Moderated by: guardian
Archive 2004 · The "PRINGLES" Method Go to previous topic Go to next topic
Aragosh
Image Upload: Off
p.1 #1 · The "PRINGLES" Method
A few months ago someone posted a method for White Balance measurement and customization. If I recall correctly, this had to do with pasting two Pringles caps on top of each other, holding this in front of the lens, and measure the WB by aiming the lens to the light source.
Can anybody please respond to the correctness of the above.
Another thing... Can anybody please tell me how I can set the WB custom on the 300D. I am not too familiar with this camera, and a friend of mine is struggling with this. Aparently you have to shoot a white card and then tell the camera to use this image as the WB.
Are there more ways in which one can set the WB on the 300D for specific lighting? Will the "PRINGLES" method work on this camera's WB as well
Thank you for your help
Apr 04, 2004 at 04:19 PM
Photon
Buy and Sell: On
p.1 #2 · The "PRINGLES" Method
Do a search for posts relating to Tom Hicks' "HickspoDisc", which involves using respirator filters as white diffusers over the lens. The idea is simply to have a completely color-neutral diffuser, so that the camera reads the overall color balance. A white or gray card works very well, too, and the owners' manual will tell you exactly how to set a custom WB (I don't use a 300D).
Apr 04, 2004 at 05:20 PM
Protege
Image Upload: Off
p.1 #3 · The "PRINGLES" Method
I did the search, and found this:
http://www.fredmiranda.com/forum/viewtopic_archives.php?TopicID=64826&page=0
Unfortunately, all the sample photos and reference links stopped working. At least the ones that THicks posted. I'm more confused than ever in how to get this to work.
Oz
Apr 04, 2004 at 06:01 PM
Melor
Image Upload: On
p.1 #4 · The "PRINGLES" Method
Try the link to my website. Once there it is the second link down.
http://www.melor.com/projects/index.htm
Paul
Apr 04, 2004 at 06:29 PM
ICQ
John Ferguson
Buy and Sell: On
p.1 #5 · The "PRINGLES" Method
I didn't try the respirator filter but had much better luck using three bleached white coffee filters than the pringles lid. Three coffee filters achieved a white balance within 5% of my calibrated expodisc. Here is how you use them or a pringles lid.
Set your lens to manual focus to prevent hunting. Stand in the approximate location of your subject to be photographed. Cover end of lens with three coffee filters and point lens back towards where you will be taking pictures from. Take one exposure. Go into menu and select Custom White Balance, the last frame you took (pretty much solid grey) will display on the screen, press set. Then select custom white balance on the LCD screen, it is the Icon that looks like two triangles with a dot in the center, see manual if necessary. Don't forget to set your lens back to auto focus and take pictures before lighting conditions change. Repeat when lighting conditions change.
Apr 04, 2004 at 09:40 PM
Aragosh
Image Upload: Off
p.1 #6 · The "PRINGLES" Method
Thank you very much for all the help... Happy shooting
Apr 04, 2004 at 10:29 PM
stevelew47
Image Upload: Off
p.1 #7 · The "PRINGLES" Method
The pringles lid is a very good method for doing a WB. It's better than AWB but not as accurate as the Expo Disc or the Hicks method but it is very fast to a quick WB and it's cheaper than an Expo Disc.
Just my 2 cents worth.
Apr 05, 2004 at 12:35 AM
edtang
Image Upload: Off
p.1 #8 · The "PRINGLES" Method
As a quick tool, I just took 3 stacked coffee filters and had them laminated - very cheap and easy to use.
edtang
Apr 05, 2004 at 03:14 AM
Littlebike
Image Upload: Off
p.1 #9 · The "PRINGLES" Method
I tried the coffee filters and Resporators and did not like the results so I took it one step further.
I went to a stainded glass shop and had them cut a piece of "Flash Glass" (Milky white coating) and fit it into an old Polorizer filter. Works great.
I still shoot in RAW just so I can do any minor tweaking I want to but would never consider shooting without it.
Apr 05, 2004 at 01:16 PM
Dimitris
Image Upload: Off
p.1 #10 · The "PRINGLES" Method
Another idea is to use the bottom half of a Cokin filter case - it is reasonably white (to my eyes...) and seems to do a pretty good job.
Apr 10, 2004 at 07:42 PM
Lost password?
