Archive 2010 · BG-E6 gear stripped :(
david1234
p.1 #1 · BG-E6 gear stripped :(
Well...i thought the grip was a little loose and tried to tighten it more and stripped the plastic wheel gear inside and am now screwed! what can be done?!?!
Apr 15, 2010 at 01:07 AM
jdben622
p.1 #2 · BG-E6 gear stripped :(
http://www.amazon.com/Canon-BG-E6-Battery-Grip-Digital/dp/B001KBZ3QO/ref=sr_1_1?ie=UTF8&s=electronics&qid=1271312292&sr=8-1
Apr 15, 2010 at 01:18 AM
KKFung
p.1 #3 · BG-E6 gear stripped :(
I had it happen 2 times, the only way is give it back to canon CS, get back the body first and get back the repaired grip later.
Actually the dail can't be and no need to tighten. This is a design fault that the dial mis-lead people think it can be tighten up with a bigger fingers force as usual houseware design.
I complained to the canon customer service since they charged me the repairing cost and of course, no feedback .....
Apr 15, 2010 at 01:23 AM
Ian.Dobinson
p.1 #4 · BG-E6 gear stripped :(
Are they still using this crappy under design?
Apr 15, 2010 at 01:53 AM
david1234
p.1 #5 · BG-E6 gear stripped :(
yeah its trash! however i just got the grip off with a small flat head and a rubber mallet...stuck the flat head through the little space (in between wheel) and loosened the gear...anyway to replace the plastic wheel which has the plastic gear on it thats stripped? i know the part number is CG2-1365-000 just cant find places that sell it!
Apr 15, 2010 at 02:01 AM
david1234
p.1 #6 · BG-E6 gear stripped :(
http://www.takeitnow.nl/product/2816751 this place sells it? just dont know the language and the price?!?
Apr 15, 2010 at 02:02 AM
david1234
p.1 #7 · BG-E6 gear stripped :(
well its euros i know that.... just cant tell what everything says!!
Apr 15, 2010 at 02:03 AM
Ian.Dobinson
p.1 #8 · BG-E6 gear stripped :(
google chrome translate (I just copied and pasted the bit in the corner for you)
"Wish List price alert stock alarm print mail
Out of Stock
Expected delivery time: unknown
€ 49,50incl VAT
(€ 41,60excluding VAT)"
Apr 15, 2010 at 02:16 AM
Ian.Dobinson
p.1 #9 · BG-E6 gear stripped :(
£41 for the gears seems a bloody rip off. How old is you grip? maybe you could get canon to replace them in warranty (just mention substandard parts on a near $200 item)
I'm also pretty sure that you could hunt around and fins a metal replacement for the nylon one. Its a while since I've seen the inside of the grip but it must be possible.
Apr 15, 2010 at 02:20 AM
david1234
p.1 #10 · BG-E6 gear stripped :(
Ok thanks for looking that up i appreciate it!!! and i will call canon tomorrow and see what they can do but check this out.. http://www.uscamera.com/cg2_1365.htm they sell a replacement for pretty cheap and all i need is the plastic wheel which pops off on the bg-e6 however that replacement part looks like its for the bg-e2, the metal frame is different but i dont need that, just the wheel which im almost positive is the same.. so if all else fails i might just get one of those?
Apr 15, 2010 at 02:22 AM
Ian.Dobinson
p.1 #11 · BG-E6 gear stripped :(
if the plastic gear pops off you might want to hunt around some model shops that do RC cars and stuff as I would bet you could find better. (and it would much cheaper)
Apr 15, 2010 at 02:36 AM
david1234
p.1 #12 · BG-E6 gear stripped :(
Yeah thats smart i def will, the other 2 gears it is hitting are metal, so why on earth didnt they make the wheel gear metal!!
Apr 15, 2010 at 02:41 AM
helimat
p.1 #13 · BG-E6 gear stripped :(
Seem like a lot of camera parts have been getting stripped around here lately...
Apr 15, 2010 at 06:59 PM
SteveTuerk
p.1 #14 · BG-E6 gear stripped :(
Nice work!
What kind of luck you must have to have a gear with the diameter and tooth count to work! I've probably got 1000 small gears and pieces of geared assemblies and not one of them would be the one I need at any given time.
In case it doesn't hold, I've got an off label copy that's as solid as the Canon model and feels like it may have metallic gears. Brand name "Zeik", and it was $69. new.
Apr 15, 2010 at 07:52 PM
Mark Zwiesler
p.1 #15 · BG-E6 gear stripped :(
I personally think it's BS that Canon makes a grip like this and doesn't do anything about it. I mean, for crying out loud, it's over $200 for it. It's been a known issue since it's introduction that the the grip has play in it, and it doesn't surprise me at all that users would try to correct that by trying to tighten it more.
I bought a Zeikos grip for mine, less than $100, and it fits nice and tight. I felt a little bit bad about buying it, I've always used Canon grips prior to this one, but I read about the fit and just couldn't justify spending so much for it.
Mark
Apr 15, 2010 at 10:32 PM
EB-1
p.1 #16 · BG-E6 gear stripped :(
It doesn't surprise me at all. Canon makes plenty of junk products.
Apr 15, 2010 at 10:44 PM
david1234
p.1 #17 · BG-E6 gear stripped :(
Yeah its quiet ridiculous that we pay 250 more or less for a grip that can get screwed up pretty easy....and the repair by canon isnt cheap! Hopefully my gear will last a while... but i just cant buy a off brand grip for this beautiful body not yet!
Apr 16, 2010 at 12:14 AM
david1234
p.1 #18 · BG-E6 gear stripped :(
SteveTuerk wrote:
Nice work!
yeah out of 3 gears i had one worked!!! such luck
Apr 16, 2010 at 12:15 AM
david1234
p.1 #19 · BG-E6 gear stripped :(
Pablov
p.1 #20 · BG-E6 gear stripped :(
I had this problem too. The knob started to rotate freely, no way to detach the grip from the camera.
The only suggested (best) way was to destroy the knob to reach the metal gear inside and then using a flat screwdriver, make it unscrew (the inner gear is metalic, not plastic) The knob SHOULD BE MADE OF METAL INDEED.
Canon made BIG mistake on this design..
- Here is a method to detach the grip without destroying it if you can't or don't want to send the camera+grip to a Canon service center:
http://www.canonistas.com/foros/bricolaje/196554-quitar-y-reparar-grip-de-5dmkii-con-la-fijacion-rota.html
Nice find thanks to a member of the forum.
Apr 27, 2010 at 11:20 AM
