       2       3       4       end
Archive 2010 · 85 1.2 AI Servo or One Shot?
docnlaw24
p.1 #1 · 85 1.2 AI Servo or One Shot?
Recently acquired this classic lens and looking to get the best out of it. One shot AF seems to give me the best results(very sharp). AI Servo seems to miss the focus when wide open. Shooting with original 5D and 1d Mark 2n, both seem to show similar improvement with one shot (shooting portraits). Thanks for any additional tricks you might have regarding this hunk of glass.
Feb 08, 2010 at 07:18 PM
mttran
p.1 #2 · 85 1.2 AI Servo or One Shot?
1dseries AI servo AF @ f1.8 or larger - works great with all AF points. I have always used 5Ds for 1 shots AF, i don't trust 5D's outer points.
Feb 08, 2010 at 07:51 PM
Zara
p.1 #3 · 85 1.2 AI Servo or One Shot?
5d, center point, AI servo with focus on the * button for me.
Feb 08, 2010 at 08:08 PM
docnlaw24
p.1 #4 · 85 1.2 AI Servo or One Shot?
so, do you avoid AI even on the 1 series wide open with 85L?
Edited on Feb 08, 2010 at 08:14 PM · View previous versions
Feb 08, 2010 at 08:12 PM
docnlaw24
p.1 #5 · 85 1.2 AI Servo or One Shot?
Always use * for AF, but AI servo still couldn't handle the 85 wide open. One shot seemed to be much better though.
Feb 08, 2010 at 08:13 PM
shaunmlavery
p.1 #6 · 85 1.2 AI Servo or One Shot?
If you are shooting at 1.2, one shot is fine but once it has "acquired focus" you better be still or your focus is going to be off.
The best thing to do is shoot a bunch with that lens. I just sold mine and dropped it of at fedex today but it it is a wonderful tool. You have to learn your lens. Mine was sharpest from 1.6 on. If a friend wanted to try out my 85L, no problem but they always seem to struggle with it. You really have to shoot with to get the feel for it.
The biggest help to me was to put a EE-S screen in my 5D and manual focus. This is how I shot my 85L probably 90% of the time. Again, once you get used to that, it is no problem. I had alott more keepers than trying to let the camera/lens hunt for AF, esp. in a dark environment.
Good Luck with your new lens. It is a really nice piece of glass.
Andre Goli
p.1 #7 · 85 1.2 AI Servo or One Shot?
5D : One shot... awful with AI SERVO
Feb 08, 2010 at 08:19 PM
cogitech
p.1 #8 · 85 1.2 AI Servo or One Shot?
There's a switch on the side of the lens labeled "MF-AF". For best results, switch it to "MF".
You will be best served by first purchasing and installing a high precision focusing screen for your camera, as Shaun suggested.
Edited on Feb 08, 2010 at 08:21 PM · View previous versions
Feb 08, 2010 at 08:20 PM
docnlaw24
p.1 #9 · 85 1.2 AI Servo or One Shot?
Thanks Shaun. Look forward to learning from this lens. My 135 was a lot easier to master!
Russ Isabella
p.1 #10 · 85 1.2 AI Servo or One Shot?
AI Servo just introduces another potential source of error as the camera is trying to track focus when that's not necessary for what you're shooting. One-shot is the way to go unless you are compelled to rely on manual focus. AI Servo was not intended for the application you have described (unless your subject is moving and I just missed that in your OP).
Feb 08, 2010 at 08:23 PM
RobertLynn
p.1 #11 · 85 1.2 AI Servo or One Shot?
+12 to what Russ says. Especially regarding that lens.
Feb 08, 2010 at 08:24 PM
docnlaw24
p.1 #12 · 85 1.2 AI Servo or One Shot?
Thanks Russ. Let me know how your Mk IV works with the 85L wide open. The kids are always moving even when told to "Stay still!"
Edited on Feb 08, 2010 at 08:26 PM · View previous versions
Feb 08, 2010 at 08:25 PM
cogitech
p.1 #13 · 85 1.2 AI Servo or One Shot?
