Archive 2010 · What cold shoe to replace Canon’s plastic feet?
Savas K
p.1 #1 · What cold shoe to replace Canon’s plastic feet?
I have been using Canon’s plastic feet to affix my flash to an umbrella adapter. This is easy to break if I am not careful.
What third party cold shoe is available that will work in place of Canon’s plastic feet?
Thanks for any help on this.
Feb 06, 2010 at 11:31 AM
muskydave22
p.1 #2 · What cold shoe to replace Canon’s plastic feet?
Get this one from Flash Zebra
Feb 06, 2010 at 11:52 AM
cgardner
p.1 #3 · What cold shoe to replace Canon’s plastic feet?
Have you ever actually broken one?
The thing to realize about locking the flash in place is that the locking mechanism isn't friction created by the collar, but rather a pin on the front of the flash base which extends and mates with a hole in the hot shoe. Canon hot shoes and the accessory foot have the corresponding hole for the locking pin, but third party cold shoes usually don't.
I used third party cold shoes but switched Canon base after several near misses of flashes falling off of my off camera light stand. So it you do opt for a third-party shoe you might want to get out the drill or Dremel tool and create a hole for the mounting pin.
Feb 06, 2010 at 12:00 PM
c.d.embrey
p.1 #4 · What cold shoe to replace Canon’s plastic feet?
For those who want the very best http://reallyrightstuff.com/rrs/Itemdesc.asp?ic=FA%2DCS2&eq=&Tp=
Feb 06, 2010 at 12:04 PM
Savas K
p.1 #5 · What cold shoe to replace Canon’s plastic feet?
I'll check the products out. thanks.
Chuck, the plastic thread on the bottom is what I am wary of. It is easy to strip out the plastic thread mating with a metal thread; easy to knock off the plastic foot base if struck. These thoughts arise while thinking about taking light stands out of the house to shoot elsewhere.
Embry, RRS site says it is good for Nikon speed light. It does not mention Canon.
Feb 06, 2010 at 02:06 PM
Michael White
p.1 #6 · What cold shoe to replace Canon’s plastic feet?
I mount my speedlites to PW Flexes and then mount a 1/4 20 stud to that and then put that in my Bogen umbrella mount. That makes a perfect setup in my view.
Feb 06, 2010 at 03:30 PM
Lovesong
p.1 #7 · What cold shoe to replace Canon’s plastic feet?
I've had good experience with these cheapies:
http://www.bhphotovideo.com/c/product/50546-REG/Stroboframe_300_405_Shoe_General_Purpose.html
The thing I like about them is that they don't use the flash tightening mechanism, but rather use tension provided by the screw on the side, which clamps the base of the shoe mount.
Feb 06, 2010 at 03:49 PM
Savas K
p.1 #8 · What cold shoe to replace Canon’s plastic feet?
Nice stuff. Thanks for the ideas.
Feb 06, 2010 at 07:06 PM
c.d.embrey
p.1 #9 · What cold shoe to replace Canon’s plastic feet?
Savas K wrote
EmbrEy, RRS site says it is good for Nikon speed light. It does not mention Canon.
Send them an e-mail and ask if it fits Canon flash. I have had no problem.
Down-load their PDF catalog http://reallyrightstuff.com/mmRRS/Others/ReallyRightStuff2010.pdf
They make excellent (not inexpensive) Ball Heads, L brackets, and Flash Brackets.
Feb 06, 2010 at 07:08 PM
RobertLynn
p.1 #10 · What cold shoe to replace Canon’s plastic feet?
I have smitch victor cold shoes. They are some sort of aluminum, but you'll have to tape off the top of it though, so it doesn't make contact with the flashes contacts.
I use them on top of bogen umbrella swivels, and I've not had a 580EXII with a cybersync fall off yet. *going to find wood to knock on*
Feb 06, 2010 at 07:19 PM
Savas K
p.1 #11 · What cold shoe to replace Canon’s plastic feet?
I knock on my head when there's no other wood around.
Feb 06, 2010 at 10:52 PM
cgardner
p.1 #12 · What cold shoe to replace Canon’s plastic feet?
YMMV but based on my experience I think you are worrying too much a problem you haven't experienced yet. I've used the flash foot for several years attached to a light stand stud and never had a problem with stripped threads. If you are tightening the base to the point the threads might strip you are over-tightening.
The plastic itself is sturdy and not likely to break. But consider if something had to break would you rather it be the foot that breaks or the base of the flash?
Whatever you use, make sure the spring-loaded locking pin engages the cold shoe holding the flash.
Feb 07, 2010 at 06:37 AM
BrianO
p.1 #13 · What cold shoe to replace Canon’s plastic feet?
cgardner wrote:
...consider if something had to break would you rather it be the foot that breaks or the base of the flash?
^ This is truth! ^
Sacrificial parts like flash feet are cheap and easy to replace, folks; a cracked or broken housing is not. Listen to Chuck's wisdom.
However since the OP isn't about replacing plastic feet with metal feet, but rather of adding something below the plastic feet to attach to the stand, the suggested cold shoes are workable choices.
Feb 07, 2010 at 07:55 AM
BrianO
p.1 #14 · What cold shoe to replace Canon’s plastic feet?
Savas K wrote:
...RRS site says it is good for Nikon speed light. It does not mention Canon.
It's a reference to a problem with some other models that worked for most Canon and Nikon lights, but had problems with the Nikon SB-900.
This one works for most Canon and Nikon lights including the SB-900.
Feb 07, 2010 at 08:07 AM
Savas K
p.1 #15 · What cold shoe to replace Canon’s plastic feet?
I will not be packing stands with speed lights attached. Without the Canon feet, I would feel more at ease in the case of manhandling folded stands or if a bag of stands fell over or got banged on the wrong end. Sort of envisioning the plastic feet as the weak link that could prevent a proper setup if one broke at the wrong time.
Feb 07, 2010 at 10:09 AM
tapix
p.1 #16 · What cold shoe to replace Canon’s plastic feet?
Try this
http://www.bhphotovideo.com/c/product/540457-REG/Crane_CCSLS_SLSC_Locking_Shoe_Mount.html
Feb 07, 2010 at 12:15 PM
Roland W
p.1 #17 · What cold shoe to replace Canon’s plastic feet?
I really like the Stroboframe cold shoe mentioned above, and have used it for many years with Canon flash units on umbrella mounts. It grabs the foot securely, and does not touch the electrical contacts on the bottom of the flash foot.
Feb 07, 2010 at 01:35 PM
Savas K
p.1 #18 · What cold shoe to replace Canon’s plastic feet?
Roland, that one looks to be the price / performance leader. Screw mount is secure.
Tapix - the one you linked to has the locking pin hole that Chuck mentioned was a good safety feature.
Thanks for all of these great choices. I'll visit B&H and have the man bring these units up to handle.
Feb 07, 2010 at 06:03 PM
DC Chavez
p.1 #19 · What cold shoe to replace Canon’s plastic feet?
Here is some of the gear I bought a while back that may help you out:
http://www.dcchavez.com/theblog/2009/01/new-gear/
Feb 08, 2010 at 01:12 AM
