Peter Figen Online Upload & Sell: On
p.1 #2 · Photoshop, layers, selections, etc. | |
You have a couple of choices. One is to straighten out your file before you start working on it. Second, and you have to do this while your original file is open - after you make your Free Transform to straighten out the image, you click on the Path you used to make your selection, activate the path, go to the Edit menu, down to Transform, then to "Transform Again". This will apply the previous transformation to your Path.
If you have saved your selections as additional Alpha Channels, then, after you do your original transform, you click on the Alpha channel to make it visible and then go to the Edit>Transform>Transform Again, which will apply the move to your entire channel. Again, this has to be done immediately after your tranform and before you close the file.
