       2       3       4       5       end
Archive 2010 · Zeiss 135/2.8 opinions??
Edgar M
p.1 #1 · Zeiss 135/2.8 opinions??
Planning to get a ZE 50 1.4 and wanting to match it with another Zeiss of at least double focal length or longer (100mm or 135mm). I really want a 100/2 MP but will be low on money after a ZE 50mm purchase and need something much more inexepensive.
How is the Contax/Yashica Zeiss 135mm 2.8?? I notice it is very inexpensive.
This will be used on a 5d2
Apr 16, 2010 at 09:52 AM
debuggerus
p.1 #2 · Zeiss 135/2.8 opinions??
It's a great value in my opinion. There are so many excellent 135/2.8s but I rank it on the upper end. If you want the zeiss look and cheap, the 50/1.7 and the 135/2.8 are the ones.
I prefer the MM version over the AE due to its non-ninja blade shape but others prefer the AE.
A shot on A900:
http://farm5.static.flickr.com/4051/4412804848_e21e099e53_b.jpg
Apr 16, 2010 at 10:14 AM
helimat
p.1 #3 · Zeiss 135/2.8 opinions??
What he said... The 135/2.8 and 50/1.7 are great value and offer a lot of Zeissiness for your dollar.
Apr 16, 2010 at 10:27 AM
Edgars Kalnins
p.1 #4 · Zeiss 135/2.8 opinions??
I am awaiting one myself. for the money they are going these days, there is hardly a reason not to try one out.
Apr 16, 2010 at 10:35 AM
Edgar M
p.1 #5 · Zeiss 135/2.8 opinions??
is there any clearance issues (shark fin, ap pin, etc) when used with an adapter and 5d2? ..fotodiox good for c/y-to-eos adapters?
Also ...how can one tell MM apart from AE??
Apr 16, 2010 at 10:55 AM
edwardkaraa
p.1 #6 · Zeiss 135/2.8 opinions??
You should be aware of the 160 cm MFD. Otherwise this lens is stellar.
Apr 16, 2010 at 11:40 AM
mortyb
p.1 #7 · Zeiss 135/2.8 opinions??
I use this lens on a 5D2, and it's stellar. No issues with a cheap adapter. The MM version has green numbers on the '22' aperture mark.
Apr 16, 2010 at 11:54 AM
Grandin
p.1 #8 · Zeiss 135/2.8 opinions??
I owned it, albeit very briefly, and used it on 5D.
Two things I do remember vividly:
1. Sharp starting wide open
2. Does not focus very close (as Eward mentioned)
The lens body is somewhat long and thin, I personally did not like how it 'felt' attached to the 5D body - but this is very subjective - others might feel different. Personally I like the handling of the Canon EF 135/2 L, which I've also owned, a lot better. And I like the Canons shorter MFD a whole lot better.
That being said, the Carl Zeiss 135/2.8 is a good value for money alt lens.
Apr 16, 2010 at 12:25 PM
teh_rebel
p.1 #9 · Zeiss 135/2.8 opinions??
definitely a great lens, specially for the money. like others have mentioned, the only negative is the MFD on it. I wish it could focus a bit closer but no biggie. I got the one with the ninja-blade which i like
Apr 16, 2010 at 12:40 PM
Edgar M
p.1 #10 · Zeiss 135/2.8 opinions??
MFD won't matter.. as I will be using it on an Isco Anamorphic adapter, which makes any lens behind it into a 6ft MFD as one focuses with the Isco and the "taking lens" is set to infinity.
Thx for reviews.. I think I am going to hunt one down.
Apr 16, 2010 at 01:13 PM
ersatz
p.1 #11 · Zeiss 135/2.8 opinions??
What's the going price for this lens in the USA market? After dropping $800 on the CY 100/2 and not being able to get focus to infinity on my 5d I'm thinking of selling it for some other Zeiss C/Y lenses. Namely the 35-70 and this 135/2.8 lenses.
Apr 16, 2010 at 01:21 PM
Z250SA
p.1 #12 · Zeiss 135/2.8 opinions??
Got mine, an AE, about a month ago. Shot a few for comparison with my 135L. The most noticeable difference is a significantly stronger CA in the Sonnar images. However, it is sort of yellow green-purple, whilst the 135L has a blue green-darker red LoCA and almost no lateral CA. I really do not like the blue green CA shade of the L though. Sharpnesswise the L is slightly sharper at f/2.8. But from there on they are essentially equal. At f/5.6 I found the Sonnar to have slightly smoother boke than the L. But that might just be that specific back ground. I find the IQ of the Sonnar more appealing than the L mostly due to more powerful colour. The Canon has a look that in my eyes is canon flat. Sharp and rich in some detail, but not much feeling of depth. This is incredible since I have loved my L since the first shot and thought it would be the one and only 135, as it is very very good. But the Sonnar is up there, perhaps even beyond in some respects, and to a fifth of the price. The CA could of course be a characteristic of my specific lens.
Apr 16, 2010 at 01:26 PM
debuggerus
p.1 #13 · Zeiss 135/2.8 opinions??
ersatz wrote:
What's the going price for this lens in the USA market? .
Around $150-200 I think
Apr 16, 2010 at 01:46 PM
rsrsrs
p.1 #14 · Zeiss 135/2.8 opinions??
i have a rollei with build in hood,
it is very very nice.
for the price a must have.
Apr 16, 2010 at 01:50 PM
Edgar M
p.1 #15 · Zeiss 135/2.8 opinions??
on ebay they are going for 300ish, give or take
Apr 16, 2010 at 02:24 PM
edwardkaraa
p.1 #16 · Zeiss 135/2.8 opinions??
A mint copy should not cost more than 200$.
Apr 16, 2010 at 04:45 PM
tonik23
p.1 #17 · Zeiss 135/2.8 opinions??
I'm new to the alt lens. I have the ZE lens but never the old Contax C/Y lenses.
I would like to knoe how difficult is it to change the mount to 5DII? Will any cheapo mount be enough? And does it require and physical Mod like filling to the lens?
Thanks.
Apr 16, 2010 at 06:19 PM
Tri Tran
p.1 #18 · Zeiss 135/2.8 opinions??
Any cheap (but not too cheap) EOS-Yashica adapter should work to mount the 135mm.
I have a 135mm f2.8, but never used it. I will start using it
Apr 16, 2010 at 06:34 PM
helimat
p.1 #19 · Zeiss 135/2.8 opinions??
Thanks.
No mod of any sort that I know of, just a C/Y to EOS adapter and you are set.
Apr 16, 2010 at 07:04 PM
tonik23
p.1 #20 · Zeiss 135/2.8 opinions??
Awesome, so much savings to be had
Apr 16, 2010 at 07:36 PM
       2       3       4       5       end
       2       3       4       5       end