Your compositions must suffer terribly.
cogitech
p.1 #14 · 85 1.2 AI Servo or One Shot?
MF + EE-S + focus bracketing. No problemo. And your compositions won't suck.
Zara
p.1 #15 · 85 1.2 AI Servo or One Shot?
I use One Shot when I need AF Assist from my 580EX - have tried it in broad daylight as well, though it didn't seem to improve my keeper rate. If in AI Servo, you'll hear the lens doing tiny little adjustments as you or your subject sway back and forth. One shot will not even register those so either way you're not going to get an f/2.8 keeper rate at f/1.2
AI Servo may not be intended for stationary subjects, but when there is no movement to predict because there is none, it will not predict any movement either. On the other hand, with the 85L wide open, there is constant movement in the form of your natural swaying back and forth unless you are shooting from a tripod. I find AI servo seems to help me here, but then maybe the root cause is all that beer I drink before noon.
No, not really. At least not because of the AF I have an Ee-S for the alt lenses I shoot, and I use MF on the 85L when shooting completely stationary subjects which is seldom. It does help immensely when double-checking AF accuracy through the viewfinder though.
I'm using focus recompose most of the time, except for moving subjects where I'll crop in post. Before I hear all the comments on how bad focus recompose is, take a DoF calculator, work in the numbers for general head&shoulder or full body shots on a 5D/85L and then realize that for most real world shooting scenarios it's not the issue it's made up to be.
Feb 08, 2010 at 08:40 PM
cogitech
p.1 #16 · 85 1.2 AI Servo or One Shot?
markle wrote:
whoever suggested that MF must have a very little experience with that lens (or none).
85mm f1.2, 5D, Ee-S, manual focus, hand held. I do it all the time.
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7659.jpg
2
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7673.jpg
3
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7690.jpg
4
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7692.jpg
5
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7698.jpg
6
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7705.jpg
7
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7722.jpg
8
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7727.jpg
9
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7731.jpg
10
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7738.jpg
11
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7746.jpg
12
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7750.jpg
13
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7754.jpg
14
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7761.jpg
15
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7776.jpg
16
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7784.jpg
17
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7785.jpg
18
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7786.jpg
19
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7791.jpg
20
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7793.jpg
21
http://www.cogitech.ca/photos/SSC_Asph/Cirque/IMG_7799.jpg
No experience?
Apparently you have no idea.
Edited on Feb 08, 2010 at 10:44 PM · View previous versions
Feb 08, 2010 at 10:40 PM
helimat
p.1 #17 · 85 1.2 AI Servo or One Shot?
Paul, please keep in mind that:
a) You are a far better at manual focusing than most photographers.
b) The 85/1.2 you were shooting with has a proper focus ring.
True, but the outer points on the 5D series suck balls. Focus recompose is in order for AF with the 85L & 5D.
Feb 08, 2010 at 10:43 PM
Hrow
p.1 #18 · 85 1.2 AI Servo or One Shot?
Shooting wide open, on a tripod, with a stationary subject, then one shot works great. If you are hand holding it then Servo helps take care of the body sway. That said, MFing it is the way I go most of the time and do a focus bracket.
Feb 08, 2010 at 10:49 PM
kakomu
p.1 #19 · 85 1.2 AI Servo or One Shot?
It doesn't take too much practice to become decent at manually focusing.
cogitech
p.1 #20 · 85 1.2 AI Servo or One Shot?
Mat. Thanks.
So why do you suppose that some cretin needs to insult my intelligence and skill by insinuating that I have no experience?
All I am doing is presenting my perspective, after many years of shooting plenty of ultra-fast glass with both AF and MF. Some numbskull who hasn't even tried MF has the audacity to accuse me of not knowing what I'm talking about?
Markle, you're a simpleton.
Edited on Feb 08, 2010 at 10:54 PM · View previous versions
Feb 08, 2010 at 10:52 PM
       2       3       4       end
       2       3       4       end
