kakomu Offline Dedicated FM Upload & Sell: On
Lance Lee wrote:
I think there is a lot of confusion on this subject, because there are two things going one, the physics of it and the practical part of it.
Technically the format doesn't effect DOF, but in practice the size of your sensor/film will effect your DOF and background blur. Both are true.
I think the biggest thing you would notice is how the camera's work. In some ways the 5D interface is more straightforward, but I've found in practice I'm far more comfortable with the 1D2 than 5D/40D/20D, etc. Then there is the AF system, which is night and day different.
Technically speaking, the format dictates the DoF as DoF is a concept based upon how a final image looks, whether it's printed or viewed on a monitor.
Lenses have a two dimensional plane of focus, which means there's absolutely no thickness. Given a lens with no medium, all you can measure is the distance from the lens where absolute focus is achieved and the maximum cone of light that can enter or exit the lens. The medium is necessary to determine the characteristics of the DoF for a given lens.
andrew81 wrote:
I was sure I read somewhere that larger formats give a shallower DOF but the distance thing seems more plausible and logical though.
There goes my justification for a 5D lol Might just buy myself a new prime lens.
The problem with most discussions about DoF and camera sensor size is that the variables are NOT controlled very well in the discussion. Most discussions on DoF attempt to either maintain angle of view or framing of a subject. So, between two cameras with different mediums, multiple factors will be adjusted at the same time.
If you attempt to adjust the camera to maintain framing, you'll change the subject to camera distance. If you attempt to maintain the angle of view, you'll change the focal length. With uncontrolled variables comes a bunch of confusion on the subject and unscientific conclusions.
In general, all things remaining the same, a smaller format will have a shallower DoF. However, in practice, this shallower DoF is typically canceled out by all of the other factors that you would change in order to take a picture with a crop format. E.g., by standing further away from the subject, you increase DoF. By using a shorter focal length (35mm on Crop, vs. 50mm on full frame), you increase DoF. It's these factors that account for the increased DoF that you encounter with a crop camera over a full frame camera.
Edited on Sep 08, 2010 at 10:59 PM · View previous versions
