Archive 2009 · SpectraView II Calibration Problem – Greenish Cast
Mardon Erbland
p.1 #1 · SpectraView II Calibration Problem – Greenish Cast
Since upgrading to Windows7 x64, my SpectraView software/hardware will not set a proper white balance when calibrating my NEC display. It produces a greenish color cast. (My equipment list is at the end of this post.) The NEC software/hardware had been working fine on Vista x64. I did a clean install of Windows7.
I have tried the obvious things like cleaning the screen. I have also completely uninstalled SpectraView, rebooted and reinstalled it. I even did a fresh download of SpectraView 1.1.03 from the NEC site and installed that. I also reinstalled the latest nVidia driver. And I even ran the X-Rite i1Diagnostics and the hardware was reported as “successful”.
If I calibrate the display with SpectraView using the “Native” white point setting, the calibrated display looks fine. If I calibrate the display with SpectraView by specifying a white point (like D65, 6500K, etc.) then the display has a very greenish cast.
I used the colorimeter window in Spectraview to measure a white sample for the Native calibration and also for the D65 calibration, Here is a screen capture image of the SpectraView Colorimeter windows:
http://www.justphotos.ca/misc/spectraview.jpg
Of course, neither image will look greenish on a properly calibrated monitor. What is important is that for the SpectraView calibration that used the my NEC display’s Native white balance (the one that looks correct to the eye) the colorimeter is reporting a color temperature of 3375K. For the SpectraView calibration that used a selected white point of D65 (the one that looks greenish to the eye) the colorimeter is reporting a color temperature of 6565K. Does this indicate that the colorimeter itself has failed? It was working fine on Vista x64 just before I made the switch to Windows7 x64.
So, do I have a faulty colorimeter or is something else wrong?
Here’s my equipment list:
NEC LCD2690WUXi display
SpectraView II software 1.1.03 Build 090828
NEC SpectraView colorimeter (X-Rite eye-one Display 2)
Latest display adapter nVidia GeForce GTX260 OC Driver 191.07 (2009-09-27) downloaded from nVidia.
nVidia Control panel set to let SpectraView control color.
Nov 24, 2009 at 09:21 PM
colinm
p.1 #2 · SpectraView II Calibration Problem – Greenish Cast
There are known issues with Windows 7 and SpectraView II right now; it's not certified for 7 yet.
NEC has indicated they'll be resolved in an upcoming update. Still, I'd contact NEC support and see (a) if they're aware of the specific issue you're having and (b) there's a beta release available in the meantime.
Nov 24, 2009 at 10:33 PM
UCSB
p.1 #3 · SpectraView II Calibration Problem – Greenish Cast
I'm using the same version of SV II on my Windows 7 system and it appears to be working fine.
Differences:
i1 Pro
ATI 4850 graphics card
My system is brand new and has all of the latest W7 drivers and software. Maybe I need to go back a take a closer look.
Nov 25, 2009 at 06:40 AM
Alan321
p.1 #4 · SpectraView II Calibration Problem – Greenish Cast
The two samples posted use a very different screen brightness. Perhaps that matters because one is maxed out.
-Alan
Nov 27, 2009 at 04:28 AM
Pondria
p.1 #5 · SpectraView II Calibration Problem – Greenish Cast
I am using SV 2, identical version/build on W7 x64, which was an upgrade from Vista x64, 2490WUXi. No problem.
It probably won't make a difference but there is a new 195.62 nVidia driver available.
Nov 29, 2009 at 05:31 PM
Mardon Erbland
p.1 #6 · SpectraView II Calibration Problem – Greenish Cast
Thanks for all the replies.
I’ve been in touch with NEC support. They had me do a number of tests and concluded that my eye-one hardware is faulty. It appears to be reading the blue channel incorrectly. They are sending me a new one under warranty. I should have it next week. Hopefully that will fix the problem.
Ping Alan321: The “Native” setting in SV forces the display to its maximum luminance value. It cannot be set any lower if “Native” is chosen as the White Point
Ping Pondria: Thanks for the heads up on the new driver.
Nov 29, 2009 at 07:17 PM
Mardon Erbland
p.1 #7 · SpectraView II Calibration Problem – Greenish Cast
I'll close this thread with a report that it was a bad sensor causing my problems. I received a replacement MDSVSENSOR eye-one Display 2 from NEC today and all is working great again. I guess it was just coincidence that the sensor failed at the same time I switched to Windows 7.
Dec 01, 2009 at 12:13 PM
