Archive 2010 · rangefinder question
Sexymaru
p.1 #1 · rangefinder question
if a rangefinder (for example Bessa R2A) has 35/50/75/90 frame lines, what happens if you put on a 15mm lens or 21mm lens? how do you frame your shots? which lens (35/50/75/90) should you set it too even tho none of them fits the lens?
Mar 03, 2010 at 12:18 AM
thrice
p.1 #2 · rangefinder question
Auxiliary viewfinder that mounts in the hotshoe is used for framing, you still use the rangefinder window for focus.
The lens will trigger a set of framelines, usually the 28/90 lines if it's wider than what is available. Leica have been sneaky and some of the newer lenses trigger different framelines to competitors lenses in equivalent focal lengths, to avoid a simple coding job to emulate the Leica corrections.
Mar 03, 2010 at 12:31 AM
Sexymaru
p.1 #3 · rangefinder question
what if it's an older non-digital rangefinder where you have to manually set the frame lines?
Mar 03, 2010 at 12:39 AM
Spyro P.
p.1 #4 · rangefinder question
Framelines are for framing, you dont use the viewfinder for framing only for focusing. Just ignore them.
In practice with a wide lens you hardly ever use the VF at all, you scale/zone focus using the numbers on the lens.
Mar 03, 2010 at 12:58 AM
