slin100 Offline Upload & Sell: Off
p.1 #24 · How do I use Canon speedlite, it doesn't do anything :/ | |
Namik wrote:
Namik wrote:
big country wrote:
are you putting it on the camera correctly? i've seen that happen before.
I think I am putting it correctly...all pins seem to align.
I already mailed it back to sender. I also tried it on one of my friend's nikons and it behaves the same way: just fires preflash.
Trying the 420EX on your friend's Nikon would not have helped troubleshoot the problem. Canon flashes are not designed to be used on Nikons and vice versa. Each company uses a proprietary flash system.
I cannot think of any setting on the 40D that would have explained what you experienced. The fact that the internal flash works suggests that the flash exposure compensation is not misset. The 420EX does not have its own flash exposure compensation controls, so the camera's flash exposure compensation settings take precedence.
It does appear that the flash is malfunctioning, but it is possible that the 40D has a problem, too. You could go to a local photography store and ask to try a brand new EX flash on your 40D to localize the problem. If the problem still occurs, then your 40D has the problem.
