drumminj Offline Upload & Sell: Off
if you use AV mode, the shutter speed is set to properly expose the background, and the flash will expose your subject properly (whatever's under the focus point).
You'll have to use either manual mode, or P mode. I think you can turn the dial in P mode to scroll through the different program settings - which may allow for you to have the aperature stopped down a bit more. I never use P mode, though, so I'm not sure.
