Sports Corner Rules
Sports Corner Resource
Archive 2010 · Soccer shooting - getting started?
redmonkee
p.1 #1 · Soccer shooting - getting started?
Hi guys
I want to try my hand at shooting football (soccer to most of you ) and just wondered what the minimum and cheapest gear I would need decent shots of Sunday footy.
I have a 5D with 70-200f4 with 580 EX, all my other glass are wides as I normally shoot landscapes.
Is the 5D fast enough to cope with soccer if I paired it up with fast glass or would I need something like a 500D or 7D.
Also what is the best priced long zoom? I know the Canon EF 400mm f/2.8L IS USM is the bees knees but way out of my price range.
Any advice greatly appreciated.
Cheers
Phil
Feb 03, 2010 at 10:26 AM
kiwifamily
p.1 #2 · Soccer shooting - getting started?
70-200 and 5D i'd imagine would be fine to start with
Its a good discipline to learn to wait for the action to come closer and time the burst before taking the shot
The most common football lens would have to be the 300mm 2.8
Feb 03, 2010 at 10:53 AM
elluDe
p.1 #3 · Soccer shooting - getting started?
Yes, 70-200mm is fine for soccer and you should get good pictures provided - as mentioned above - you wait for the action to happen close to you. Forget about taking action that is taking place far away (even with a 300mm lens).
Use centre point to focus, aim at the players chest. Adjust ISO so you have a shutter speed of 1/500 sec.
Feb 04, 2010 at 12:48 PM
likecoolpics
p.1 #4 · Soccer shooting - getting started?
Some might think I'm crazy, but I don't think the 300mm F/4 IS is that big of a step down from the f2.8 version. I say go out on the field and practice. You can take some shots and then do some calculations to see how much ISO you would gain by going with a 2.8 over an F4. But for Soccer and even football, I prefer the zoom lens.
Feb 04, 2010 at 02:27 PM
gtjohnson
p.1 #5 · Soccer shooting - getting started?
In my opinion 70-200 on a FF body is going to be pretty short. You'll be eliminating a lot of the field because it's just too far away. 100-400 is a great starting lens assuming you'll be shooting in daylight. Opens up a big chunk of the field to shoot and can shoot action that's pretty close as well. 1.6 crop body will open up the 70-200 a fair amount and make it much more usable. If it's all you have and aren't in a position to make a move, then 5D + 70-200 will get you started, but you'll soon be wishing you had more reach ...
Gary
Feb 04, 2010 at 11:08 PM
redmonkee
p.1 #6 · Soccer shooting - getting started?
Thats what i thought Gary.
if I were to get a body with a 1.3x crop sensor (1D Mk2)and use my 70-200 with a 1.4 converter how much reach would that give me?
Sorry for the maths question
Feb 04, 2010 at 11:57 PM
Monkey Falls
p.1 #7 · Soccer shooting - getting started?
Well on the short end that would give you 70*1.3*1.4 = 127.4.
On the long end that would give you 200*1.3*1.4 = 364.
Feb 05, 2010 at 01:45 AM
kiwifamily
p.1 #8 · Soccer shooting - getting started?
basically you can cover the 1/4 of the pitch you are on
Go try it, youll soon see
Feb 05, 2010 at 01:50 AM
Russ Isabella
p.1 #9 · Soccer shooting - getting started?
What you might gain in reach with the teleconverter you will lose in aperture (you'll be at 5.6), so I don't recommend that you use the 1.4x with your 70-200 f/4 lens. (280mm isn't going to allow you to shoot much more than 200mm, but f/5.6 could really cramp your style if light is an issue.) As others have suggested, take your equipment and go shoot football. You'll see soon enough what it affords you and what its limitations will be.
Feb 05, 2010 at 02:09 AM
redmonkee
p.1 #10 · Soccer shooting - getting started?
Cheers for working out the math Monkey.
364 seems like a long enough reach!
Russ If I were to sell the 70-200 f/4 and get the 2.8 version, would this work well with the 1.4x converter?
Feb 05, 2010 at 10:47 AM
mfreardon
p.1 #11 · Soccer shooting - getting started?
I use the 300mm f/4 lens for youth soccer and it works well for most daylight games. I suggest that you rent one for a weekend and try it. The purchase price will be less than a 70-200 f/2.8 + converter.
Feb 05, 2010 at 04:28 PM
redmonkee
p.1 #12 · Soccer shooting - getting started?
Guys I have been thinking. Initially I was thinking of getting a 300mm f/4 for my 5D. This would cost me just over the £1000 mark.
Now I am thinkng would it be a better option to go for the 7D (and keep my 5D) as this is a great sports camera and also due to the 1.6X crop it would make my 70-200 f/4 a 112-320 f/4.
Also this would mean I have another body for getting more focal ranges out of my existing lens line up.
Any thoughts?
Feb 05, 2010 at 09:09 PM
mfreardon
p.1 #13 · Soccer shooting - getting started?
If you can afford it, I recommend a used 1D MKIII. For sports, it's far better than my 50D. The keeper rate is much higher.
Disclaimer: I have never used a 7D so I cannot comment directly on your question.
Feb 06, 2010 at 04:40 PM
redmonkee
p.1 #14 · Soccer shooting - getting started?
Just an update guys.
I have ordered a 7D, and am keeping my 5D.
I am selling my 70-200 f4 and using that cash towards a EF 100-400.
i think this combination will cover my needs.
Thanks for all your advice
Regards
Phil
Feb 09, 2010 at 04:45 PM
schlotz
p.1 #15 · Soccer shooting - getting started?
Phil,
I've shot soccer for many years now. Your choice of the 7D is good. Its fps is where you want it to be. There are two items in the thread I would caution you on.
