Archive 2010 · Backdrop Stand Height Suggestions
WThiry
p.1 #1 · Backdrop Stand Height Suggestions
Suggestions needed on height of backdrop stand. Is the idea of higher better because you can always lower, but you can't make a shorter one taller.
Feb 06, 2010 at 07:34 PM
RobertLynn
p.1 #2 · Backdrop Stand Height Suggestions
You can do a lot with one of those "kits" that has the 3 piece cross-bar, and 2 10 ft stands.
Some folks use super clamps, a cross bar and 2 12 foot stands.
Feb 06, 2010 at 08:36 PM
WThiry
p.1 #3 · Backdrop Stand Height Suggestions
I am looking at this:
http://www.bhphotovideo.com/c/product/556183-REG/Photoflex_DP_BP412_First_Studio_Backdrop_Pole.html
and this:
http://www.bhphotovideo.com/c/product/644444-REG/Manfrotto_1004BAC_Alu_Master_3_Riser.html
Feb 06, 2010 at 08:46 PM
Tim Combs
p.1 #4 · Backdrop Stand Height Suggestions
If you're not planning on transporting and shooting remotely, AutoPoles, a cross bar and super clamps with U-hooks work really well. It's very stable and will support multiple backgrounds at one time. The cost is not much different than what you've looked at above.
Feb 06, 2010 at 08:54 PM
WThiry
p.1 #5 · Backdrop Stand Height Suggestions
I will be doing remote shoots, schools etc. Go with what I have linked?
Feb 06, 2010 at 08:55 PM
Tim Combs
p.1 #6 · Backdrop Stand Height Suggestions
Those look like pretty solid components to me if you're moving around. Maybe a couple sandbags if you thought it wasn't as stable as you'd like but seems like a good choice.
Feb 06, 2010 at 09:00 PM
tell
p.1 #7 · Backdrop Stand Height Suggestions
This is the one I've been using for six years http://www.bhphotovideo.com/c/product/395974-REG/Savage_6203750_Background_Port_A_Stand_Travel_Case_.html
When I need it wider, I have a telescoping paint pole I purchased at Menards that I drilled holes in. When I get the pole out beyond 14 feet, I'll use a third stand in the middle and clamp it. I've had it 20' wide with no probelms.
Feb 08, 2010 at 10:43 PM
EA6B
p.1 #8 · Backdrop Stand Height Suggestions
Calumet and Savage are both good!
Feb 08, 2010 at 11:10 PM
