mike09 Offline Upload & Sell: Off
p.1 #4 · Short telephoto Advise | |
jasoncallen wrote:
I've owned both the 85/1.8 AF-D and the 85/1.4 AF-D, and either would be a good addition to your kit.
The 85/1.8 delivers sharpness pretty much wide open. The only think I never 100% cared for on that lens was the bokeh rendition... the defocused areas of the image had a sharpness about them that I can't quite put my finger on, but it's very obviously different from the various 80-200 & 70-200/2.8 lenses I've owned, and it's worlds apart from the 85/1.4's creamy backgrounds. After using a rented 85/1.4, I couldn't go back to the 85/1.8... I sold mine and coughed up the cash for the 1.4 AFD!
The 85/1.4 is a professional workhorse for those needing an extra of low-light performance, and DREAMY, CREAMY bokeh. They call it "the cream machine" for a reason At almost 3 times the price of the 85/1.8, it's hard to justify if you're not earning money with it, but it's a lens that will stay with you for a LONG time, across generations of Nikon's bodies!
The longer primes are great for more reach, but on a DX body, they're going to be significantly longer than what you have, and you're going to be wanting something in the middle range between your 50 and a 105 f/2 or 135 f/2 prime.
I'd say the 85/1.8 is the safe bet!
I see what you're saying. Although I did pull the trigger and buy the 17-35, it was still a lot used, but is certainly a wonderful lens.
I'm gonna have to go to B and H and try both the 1.8 and 1.4 first hand. Maybe seeing the delicious bokeh first hand will sway me toward the 1.4, I just hope if that happens I don't max my credit card out.
In terms of robustness, are the 85 1.4 and 1.8 about the same? I mean, are both lenses weather sealed, or generally built like tanks like other Nikon pro glass like my 17-35? Or is it more like the 50 1.4 where it's just an all around solid lens.
One more thing to add, what about the 105 2.8 micro. I know the new AF-S version is out, but how about the older AF-D version. Any thoughts?
