Mike K Offline Upload & Sell: On
p.1 #8 · Will a wide Cokin-P holder vignette on a 24mm TSE (shifted) or a 21mm ZE? | |
saravk wrote:
Thanks for the replies everyone. So let me get this straight.. In order to use the 24TSEII or 21ZE i'll have to go for the 100x150mm Lee/Z-Pro size holders. The regular 84x120mm filters simply wont do. Is this right ??
I have just received the Zeiss 21 2.8 ZE and several weeks ago the Canon TSE 24 II. They both take 82mm threads. Also bought an 82mm CP for them. However the grads I have been using (Hitech) are the 85P Cokin size and and to address your questions I just did a few tests since I was also very interested to see what would work:
I do not have an 82mm adapter for the Cokin holder as I was planning on holding the filters by hand in front of the lens. On the 24 TSE this is no problem, you don't even need to take the lens hood off. The filter is narrower than the lens hood, but using the 5DII viewfinder shows that the filter is easily wide enough, I don't see the filter edges. This says that given the ~1.5 cm depth of the hood, I could probably mount the Cokin filter holder without seeing too much vignetting (depending upon aperture). Also my strategy of hand holding would technically work.
Now the Zeiss is a different story. The wider angle of view with the 21mm focal length means that even though the petal hood is very short, holding the filter in front of the hood, it will not cover the frame. Through the viewfinder one can see quite a bit of image between the outer edges of the filter and the edge of the frame. Thus one will have to take the hood off, and the GND filter is the same width as the outer edges of the lens barrel. Holding the filter with the hood off is easy as the lens barrel will help stabilize the hand. This also says that even with a 82mm adapter, the Cokin filter holder will not work on the 21mm Zeiss. A wider system, such as the Lee will be needed if the filter holder is critical to your work style.
Since the camera is always on a tripod for this type of work, I am going to try the handhold solution to see how it works before purchasing anything else. I have done that before, even when my 77mm lens had the adapter in the camera bag.
I have done some preliminary tests comparing these two lenses with the Canon 24-70 L f2.8 and am writing up a summary...
I will probably post it on the "Alternative" Forum.
Mike K
