fredmiranda.com Login
Trade safely
This topic is in the 2010 archive. You can read it and like its posts here. It is read only.
Archive 2010FSContax C/Y Distagon 15mm f3.5
Jim Gilley
p.1 #1FSContax C/Y Distagon 15mm f3.5
Here's one you don't see everyday. Let me begin by apologizing for the truly horrible photos. I'm in a really bad situation right now and simply don't have the equipment to properly clean, light or photography my equipment. This lens is in great shape, despite how dusty it looks here.
http://static.grumpysworld.com/15_side.jpg
This is a Contax Zeiss 15mm f3.5 T* Distagon rectilinear ultrawideangle prime originally designed for the Contax/Yashica mount. It has an adapter on it that allows it to be mounted to certain Canon EOS bodies.
Note that some Canon EOS bodies cannot use this lens because the mirror interferes with the rear element (notably the 5D and 5D2). I used this lens on a 1Ds and it worked beautifully. I no longer have a body suitable for this lens and never did use it enough even when I did.
http://static.grumpysworld.com/15_front.jpg
It comes with the original front cap and a genuine Canon rear cap. The lens hood is built in. I do not have a box or manuals.
I think the EOS adapter can be removed to reveal the original C/Y bayonet of the lens, but I lack the tools to do so. I have never removed the adapter, so I cannot be totally sure that it isn't permanently attached, but I believe it can be removed with a set of jewelers screwdrivers.
http://static.grumpysworld.com/15_back.jpg
The glass is flawless, in spite of all the crud you see in these images. As I said, I'm in a really bad situation where I can't clean this lens. You wouldn't want me to use a sponge and dish soap, would you? Hence, what you see in these pathetic photos is just ordinary dust on the outside of the glass, which could be easily removed with a soft brush or blower (both of which I lack).
The body of the lens is very nice with no scratches or scuffs. The only thing I don't like about it is that it oozes a tiny bit of glue around the rubber focus ring every once in awhile and this attracts lint and leaves boogers along the smooth metal surface next to it. It's not really a defect so much as an annoyance. You could probably clean this up if you had a soft cloth and some alcohol. The focus ring itself is just fine and you never need to use it anyway.
Using this lens is dirt simple. Set the focus at infinity, set the aperture at f8, adjust your shutter speed to the light conditions and shoot. It's amazing how much wider 15mm is than 16mm. I wish I had some nice shots to show you, but truthfully, I'm such a lousy photographer that my results with this lens are pretty pathetic and it's not the fault of the lens.
I bought this lens used from mark1958 right here on fm quite a few years ago. My recollection was that I paid $3500 for it. I have used it very little over the years, and not at all in the past three years. It is a superb lens, but I'm simply not a good enough photographer to need such a thing.
I see a few of these on eBay from time to time, and they generally go between $2500 and $3000. I'd like $2000 for mine, and I'll pay the PayPal fee and ground shipping. This is such an odd/rare lens that I don't know if anyone is interested or not. If not, I'll probably just keep it, since I'm already taking a huge bath on it and can easily put it back in storage for a few more years. Still, it seems a shame that such a fantastic lens can't find an equally fantastic photographer to make good use of it.
Please PM me for more information, but be aware that I really can't get you any photos of this lens that are better than I posted here, but I will answer whatever questions you have. Thanks!
Jul 07, 2010 at 06:23 PM