1. The crop factor is NOT a multipler. Said another way, it does not do the same as a teleconverter, i.e increase the reach of a lens. It is no different than using photosop in PP to crop out a piece of a photo. You then have to blow it up to see it better which does not by itself make it the same, in fact the resolution captured is now spread over a larger area.
2. Use of the 100-400L. This lens is fine in mid day shooting where there is PLENTY of light but attempt it on a very overcast day, or late in the afternoon and you'll be starved for light therefore limited in shutter speed. Its max aperture tends to be light limiting in less than bright conditions. Yes there is ISO compensation, but even that has limits. In the end the ability to achieve fast shutter speeds will suffer. 1/500 is a minimum, soccer is covered better by keeping closer to, or over, 1/1000.
f/2.8 lenses are the norm. That in a 70-200 with a 1.4tc will yield a 280 mm rig operating at f/4.0. This will cover a closer portion of the pitch under a number of conditions. You'll have to remove the tc and deal with a closer section of the pitch in order to compensate for low light.
Best Regards,
Matt
Feb 11, 2010 at 01:59 AM
redmonkee
p.1 #16 · Soccer shooting - getting started?
Hi Matt
Are you saying that the 70-200 f2.8 would be a better option for me than the 100-400L. Bear in mind that I want a combination that will also allow me to shoot birds and wildlife.
Cheers
Phil
Feb 11, 2010 at 10:22 AM
fastcarsspeed
p.1 #17 · Soccer shooting - getting started?
I was going to say some of the same above. It really depends on what your shooting and when. Shooting outside during the day with sun you will be fine with the gear you have. Shooting in lower light your going to want faster glass. Shooting my childrens soccer I think was one of the easier sports I have shot. Even with my original XT I was able to get good shots in decent light. Good luck in your venture.
Feb 11, 2010 at 12:45 PM
m34tba11
p.1 #18 · Soccer shooting - getting started?
Your camera body is fine, except not having the 1.6x factor will shorten that 70-200. I've read/heard of a lot of people forgoing the 1D and using the 7D for sports b/c the AF is on par with the 1DIII, and it is APS-c vs APS-h. I've played with a 7D with a 70-200 mounted on it for basketball, and except for how it felt in my hand, could not tell much difference in AF performance. (you do notice the difference though when you hit that shutter release). I am pretty sure it uses the same battery set as the 5D MII (and maybe the 5D) so that works in your favor.
I've used the 100-400 for AFB, and it has great reach and is also good for BIF, but you can kiss those action stopping shutter speeds goodbye once dusk sets in. You might be able to get by with 1/500 or 1/250 later in the day, just going to have to employ some panning technique to keep the players somewhat crisp. I still like my 70-200 2.8 more then the 100-400. *but these are just my thoughts*.
Just be willing to move around if you can and or stay b/w the penalty boxes and work the action on the near side to you. (and occasionally drop behind the goal if you think someone is going to break thru/score or for a corner kick/free kick near the box.
Feb 11, 2010 at 05:08 PM
Jeff_Stapleton
p.1 #19 · Soccer shooting - getting started?
I use a 300/4L with my 30D, and recently with my 7D.
Its a great combo. What time of day will you be shooting?
Feb 11, 2010 at 05:39 PM
schlotz
p.1 #20 · Soccer shooting - getting started?
Red,
Welcome to the land of photography a.k.a. the compromise zone. What is best for one venue can be marginal for another. While there are those that might imply that the 100-400L is marginal for birds, I cannot comment as that is not where I spend my time behind the shutter. For soccer, yes, the 70-200 f/2.8 is a much better choice. It does not allow the reach but will provide good service for those times where you wait for the action to come to you. In the end, its up to you in choosing what and where to compromise.
Best Regards,
Matt
Feb 12, 2010 at 03:13 AM
redmonkee
p.1 #21 · Soccer shooting - getting started?
Hopefully I will try and keep my shooting to midday.
Obviously for any wildlife or birds i may be shooting earlier.
Anyway my 7D arrived yesterday and my first impressions are like....WOW! This thing is so much quicker and more responsive than my 5D I am so glad I bought it. Not had chance to take it out yet but just from the test shots in my room I can tell i'm going to like this body.
The instruction books a bit of a surprise as it's ...BIG lol. Gonna take me all weekend to work out all the custom functions on this thing.
Feb 12, 2010 at 03:11 PM
lokie
p.1 #22 · Soccer shooting - getting started?
Redmonkee,
A 5D or a 7D will work fine for soccer. Just make sure that your minimum shutter speed is 1/500th second or less. Otherwise you will see movement in the players.
Adjust your ISO to suit.
For behind the goal shots I would recommend a minimum 85mm or equiv. lens.
For out field shots I really think that 400mm is the best. Of course fast glass is better. f2.8 or faster is what you need.
Don't underestimate shooting from behind the goals. You can get some good shots of goalmouth action even though the opportunites are fewer.
For outfield shots try and make sure that the face of your subject is visible, even more important than the ball.
Follow the ball and snap your shots at every opportunity. In focus is the key and shooting just a little bit later is better than shooting earlier.
First time, most of your shots will be out of focus but don't worry, it will improve.
Soccer is a hard sport to shoot but very rewarding when you get a nice picture.
One more thing, don't forget off the ball incidents. They are sometimes better than the action on the field!
Feb 12, 2010 at 04:28 PM
Nill Toulme
p.1 #23 · Soccer shooting - getting started?
Phil you might enjoy my Sports Basics here. It's heavily focused (so to speak) on soccer, which is my personal favorite. An excerpt:
Shoot for Face/Ball/Action/Contact!
Nill
Feb 12, 2010 at 05:50 PM
KrautFed
p.1 #24 · Soccer shooting - getting started?
You definitely captured all of the above!
Feb 12, 2010 at 07:22 PM
