), or make it your umbrella / light box stand flash
Jan 18, 2011 at 06:41 AM
artemk
p.1 #4 · SB-600 problems
Well, I am sure there are few people around here who taken them apart. I would not mind trying to repair it myself - I can't see Nikon charging acceptable amount for repair (considering new SB600s are under $200)
I was also given a Gary Fong diffuser as a Bday present, which works surprisingly well (but it also surprisingly big ). So the flash problem is less of a problem, more of an annoyance.
Jan 18, 2011 at 06:52 AM
cputeq
p.1 #5 · SB-600 problems
Yeah were it *me*, I would try to take it apart - but that's me.
It could just be a locking / tension mechanism popped loose, and I can't imagine flashes being too terribly complex to assemble.
Jan 18, 2011 at 07:00 AM
artemk
p.1 #6 · SB-600 problems
I sure don't have any problems taking it apart, but at the same time I want to be somewhat prepared to what I need to do.
I won't even start on how many things I've taken apart to get bored with it and not put back together
Jan 18, 2011 at 07:06 AM
artemk
p.1 #7 · SB-600 problems
Thanks to google and a some russian discussion board just downloaded a repair manual for SB600. Will make a nice project once I will get a bit more time.
Jan 18, 2011 at 07:29 AM
arthurman
p.1 #8 · SB-600 problems
I have a couple of SB600s. Can you post a link to the repair manual site. Might be a good resource to have going forward.
Thanks
Jan 18, 2011 at 07:41 AM
artemk
p.1 #9 · SB-600 problems
Don't get too scared by Russian on the page...
http://narod.ru/disk/1071975001/SB600rm.rar
wait for countdown, then enter digits into captcha field.
You'll need WinRAR to open the file.
Jan 18, 2011 at 08:05 AM
DABNIK
p.1 #10 · SB-600 problems
Well - that's a fun exercise, trying to navigate a web site in Russian
Please let us know how you make out. It seems like it should be a simple fix.
I have a SB600 I bought used about a year ago but it works perfectly.
Good luck
Jan 18, 2011 at 10:44 AM
arthurman
p.1 #11 · SB-600 problems
I couldn't find the download button, as I don't read Russian.
Jan 18, 2011 at 11:20 AM
artemk
p.1 #12 · SB-600 problems
Just enter the numbers into the verification field and push the green button. Wait for countdown to end and download would start automatically.
Hope this helps.
BTW, Google Chrome should be able to translate the site automatically. Probably not perfect, but acceptable. Can't really verify - I turned translation off for Russian, but for German sites it works pretty good.
Jan 18, 2011 at 11:23 AM
DABNIK
p.1 #13 · SB-600 problems
And - once you dl the manuals, they are in several languages. I would em them to you but they are very large.
Jan 18, 2011 at 11:26 AM
unrlmth
p.1 #14 · SB-600 problems
Hope this helps.
I have chrome and it did a pretty good job on that site. Definitely enough to understand how to download it.
Jan 18, 2011 at 11:51 AM
arthurman
p.1 #15 · SB-600 problems
Mine doesn't seem to download. Not sure what's going on. Oh well.
Jan 18, 2011 at 12:00 PM
artemk
p.1 #16 · SB-600 problems
Hope this is not going to cause problems...
Here is REPAIR MANUAL
and PARTS LIST Parts LIST
Jan 20, 2011 at 09:15 AM
arthurman
p.1 #17 · SB-600 problems
Thanks for posting them. I did get them to download finally. I found out it was being blocked at my office. Got it to work at home. Unfortunately, I'm the IT guy at work, so I get to blame myself.
The manuals are nice to have though.
Alvin
Jan 20, 2011 at 09:51 AM
NightOwl Cat
p.1 #18 · SB-600 problems
Thanks Art!
Jan 20, 2011 at 09:54 AM
artemk
p.1 #19 · SB-600 problems
I would not blame you too much. Some stuff you get from some Russian sites is quite nasty. While a lot of people can judge pretty good, quite a few still install those wonderful Registry Cleaners and fake Antivirus programs... Now, when I started to think about it, it' not only Russian sites that have that cr@p...
Jan 20, 2011 at 10:03 AM
norrad
p.1 #20 · SB-600 problems
Thanks for posting the links. I just picked up an SB-600 which is missing the diffuser panel. It still zooms in manual mode, but cannot be used in full auto TTL mode at anything but 14mm as the diffuser is missing.
As soon as I find where to buy the diffuser and spring I'll be putting this manual to use!
Darron
Jan 21, 2011 at 02:45 PM
